Old 10-31-2012, 08:54 PM   #1
maigashi OP
maigashi's Avatar
Oddometer: 117
Fuel mileage on gravel
What should I expect l/100km travelling long distance on fire roads at about 90-100 km/h with 80lbs on the back? Have to plan fuel load
maigashi is offline   Reply With Quote
Old 10-31-2012, 08:58 PM   #2
Deuce
Crazy Canuck
Deuce's Avatar
Oddometer: 2,797
Your going to have to speak American here. Most guys won't know what your talking about with l/100km thing. I would guess your mileage will be pretty much the exact same as if you were driving those speeds on pavement. Why would it be any different?? Most guys get better mileage on gravel because they are riding at slower speeds anyway.
I'm not lost for I know where I am. But however, where I am may be lost.
-- Winnie the Pooh
Deuce is offline   Reply With Quote
Old 10-31-2012, 09:08 PM   #3
sorebutt
Oddometer: 1,825
I average 52-55 mpg on mixed forest roads and pavement. I am always good for at least 200 miles. Now convert that.
sorebutt is online now   Reply With Quote
Old 10-31-2012, 10:01 PM   #4
maigashi OP
maigashi's Avatar
Oddometer: 117
Only in 'Merica. Lol. Reason I ask is because of the increased on off on the throttle and increased drag from the gravel
Old 11-01-2012, 05:20 AM   #5
ebrabaek
Oddometer: 4,745
Gravel at 45-55 mph...... I get 65-70 mpg...... On technical rocky gnarly stuff at 20-30 mph....45 mpg.
Erling
Old 11-01-2012, 05:39 AM   #6
Ceri JC
UK GSer
Ceri JC's Avatar
Oddometer: 2,462
Gravel I get higher MPG than on the slab, because I drive slower. If you are doing equivalent speeds though, I suspect you would get worse on the gravel because of all the energy being wasted (on/off the throttle, wheelspin, kicking up roost, etc,)
I like my bike because I can overtake 4x4s down farm tracks with a week's worth of shopping on the back.
Ceri JC is offline   Reply With Quote
Old 11-01-2012, 06:41 AM   #7
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,712
Keep the smile on your face!
Originally Posted by Reaver View Post
You can be imitated but not replaced. You're such a special blend the recipe is guarded like KFC's 11 herbs and spices.
Homeless Otter on the road One month to find the rising sun
Loutre is offline   Reply With Quote
Old 11-01-2012, 07:12 AM   #8
TRZ Charlie
That's MR. Asshole
TRZ Charlie's Avatar
Oddometer: 15,889
Isn't this going to be a subjective answer? I mean there are variables. For instance are you riding a fuel injected 250 or a 650 with and FCR carb? Are you a hot shot that ramps off stuff, wheelies at will and roosts his buddies or are you an older guy that just putts along?
Just sayin
My SPOT - No tracks = not riding | Husky TR650 Thread Index | Husky TR650 OEM and Interchangeable Parts List | Cheap Beer & Tenderloins | "You know your getting old when a bad hair day includes your nose, eyebrows and ears" - Inmate - advNZer?
TRZ Charlie is offline   Reply With Quote
Old 11-01-2012, 07:44 AM   #9
maigashi OP
maigashi's Avatar
Oddometer: 117
Just clarifying this is this is the f800gs forum, so this is the bike implied.
Old 11-01-2012, 08:31 AM   #10
sorebutt
Oddometer: 1,825
[ Are you a hot shot that ramps off stuff, wheelies at will and roosts his buddies or are you an older guy that just putts along?
Just sayin[/QUOTE]
Not all older guys putt along. I know some older guys that embarass hot shot young guys.
Old 11-01-2012, 08:39 AM   #11
vtbob
wanderer
Oddometer: 579
It depends on the gravel...hard or soft and loose.
Hard to say exactly but my guess is 0 to 5%less if the gravel real loose marbles that you have to wade thru...like the Northern american roads just after the grader has gone thru
vtbob is offline   Reply With Quote
Old 11-01-2012, 12:51 PM   #12
Bayner
Oddometer: 1,577
I get slightly lower mileage on gravel than I do on pavement. Probably because I like to horse around more in the woods. If I reduce speed on gravel it burns about the same. Keeping it under 80KPH will return the best range between fuel stops.
Bayner is offline   Reply With Quote
Old 11-01-2012, 01:33 PM   #13
Bucko
In a parallel world
Bucko's Avatar
Oddometer: 817
I get slightly better mileage on gravel, probably because it usually includes some side trips on slower two-tracks. Speeds on gravel range from 30 to 90 mph, depending on conditions
Just to clarify, that's on an F800GS. My DR-Z won't go that fast
Bucko is offline   Reply With Quote
Old 11-01-2012, 06:40 PM   #14
GH41
Oddometer: 822
I cannot say what I want to for fear of being thrown out of another forum!!! I am running out of boards to post to!! GH
GH41 is offline   Reply With Quote
Old 11-01-2012, 09:43 PM   #15
sorebutt
Oddometer: 1,825
You mileage may vary depending how you ride. Short trips you might be playing with the throttle coming out of the corners. You will ride considerably different if you have to cover over 200 miles before the next fuel. You will find you are very gentle with the throttle. 200 miles is easy and 240 miles possible with a conservative throttle hand. Plus you can always carry some extra fuel.
Times are GMT -7.   It's 07:11 PM.
