Go Back   ADVrider > Riding > Regional forums > Alaska
Old 11-03-2012, 09:15 AM   #1
Steve907AK OP
Obsessed
Steve907AK's Avatar
Oddometer: 50
New to me 2010 R1200GSA, need help!!!
Greetings to all!! This is my first post on this forum, but I've been reading it for about two months now. It's driving me nuts now that the weather is getting colder. The more I read, the more I realize what I don't know. But there's one thing that's really bothering me....just had my 12K service and 20W/50 was put in my engine and 75W/140 was put in my tranny and final drive. Now I'm no BMW mechanic or anything, but in my earlier years would consider myself somewhat of a gear head. I've built a few small block Chevy engines, transmissions and differentials, in fact, put together vehicles starting with a frame only.
That being said, it appears to me that what the dealer used (had dealer do 12k service for warranty purposes), is not what would make any sense to me.. Why 20W/50 in the engine? This is fall in Alaska. Why 75W/140???
I am really confused. I called BMWNA. They said they can't recommend oil weight, the dealer uses their discretion.
I then called some dealers in the lower 48. They appear to be using 10 or 15W/40 and everyone I talked to appears to be using 75W90 in the final drive.
I need help because I have no problem riding in 25-30 deg weather as long as the streets are clear and dry.
I noticed my engine ticks for 45 seconds or so after turned off in for a bit in these temperatures. It didn't do this when I first changed it a week or so after I bought it in August.
Any good insight out there??
Steve907AK is offline   Reply With Quote
Old 11-03-2012, 09:43 AM   #2
KHuddy
Big Sky Country
KHuddy's Avatar
Oddometer: 2,869
Read the owner's manual......
Were it my bike I would have prefered 10W 40 oil in the engine, however if you look at the chart in your owner's manual I'm betting that 20W 50 oil is okay in the temperature range you can expect to see in Anchorage (That is where BMW recommends oil types for various operating temps). In any case it will not harm the bike.
Transmission spec is 850 ml of 75W 140 or 75W 90 GL5 rated synthetic oil. I would opt for the 75W 140 since it provdes a broader temperature range.
Final drive spec is 180 ml of 75W 90 GL5 synthetic oil for R1200s 05-09. You should again check the owner's manual to see what oil is recommended in your final drive. The 75W 90 oil is recommended for the 05-09 hexheads, but maybe they went to 75W 140 for your year. If you have a vented final drive, then the amount of oil in the FD is likely 230 ml.
The ticking you are hearing is likely the result of cooling metal as the engine, or more likely the exhaust system, cools.
Don't think you have anything to worry about.
Kevin
KHuddy is online now   Reply With Quote
Old 11-03-2012, 12:14 PM   #3
Alcan Rider
Frozen Fossil
Alcan Rider's Avatar
Oddometer: 3,977
Have never owned a BMW so claim next to zero knowledge of the beasts, but... my shaft drive bikes do fine with 75W-90 synthetic in the final drives year around, in all climates. Likewise, the liquid-cooled ones (except for the KLR) survive very well on a diet of 5W-30 synthetic here in Alaska, 5W-40 synthetic Diesel motor oil when I'm traveling into hot climates. During summer, the KLR gets treated to 15W-50, but no way would I ask it to handle anything heavier than 10W-30 in colder weather. Initial lubricant flow when an engine is first started is critical, as more wear happens in a cold engine than after it has reached full operating temperature. Modern synthetic motor oils have a film strength that is vastly superior to the oils of a few decades ago, and lighter oils protect from wear better than in the past, while also flowing more freely. That is why some auto manufacturers are even recommending 0W-20/30 oils for cold climates.
"I am in the prime of senility." Ben Franklin
I'm so old I remember when the gallons rose faster than the dollars on gas pumps.
The Lure of the Dalton, The Lure of the Dempster, Haul Road Chronicles, My Evening Rides, Alaska Primer
Haul Road Primer
Alcan Rider is offline   Reply With Quote
Old 11-03-2012, 12:53 PM   #4
Steve907AK OP
Obsessed
Steve907AK's Avatar
Oddometer: 50
Clarification on "ticking"
On my first post I said with the 20W/50 engine oil, the engine "ticks" for about 30 seconds or so after turning off". I MEANT after starting it up after cooling off for a bit. Like the valve train doesn't get oil right away because it's too thick...??
Old 11-03-2012, 06:12 PM   #5
Drunk_Uncle
Drunk_Uncle's Avatar
Oddometer: 2,234
I thought boxers sounding starved of oil at start up was normal.
"I refuse to tiptoe through life only to arrive safely at death" '13 Tiger 800XC, '14 Street Triple, '00 KLR 650(finished project), and 2010 Honda NT700V wife's.
Drunk_Uncle is offline   Reply With Quote
Old 11-03-2012, 06:42 PM   #6
Juvat
Juvat's Avatar
Oddometer: 695
Steve,
I have an 09 I live in Wasilla and just went riding today with no problems. I run the recommended 20W50 with no problems at all. I have also rode in temps as low as 10 deg without any bike problems at all. Don't worry about it and ride on
Juvat is offline   Reply With Quote
Old 11-03-2012, 09:44 PM   #7
ThatGuy
Brownie
ThatGuy's Avatar
Oddometer: 5,095
Mee thinks your shizz is all fugged up! Wheel it to my house and ill give you $50 for salvage.
