Old 11-02-2012, 09:05 AM   #1
Yardstick OP
Hydrophobic
Yardstick's Avatar
Oddometer: 3,059
990 EFI System on a 950 -Can it be done?
Converting a 990 to carbs is pretty well documented here, but how about the other way around? Can the 990's EFI system be adapted to the 950? I would really like to have an EFI'd SE without changing out my relatively low mile engine.
Yardstick is online now   Reply With Quote
Old 11-02-2012, 09:39 AM   #2
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,856
Internally you will need to change the tone ring to get the timing done right.
Externally there are a boatload of tabs etc on the 990 frame for sensors and such you wont find on the 950.
Can it be done, sure but to do it properly you most likely would need the entire wiring harness from a 990 to swap for the 950. Then it becomes a matter of finding space for it all and plugging it all up. Also there are smaller diff like airbox covers have stuff in the 990 not on the 950 etc.
I went to carbs on my 990 and the harness was much simpler on the 950.
Then you have the matter of the EFI fuel pump. Where ya gonna stick that sucker since it go INTO the tank.
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 11-02-2012, 10:16 AM   #3
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 908
Swap tanks!
but then again, converting a 950 to EFI... what for?
690R
Old 11-02-2012, 10:28 AM   #4
Yardstick OP
Hydrophobic
Yardstick's Avatar
Oddometer: 3,059
There are high pressure EFI pumps that can be mounted external to a tank. That's one of the lesser worries.
I assume it would take the EFI portion of the wiring harness and associated ECU from a 990. What about the fit? Are the intakes the same size? I know the 990 uses different air filters.
I have both right now ('09 SE and '11 990R) and I could try some fitting, but I was hoping somebody else had done it already and could enlighten me. I like the EFI on the 990 and would prefer to have EFI on the 950.
Old 11-02-2012, 11:08 AM   #5
LukasM
Oddometer: 5,418
Didn't PowerCell do an EFI conversion on his monster bike?
Old 11-02-2012, 11:38 AM   #6
Yardstick OP
Hydrophobic
Yardstick's Avatar
Oddometer: 3,059
I think he has a 990 motor in his. Tempting but my 950 has really low miles.
Old 11-02-2012, 11:38 AM   #7
KTMADV
Hammer Down
KTMADV's Avatar
Oddometer: 174
It is easy to make a ktm 990 adventure to carbs. I just got done if anybody needs info on it or what parts are needed just ask .I have all the parts off my 2007 ktm 990 adventure that I dont need.
Ceasar Vasquez
KTMADV screwed with this post 11-02-2012 at 10:31 PM
KTMADV is offline   Reply With Quote
Times are GMT -7.   It's 02:01 PM.
