Old 10-31-2012, 07:51 AM   #1
Rockwell OP
Rockwell's Avatar
Oddometer: 460
Tune ECU Question
Can I disable both the SAS and the valve for the carbon canister with Tune ECU, and not have to use resistors to trick the ECU out?
Also, what cables are required to communicate with the ECU?
not all those who wander are lost | two earthlings ride around the world
Home | Photo Blog | The Route | The Bike | About Us | Participate!
Rockwell is offline   Reply With Quote
Old 10-31-2012, 08:24 AM   #2
Rockwell OP
Rockwell's Avatar
Oddometer: 460
Found this one on CJ's site: http://www.dualsportwarehouse.com/CJ...TUNE-C-KTM.htm
Other than software and a laptop, is this everything I will need?
Old 10-31-2012, 02:28 PM   #3
Desmofan
Bring the whole family!
Desmofan's Avatar
Oddometer: 500
Yes, TuneEcu has 4 check boxes (EPC, SAS, Idle control, O2)-you can disable all with the software (leave idle control on).
I unplugged and threw away my charcoal cannister, leaving the wiring in: no fault codes or lights.
KTM990 SMT
KTM950 Adventure
DRZ400S
Ducati Superlight--gone but not forgotten
Desmofan is offline   Reply With Quote
Old 10-31-2012, 03:09 PM   #4
Rockwell OP
Rockwell's Avatar
Oddometer: 460
Thanks.
Why would you disable O2? Will this ignore inputs form both lambda sensors?
Old 10-31-2012, 09:23 PM   #5
Desmofan
Desmofan's Avatar
Oddometer: 500
Yes it does. You really need to wade thru all 80 something pages of "990 got tunes ?" here in Orange crush. My SMT is tunecu mapped (from the website map library) ,with secondary throttles disabled and removed, o2 loop off, CPR airfilter etc, and it runs like a raped ape, but so smooth down low compared to stock.
KTM990 SMT
KTM950 Adventure
DRZ400S
Old 11-01-2012, 12:51 PM   #6
Rockwell OP
Rockwell's Avatar
Oddometer: 460
Yes. I need to find the time to sit down and go through that entire thread. Just put in the order for my cable last night. Hopefully they'll have them in stock and shipped out soon. Will have the rest of the bike together this weekend.
Old 11-02-2012, 07:41 AM   #7
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 2,575
You might want to do a bit more reading about turning off the O2 sensors and the effect it has on AFR during closed loop running at higher elevations/ambient temperatures.
'07 KTM Adv990S
No myriad hues of laser lights no bottles that are oozing with nectars from heaven, no beautiful body soft and warm to the touch but, i have a very small desire.. Give me a dark.. long.. winding road, three gears to go and my Hellas on fire..
950Rally picture thread
Vicks is offline   Reply With Quote
Old 11-02-2012, 08:26 AM   #8
Rockwell OP
Rockwell's Avatar
Oddometer: 460
I'll try to find that in the thread.
I'm pretty new at all this stuff, but, when you say "closed loop running", what feedback signals are you referring to when you use that term? There are throttle position sensors, O2 sensors, speed sensors, air temperature sensors, etc. I am assuming that most of these are used in the feedback loop for AFR output, but, if you disable the O2 sensors, is that still considered to be closed-loop since not all the required feedback is being received? Also, are there times when the system runs open-loop?
Maybe all this stuff is covered in the TuneECU thread? If so, I should probably get to that soon. Just need to find the time.
Times are GMT -7.   It's 09:35 PM.
