Old 10-31-2012, 04:21 PM   #1
KaceCoyote OP
Pass the queer more beer
KaceCoyote's Avatar
Oddometer: 5,632
DR650SE wont start!
So, bike sat for a week on a flat tire. Tire gets fixed, but wont start now.
Heres the deal, its an IMS tank with the stupid IMS petcock which I already ripped apart, rebuilt and doublechecked to make sure it actually flows and doesnt leak. so, Petcock eliminated. Turns over, will pop over a few times and then promptly dies right out.
Recharges the battery, checked the plugs and terminal connections. Good voltage to the plugs are confirmed.
So here are some potential environmental factors. Gas did seem a little dark, but its only like a week old so wtf? Could water have contaminated the fuel to a sufficient amount to let it fire a few, then conk out? Not sure. No fucking clue really what could be at work here, I've run through my diagnostics list and any assistance would be greatly appreciated. Am under a somewhat intense time deadline here.
When the smoke clear, you can see the sky again
There will be the chopped off heads of leviathan
My friend, they call 'em strangers
Everybody talk to them end up in some danger
-MF Doom, Strange ways
KaceCoyote is offline   Reply With Quote
Old 10-31-2012, 04:30 PM   #2
NJ-Brett
Brett
Oddometer: 6,444
Pull a spark plug and check it, and see if you have spark.
Does the exhaust smell like nasty off gas?
Choke working?
Kill switch on?
Carb float stuck?
Brown gas does not sound good...
NJ-Brett is offline   Reply With Quote
Old 10-31-2012, 09:55 PM   #3
clapped_r6
The Spoad Warrior
clapped_r6's Avatar
Oddometer: 2,695
drain the float bowl with the petcock "on" for a few oz. get the schmeg that is sitting at the bottom out. most likely.
none of us is as dumb as all of us
clapped_r6 is offline   Reply With Quote
Times are GMT -7.   It's 11:20 PM.
