Old 11-01-2012, 02:53 AM   #1
jimmibanke OP
jimmibanke's Avatar
Oddometer: 102
Clutch hacking and draggin at startup.
Hello
I have a startup problem with my 2003 950 adv. Its hacking and dragging when the motor is cold, any of you that have the same problem, and whats the cure for it?
Best regards from denmark
jimmibanke is offline   Reply With Quote
Old 11-01-2012, 05:53 AM   #2
jimmibanke OP
jimmibanke's Avatar
Oddometer: 102
When i release the clutchlever in gear it sometimes hack like the plates are not fully connectet (hope you understand what i mean?). This stops when its warm. I have read somewhere about a oil jet, do i have to clean this or make the hole bigger? What have you done?
Old 11-01-2012, 06:25 AM   #3
MotoTex
Miles of Smiles
MotoTex's Avatar
Oddometer: 1,699
Take a look at this thread.
Maybe it will lead you to some happy time quicker than it took me to figure it out.
This is The Internet. Confirm for yourself anything you may see while visiting this strange and uncertain land.
MotoTex is offline   Reply With Quote
Old 11-01-2012, 06:27 AM   #4
DeepInIt
DeepInIt's Avatar
Oddometer: 1,368
As someone informed me, that's an easy one and there are many threads. The full solution is replace your disk pack for your clutch. Specifically the last fiber disk in the pack has become too thin and the metal centering rings, I think that is there purpose are eating into and grabbing the last metal disk. if you want, you can buy some time with a quick cleanup and swap. I did this because parts aren't available in Argentina.
Lay the bike on it's side, remove clutch cover, leave basket in bike but remove springs and bolts. You can remove all plates, keep track of order off things. The final metal plate will have gouges in it. Sand those smooth and swap with a plate from the middle of the pack, reassemble and enjoy. Takes 30 minutes. In reality, your final fiber disk is thinner than the combination of the two centering rings and you will be gouging the moved metal disk.
Also check your oil jet and clean it out. Many threads on this.
DeepInIt is offline   Reply With Quote
Old 11-01-2012, 06:57 AM   #5
jimmibanke OP
jimmibanke's Avatar
Oddometer: 102
Thank you mototex and deepinit, very helpfull (I hope:-) I have been seaching around but its hard to find something clear simple and usefull.. Is there any pictures of the plates in here on how they should be sitting in there?
Old 11-01-2012, 07:05 AM   #6
Brown Dog
North Georgia Dual Sportr
Brown Dog's Avatar
Oddometer: 1,947
Cleaning clutch oil jet Didn't help mine
My SE has did this since new, but i solved it :
Simply get in the habit of working the clutch lever in & out multiple times AFTER cold start ups before putting bike into gear
It works oil into the clutch disc that runs out while sitting.
Problem solved
Brown Dog is offline   Reply With Quote
Old 11-01-2012, 08:29 AM   #7
jimmibanke OP
jimmibanke's Avatar
Oddometer: 102
Brown dog, i do that now but its not every time its working, and i prefere fixing the problem so i can drive with peace in mind:-)
Old 11-01-2012, 08:51 AM   #8
MotoTex
Miles of Smiles
MotoTex's Avatar
Oddometer: 1,699
That didn't work for me either. Though it seemed to help intermittently, it wasn't a consistent remedy.
Getting the plates' sharp edges oriented correctly and the fibers in the right places was what got it right for me.
Old 11-01-2012, 10:33 AM   #9
jimmibanke OP
jimmibanke's Avatar
Oddometer: 102
Sure hope its the key to solve this problem:-). Mototex do your have any pics of how they should line up? Or is it easy to tell when you have the plates out?
Old 11-01-2012, 12:48 PM   #10
Wallaby_Ted
You call that a bullbar?
Wallaby_Ted's Avatar
Oddometer: 120
Originally Posted by jimmibanke View Post
Hello
It might be the clutch oil jet is blocked, i had a similar problem on my 08. I cleaned the clutch jet and it sorted the problem for me (bike is at 70,000km's)
Left or right???
www.checkingtheboundaryfence.com - The upside, down-under tour of Australia. August to September 2009
Wallaby_Ted is offline   Reply With Quote
Old 11-01-2012, 12:50 PM   #11
AdvGa
AdvGa's Avatar
Oddometer: 1,320
Here's the Oil Jet Cleaning thread:
http://www.advrider.com/forums/showp...9&postcount=62
AdvGa is offline   Reply With Quote
Old 11-01-2012, 02:49 PM   #12
TcRulz
Oddometer: 289
My 03 950A came out of the factory with no hole in the oil jet. Couldn't seem to drill one either, so bought one with the 0.3mm hole and enlarged it to 0.5mm. Bikes done 73000km with no hole and must admit that I can't tell the difference either way but never had a clutch issue.
TcRulz is offline   Reply With Quote
Old 11-01-2012, 08:26 PM   #13
MotoTex
Miles of Smiles
MotoTex's Avatar
Oddometer: 1,699
Look about halfway down the first post in the thread linked above. There is a link to an article that should help.
Let me know if that doesn't fill in the blanks.
Old 11-02-2012, 01:38 AM   #14
jimmibanke OP
jimmibanke's Avatar
Oddometer: 102
Thats the link i did not see, again many thanks! This is gold to me and others!
Old 11-02-2012, 06:42 AM   #15
MotoTex
Miles of Smiles
MotoTex's Avatar
Oddometer: 1,699
Glad I could help.
I've edited the referenced thread to make that link more obvious.
Times are GMT -7.   It's 08:07 AM.
