Old 08-03-2013, 04:31 PM   #31
Prutser
Prutser's Avatar
Oddometer: 969
Originally Posted by Zodiac View Post
what do you mean "loose" the drum brake?
Do you mean, lose?
"lose" sorry about that.
BMW R100'91/R80'93/R75/6 R80ST'83/R65GS'87/GasGasTXT300/DouglasW20-1920
Ride Report 2012
Prutser is offline   Reply With Quote
Old 08-04-2013, 06:08 AM   #32
Clay Spinner
Clay Spinner's Avatar
Oddometer: 642
I had read that Pruster was going to revert back to his 37:11. For my efforts, the 37:11 will have the gearbox with the higher 5th and an 18 inch rear wheel. The 32:10 mono will run the gearbox with the lower 1st, higher 5th and a 17 inch rear wheel. In my lack of knowledge (and no desire to model it in excel) I'm thinking these two setups will be quite similar in terms of rpm and speed. I don't really want to go lower as the 37:11 will have a 1000cc engine and modded heads messed with by Moorespeed while the 32:10 will be running a r100 full fat engine...I don't really want to be wheeling in third gear off the throttle.
Clay Spinner is offline   Reply With Quote
Old 08-04-2013, 06:31 AM   #33
chasbmw
Oddometer: 2,120
[I'm thinking these two setups will be quite similar in terms of rpm and speed. I don't really want to go lower as the 37:11 will have a 1000cc engine and modded heads messed with by Moorespeed while the 32:10 will be running a r100 full fat engine...I don't really want to be wheeling in third gear off the throttle.[/QUOTE]
I think that's fairly unlikely, whoever modded your engine!
Charles
1971 Commando Fastback
Old 08-04-2013, 07:41 AM   #34
Prutser
Prutser's Avatar
Oddometer: 969
My engine has the 1000cc powerkit a different cam, ported heads and a Siebenrock exhaust. It has no problems to get the bike going with the 18" wheel. My biggest reason to go back to the 37:11 is to be able to ride real slow without using the clutch.
When I was using the 32:10 I allready had the shorter first gear but for my use it was to tall.
For more road use the 32:10 should be fine.
Ride Report 2012
Old 08-04-2013, 05:02 PM   #35
Jim K in PA
Jim K in PA's Avatar
Oddometer: 1,041
Good input Prutser - thank you.
Jim K in PA
1979 BMW R100T - Otto - Returned to the road - 5/12/11
1975 BMW R90S Hack - Olga - Olga's story - adopted 3/22/14
Viktor - Coming to a thread near you - eventually
Jim K in PA is offline   Reply With Quote
Old 08-05-2013, 07:17 PM   #36
bmwrench
Oddometer: 2,062
Originally Posted by adrenal View Post
Hey wrench, so you built one with new crown and pinion..
Is there a source for longer than 32/11 gear sets?
(apologies for threadjack Jim)
Yes-BMW! You'll find the 33/12 in Maxes parts site under '77-'84 R100RS.
bmwrench is offline   Reply With Quote
Old 08-05-2013, 08:29 PM   #37
adrenal
skrunkwerks.com
adrenal's Avatar
Oddometer: 529
Well I never! tks wrench.
Trouble is, I need the longer gear set for a monolever drive, nothing listed as far as I can see.
Any clues?
Adrian
cafebeemer is now:http://www.skrunkwerks.com
farcebook page: http://facebook.com/skrunkwerks
instagram: #skrunkwerks
adrenal screwed with this post 08-06-2013 at 06:14 PM
adrenal is offline   Reply With Quote
Old 08-07-2013, 10:34 AM   #38
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,469
Any clues?
I think the tallest ratio you can get for a mono is the 33:11 off later RS models.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Airhead Wrangler is online now   Reply With Quote
Old 08-07-2013, 07:07 PM   #39
adrenal
skrunkwerks.com
adrenal's Avatar
Oddometer: 529
Yes, think that's right, 33/11 is the longest stock ratio for the mono (I've got one), but trying to find out if there are any after market options out there for even longer gearsets..
Think I might be pissing up wind with this one though!
Adrian
adrenal screwed with this post 08-07-2013 at 11:54 PM
Old 08-08-2013, 04:25 AM   #40
Clay Spinner
Oddometer: 642
Richie Moore does a +10% gear set (i.e. you need to rebuild your gearbox)... you could try him ... just google moorespeed bmw.
Old 08-08-2013, 06:52 AM   #41
adrenal
skrunkwerks.com
adrenal's Avatar
Oddometer: 529
Thanks Clay Spinner, I knew about longer 5th gear but I thought it was 5% - will have another look..
Adrian
adrenal screwed with this post 08-08-2013 at 07:12 PM
Old 08-08-2013, 09:11 AM   #42
ME 109
ME 109's Avatar
Oddometer: 2,575
I put a taller 5th in my 33/11 recently.
Indicated speed of 130 kph used to show close to 5000
The same speed now shows close to 4500
Lord of the Bings, kangaroo farmer
ME 109 is online now   Reply With Quote
Times are GMT -7.   It's 06:06 PM.
