Old 11-01-2012, 04:37 PM   #1
osro OP
Oddometer: 6
Question rpms drop when clutch lever is pulled ('77 R75/7)
My RPMs drop when my clutch lever is pulled in, even if the bike is in neutral, is this normal? I've had the bike about two months (therefore, I'm not sure if its always done this) and if the bike is cold it'll actually stall about 10 seconds after I pull the clutch in. The stalling issue came up about two weeks ago, not sure if that helps.
Once the bike is warm, the RPMs will still drop about 200 when I pull the clutch in, but no stall since I'm still idling at about 1000.
osro is offline   Reply With Quote
Old 11-01-2012, 04:39 PM   #2
ozmoses
Ride On
ozmoses's Avatar
Oddometer: 3,312
Is your free play adjusted correctly?
Opinions are like internet connections- everybody has one.
ozmoses is offline   Reply With Quote
Old 11-01-2012, 04:41 PM   #3
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,464
Check your clutch throw out bearing. Sounds like it's on its way out if not already gone.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 11-01-2012, 11:29 PM   #4
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,079
I'll second AW's suggestion.
Old 11-01-2012, 11:31 PM   #5
osro OP
Oddometer: 6
Please excuse my ignorance, but can someone point me in the direction on how to check that?
Old 11-02-2012, 01:09 AM   #6
ME 109
ME 109's Avatar
Oddometer: 2,565
Am I correct in remembering issues with crank endplay causing these idle decrease symptoms?
Lord of the Bings, kangaroo farmer
ME 109 is online now   Reply With Quote
Old 11-02-2012, 02:09 AM   #7
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,185
The troubles with crank end play causing a drop in idle are supposed to be rare and not an everyday occurrence.
The same problem caused by the throw out bearing and assorted paraphernalia is not a rare occurrence at all. In fact the idle normally drops some when the clutch lever is pulled and the trans is in neutral. This seems to bother a lot of riders that don't expect it and if as much as 200 rpm I think it is too much. But even this much and killing the engine when the engine is cold is common.
Part #11 or 12 has to be removed to get the pin #13 out. On the earliest styles and I think still in 1977 the E-clip was on the inner grove, inside the stanchions, on the back of the trans that holds the pin. Once #13 is removed the throw out arm #14 can be removed.
Part #6 is a rubber seal that fits onto the thrust piece #5.
Sometimes the bearing #4 and the thrust washer have to be fished out with a piece of wire or a magnet.
Leave the thrust rod and it's felt seal in place. They are sometimes at fault but it is not easy to deal with them with the trans in the bike. If you do need to take them out it might be best to remove the trans. It's possible to remove them with the trans in the bike but not easy.
On inspection look for irregularities of the rollers of the bearing, a smooth and polished surface of the faces of the thrust pieces and the rubber parts should be in good order.
The little bearing costs about $31, last I checked, don't try to get by with one that is ruff or showing signs of aging. When the little piece does go bad, and they do, it will take hundreds of dollars in other parts with it and it can cost several hundred more to put these parts on.
Grease all the pieces when reinstalling them. Grease the throw out bearing. Just a medium coating of wheel bearing grease. This will be washed away by a tiny amount of trans gear oil that is dripped onto the parts. This oil is sealed into the trans rear cover by the felt on the rod and the small rubber seal #6 on the thrust piece. The rear rubber boot doesn't seal oil in the trans but it seal dirt out and it should also be in good condition. (the rubber boot on the later style rear covers found on clutch carrier set ups does seal the oil in)
Notice there is a grease nipple on the throw out arm. It is for greasing the pin #13 and not for greasing the inside parts of the throw out system. They are only greased for start up and then after that they get their lube from transmission oil. It's another good thing to remember to grease that pin once a year or even more in dusty conditions. If the pin, steel, is running dry it will cause problems with the rear cover stanchions, aluminum, and to fix those the rear cover will need to be welded or replaced.
---Albert Einstein
Old 11-02-2012, 07:35 AM   #8
osro OP
Oddometer: 6
Wow, thanks for the posts guys! So based on what Disston said, it sounds like everything might be running normal?
FYI- I live in Houston and had the carbs synched/balanced in August on a day that was damn near 100 degrees. Would it be possible that I'm only now noticing this problem because the ambient temperature is 30 degrees lower than when I had my carbs synched?
Times are GMT -7.   It's 03:56 PM.
