11-02-2012, 12:08 AM
#16 |
Oddometer: 2,544
my question is... why even fool with dyna beads? it's not like balancing a tire is hard to do. a standard balance using weights uses the smallest amount of weight possible.
Bringing BMW R90S back to life, R80G/S, LiFePO4 testing Which is more reliable ... Points or Electronic Ignition for Airheads? |
11-02-2012, 01:32 AM
#17 |
Oddometer: 1,446
Well, in my case I didn't have a balancer. Now that I do I favor of the tape weights. My stateside bike has Dynabeads in it's tires because I don't have access to a balancer where the bike is kept.
11-02-2012, 03:09 AM
#18 |
Keep On Keeping On!
Oddometer: 1,856
The Dynabeads will keep the tire balanced as it wears and weigh less than conventional weights.
“Do not be afraid; only believe.” |
11-02-2012, 06:06 AM
#19 | |
Deputy Cultural Attaché
I've been using the beads on a couple of my bikes and have not had any air loss issues.
Successfully surviving motorcycling since 1976. |
11-02-2012, 09:07 AM
#20 | |
Oddometer: 1,090
I've found many tires today come pretty well balanced. Many don't even have the dot to show where to line up the valve stem. I've found my rim is more out of balace than some tires. However, an out of balance tire would have a greater affect because it is on the outside of the rotating mass. I find that if a tire takes a lot of weight to balance I can rotate the tire on the rim and it will take less weight. Here is my take on how the beads work. They don't migrate to the lightest place. That is impossible. They simply add mass to the outside of the rotating mass. The increased mass will override any slight difference in tire balance. Those people that say they work have tires that are already close to being in balance and those that say they don't work have used them with a tire or wheel that is a long way from being balanced. |
11-02-2012, 09:25 AM
#21 | |
No offense intended; it is probably not something that is intuitive. However, they do work, and are in wide use in a variety of applications. Dynabeads are merely one method of dynamic balancing.
11-02-2012, 10:00 AM
#22 | |
Oddometer: 1,090
11-02-2012, 11:04 AM
#23 |
Oddometer: 1,665
I use them, they have worked exactly as advertised for me. Running rim-locks in both front a rear and they have worked great up to 90+mph.
No problems with air leakage from the valve core. Follow the directions for how much to add and the core and you should have no problems. I use a metal valve core cap with a rubber gasket which should also stop any air getting by the core, but I have never seen that anyway. http://www.innovativebalancing.com/motorcycle.htm Explanation on how they work and more info+ http://www.innovativebalancing.com/HowItWorks.htm
TRAIL STAND (advrider thread)- Dual Sport Portable Jack Stand www.endurostar.com Husqvarna TE630 Husqvarna TE610E (for sale) Cagiva Gran Canyon |
11-02-2012, 11:23 AM
#24 |
has become "FERAL"
Oddometer: 1,638
I just balance my tires when I change them and never worry about anything until I replace them
< spell cheqeur is bustimicated > |
11-02-2012, 12:09 PM
#25 |
bikaholic
Oddometer: 1,536
I've always wondered how well they stay in place under hard braking and acceleration. Insome cases a tire itself will actually move on the rim under extreme circumstances and they're locked in place with a bead. There is nothing keeping any beads or liquids from spinning inside the tire under these circumstances which would cause momentary imbalance at a most inopertune time in my opinion.
11-02-2012, 03:21 PM
#26 | |
http://youtu.be/ullnFQD4F1I
11-02-2012, 03:53 PM
#27 |
I will test with ATF, because I have, because it don't freeze and because it don't rust anything.
I did the same test with a small plastic bottle than DynaBeads youtube video and worked 100%.
DiasDePlaya "Ya veras como quieren en Chile al amigo cuando es forastero" Traditional song |
11-02-2012, 06:04 PM
#28 | |
Oddometer: 2,544
let's assume for sake of argument that dyna bead is not snake oil and it works as advertised. conventional balancing is easy and has zero issues. besides clever marketing, why in the world would anyone need dyna beads? convinced dyna beads are a solution looking for a problem. sorry there's no problems with conventional balancing. a balancing rig can be made for dirt cheap. two roller bearings, one solid shaft and some spacers. resting on two jackstands. heck a harbor freight balance stand is about $37.
11-02-2012, 08:30 PM
#29 | |
Disgruntled Student
Oddometer: 1,596
11-03-2012, 07:46 AM
#30 | |
Oddometer: 1,089
I do plan on buying a balancing stand one day though, and have this hair-brained idea to start running Craigslist ads to make a couple of bucks mounting tires for people. |
