Old 11-02-2012, 07:19 AM   #16
1stiski
Ride that nasty thing
1stiski's Avatar
Oddometer: 1,645
On occasion mine develops this issue, it is my sign to clean the oil jet. Works everytime. But that's just mine.
"04" 950 Adventure S 37,000+ miles
2003 Harley XL883 converted to CAFE (2013-14)
"Grim Brother" #1
1stiski is offline   Reply With Quote
Old 11-02-2012, 04:40 PM   #17
Grayspeed
Grayspeed's Avatar
Oddometer: 15
Yep, same here. Clean the clutch jet out and make sure the clutch pack is assembled as it says in the LC8 manual. I had given my clutch pack some heavy work on a 2 day rally in Wales a few months ago. In the end I had to refinish the steelplates as they had been over heated but none were warped and the fibre plates were still in spec.
You definately need to keep on top of it to get the best performance.
Grayspeed is offline   Reply With Quote
Old 11-07-2012, 04:41 AM   #18
jimmibanke OP
jimmibanke's Avatar
Oddometer: 102
I have done the oil jet(totally blocked) its now clean with a hole through. and the clutch is in order now, there was one steel plate out of order...
And its working! So simple to fix, so much pease in mind.
jimmibanke is offline   Reply With Quote
Old 11-08-2012, 06:44 AM   #19
rossguzzi
990 Adv.
rossguzzi's Avatar
Oddometer: 1,022
When you say one steel plate out of order, what do you mean?
I am having clutch/creeping issues. Just trying to learn as much as possible.
rossguzzi is offline   Reply With Quote
Old 11-08-2012, 11:03 AM   #20
MotoTex
Miles of Smiles
MotoTex's Avatar
Oddometer: 1,703
Look at the link I posted above for the detail to know what he means.
In other words, read the thread, completely, and all will be revealed.
This is The Internet. Confirm for yourself anything you may see while visiting this strange and uncertain land.
MotoTex is offline   Reply With Quote
Old 11-08-2012, 11:45 AM   #21
jimmibanke OP
jimmibanke's Avatar
Oddometer: 102
Old 11-08-2012, 10:33 PM   #22
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,572
if the clutch pack is not below the minium stack height, then I would inspect all the plates. If the steel plates are not overheated and warped, then I have had very good success with the following:
1. round up a piece of plate glass, 12x12 inch or slightly bigger, tempered would be best.
2. spray contact cement
3. full sheet of 400 wet dry sand paper.
glue the paper to the glass
lightly sand the friction surfaces of steel plates while flushing the paper with fluid of choice (I use this setup in the solvent tank). Sand each side of the plates until there are no shiny spots. Now do the same to the friction plates (LIGHTLY!) to remove most of the burnished effect on the surface of the friction plates.
Flush well with solvent, blow clean/dry, cover all plates with oil and reassemble clutch.
will be butter smooth
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 11-09-2012, 02:21 AM   #23
wantok
Oddometer: 165
me too
my 04 950ADV has started doing exactly the same thing. As soon as it warms up it disappears. I'll change the clutch push rod for a later model one as the 03 & 04 ones have an alloy multi-piece one which can compress slightly as it wears causing issues. It's a simple straight swap.
Nick (wantok)
wantok is offline   Reply With Quote
Old 11-10-2012, 04:40 AM   #24
guns&coffee
Gnarly!
guns&coffee's Avatar
Oddometer: 1,237
Originally Posted by Brown Dog View Post
My SE has did this since new, but i solved it :
Simply get in the habit of working the clutch lever in & out multiple times AFTER cold start ups before putting bike into gear
It works oil into the clutch disc that runs out while sitting.
Problem solved
+1 Same issue..same temporary solution
When funds come available the Beastie will get a Rekluse
"Over the Mountains Of the Moon,
Down the Valley of the Shadow, Ride, boldly ride,"
The shade replied- "If you seek for Eldorado!" E.A.P. 1849
04 KTM 950ADV ~ "BEASTIE", '13 KTM 300XCW, '75 Husky 360WR/CR,
guns&coffee is offline   Reply With Quote
Old 11-11-2012, 08:00 PM   #25
bomose
bomose's Avatar
Oddometer: 1,255
Problem solved
I was doing the same thing for that problem. But sometimes when riding with others I didn't have time to wait.After stalling and almost falling down I decided to do something about it. I found the inner steel plate had a ring worn in it and replaced it. I also cleaned the oil jet and put on an Oberon slave cylinder. I'm not sure what did the trick, but it now works smoothly and will shift into neutral easily.I used 5w BelRay fork oil in the clutch master cylinder.
I prefer a short life with width to a narrow one with length-Avicenna
http://www.advrider.com/forums/showthread.php?t=810149 Ouray Adv
http://www.advrider.com/forums/showthread.php?t=800723 Cortez & Moab
http://www.advrider.com/forums/showt...=955211Chasing Dinosaurs
bomose is offline   Reply With Quote
Times are GMT -7.   It's 02:46 PM.
