Old 11-20-2012, 06:55 AM   #16
RGregor
Oddometer: 465
Originally Posted by chasbmw View Post
I assume that the orange lines on the gaskets are a compound that help to seal the gaskets?
Charles
Some kind of silicone
RGregor is offline   Reply With Quote
Old 11-20-2012, 06:58 AM   #17
RGregor
Oddometer: 465
Originally Posted by Airhead Wrangler View Post
That tiny ring is now VERY close to the holes for the cylinder studs. Not a problem, I guess though.
Yours? What's the environment you run it in?
Old 11-20-2012, 07:00 AM   #18
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,513
No, not mine, just a random photo I found on the internet. I'd never paint Siebenrock cylinders. Especially, not running it here in Mexico in 40+ degrees.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 11-20-2012, 07:00 AM   #19
AliBaba
AliBaba's Avatar
Oddometer: 372
100mm bore (racing only):
AliBaba is offline   Reply With Quote
Old 11-20-2012, 07:12 AM   #20
Airhead Wrangler
Adios Mexico
Oddometer: 6,513
That'd make for 1109cc. Hot mama.
Old 11-20-2012, 07:58 AM   #21
AliBaba
AliBaba's Avatar
Oddometer: 372
With a long-stroke crank you can even get 1160cc.
Old 11-20-2012, 10:02 AM   #22
RGregor
Oddometer: 465
A friend has an engine with 102mm bore.
Full story (in german) here.
http://www.boxerkunst.de/content.php...r-Alpenbrenner
Pistons were from Werner Fallert, cylinders are custom made.
No long term experience yet.
Old 11-20-2012, 01:26 PM   #23
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,513
That goes for polishing various outer parts as well; some may think it looks good, but it makes the engine run much hotter.
David Hunn:
R100GS Ray Peake special.
http://www.advrider.com/forums/showt...uild+australia
gsd4me is offline   Reply With Quote
Old 11-20-2012, 02:03 PM   #24
pommie john
pommie john's Avatar
Oddometer: 1,455
Not much room between the bore and the studs.
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt.
Bertrand Russell
pommie john is online now   Reply With Quote
Old 11-21-2012, 05:40 AM   #25
RGregor
Oddometer: 465
Originally Posted by supershaft View Post
I wonder if the cylinders 'walk ' more with no skirts?
The 98mm Siebenrock cylinders have a very short and thin (1mm) skirt.
Old 11-21-2012, 05:41 AM   #26
RGregor
Oddometer: 465
Close to none. I'm wondering if they last ...
Old 11-21-2012, 09:05 AM   #27
craydds
craydds's Avatar
Oddometer: 1,160
Yes, they do last... for 10 hours. For race motors only.
ABC #12947
'75 R90S
craydds is offline   Reply With Quote
Old 11-21-2012, 09:43 AM   #28
RGregor
Oddometer: 465
It's not a racer but a normal street bike.
And it's intended to last.
I'll report, if it doesn't.
Old 11-21-2012, 09:49 AM   #29
craydds
craydds's Avatar
Oddometer: 1,160
Sign me up for a set.
ABC #12947
'75 R90S
Old 11-21-2012, 09:57 AM   #30
Airhead Wrangler
Adios Mexico
Oddometer: 6,513
I've never seen an open oil ring like that. It seems like you'd get some accelerated wear where the oil ring enters the grooves on both sides of the wrist pin. Is he using a normal 70.6mm stroke? Longer rods or shorter barrels?
Times are GMT -7.   It's 09:05 PM.