Disclaimer: The writer does not represent any organization, employer, entity or other individual. The views expressed are those only of the writer. In the case of a sarcastic, facetious, nonsensical, stirring-the-pot, controversial or devil's advocate-type post, the views expressed may not even reflect those of the writer.
ThatGuy is offline   Reply With Quote
Old 11-04-2012, 07:21 AM   #8
Steve907AK OP
Obsessed
Steve907AK's Avatar
Oddometer: 50
Thanks for the help!
Originally Posted by Juvat View Post
Steve,
Juvat: Thanks for the input. I'm just going to ride it for now. In fact, I'm thinking about a ride today. I also live in Wasilla. If your interested in a quick trip today shoot me a text or call: 982-6133.
Old 11-04-2012, 03:58 PM   #9
Juvat
Juvat's Avatar
Oddometer: 695
Sorry, didn't get the message till just now. I hope you had a chance to get out!
Old 11-10-2012, 01:24 PM   #10
Brendon@TMS
The Motorcycle Shop
Oddometer: 271
Hey Steve!
Those oil specs are what BMW calls for per their maintenance recommendations, however, if you're wanting another type of oil, we're happy to do accommodate!
We've been using 20w50 in the boxers for years, haven't had any issues whatsoever. Same with the final drive stuff.
The ticking on startup is normal, as the bike sits on a sidestand or centerstand, oil drains out of the head into the sump. Takes a few secs for the oil to get pumped back into the head. Totally normal, no cause for concern. If you like I'm happy to put an ear to it if that will help too. After your 12k service, if anything was out of spec it would have been readily apparent.
Your logic is sound regarding oil weights, most of my customers who ride their dirt bikes in the winter use lighter weight oil in the very low temps due to reciprocating drag, but that's an exception and you probably won't be riding your bike when it's below zero.
Anything else please ask away, hope I can help!
Brendon Gallant General Manager
The Motorcycle Shop 400 W. Potter Dr.
Anchorage, AK 907.561.1165
www.themotorcycleshop.com
brendon@themotorcycleshop.com
Brendon@TMS is offline   Reply With Quote
Old 11-14-2012, 04:50 AM   #11
Boulder Ed
Bin Ridin
Boulder Ed's Avatar
Oddometer: 962
For the record
The 75-140 is not recommended for R1200 FD's. Apparently under certain circumstances it cannot maintain it's presence under rapid loading like AK chuckholes for example. It is too thick. That said I have run it quite a bit in both R1200's. The official BMW recommended volume has now been reduced to 180cc vs. 220 as well. Most are settling for around 200cc. This is because the dip$*%*$ at BMW got cheap and did not vent the FD until this year, and it becomes a pressure vessel, blowing out seals, and destroying FD units from lack of oil. Yes, it's vented again now, and even has a drain plug too, starting 2008! Cost saving in all the wrong places. I've heard mine pop and release the pressure when I pulled the plug. 65,000 miles though and no FD failures.
Ed
Bin Ridin
"Terrorizing small animals on the road since 1971"
Boulder Ed is offline   Reply With Quote
Old 11-14-2012, 01:57 PM   #12
friar mike
IronButtGruver
friar mike's Avatar
Oddometer: 4,908
You know I love my BMW but it is just unbelievable the crap I have to tell customers as I work on these things and I will never own a 1200gs my 1150gs maybe big and heavy but it just doesn't have the problems. I would like to know what the hell happened to BMWs research and development and more over there engineers there is no real world work going on before they sell theses things to the consumers
We,re on a mission from God. "blues brothers"
Don't go up there someone's going to die. "Walter"
A world without string is chaos
Good-Bad-Iam the guy with the gun "evil dead"
God's speed Rommel run free my dog
friar mike screwed with this post 11-14-2012 at 02:04 PM
friar mike is offline   Reply With Quote
Old 11-14-2012, 04:51 PM   #13
Brendon@TMS
The Motorcycle Shop
Oddometer: 271
Oh boy a "1150 vs 1200" thread! Are we in 2005 again?
I've never seen so many people be so happy with this alleged piece of "crap." There were teething problems to work through that every model of every brand has to work through, but on the whole it's a fantastic bike, just as the 1150 was fantastic.
Different strokes for different folks.
And Steve,
Were you able to get sorted out? Again, drop me a line if you need anything!
Old 11-14-2012, 06:00 PM   #14
friar mike
IronButtGruver
friar mike's Avatar
Oddometer: 4,908
Brendon it is what it is from it ABS to it rear end and it troublesome I work on them I know now the new 800s I just haven't seen them in for so many troubles and stranding riders like the 1200 has. The 1150 has rear end bearing troubles too but nothing like the 1200 and we won't even start on the electronic problems and you know it. Iam not here to bash the 1200 they are loved by lots of riders but facts are facts.
Old 11-15-2012, 10:38 AM   #15
Brendon@TMS
The Motorcycle Shop
Oddometer: 271
Those aren't facts, they're your opinions.
Numerical/quantitative evidence and a statistical analysis of events showing a trend that one model has more instances of warranty induced repair would help bolster your claim.
Agree to strongly disagree.
Times are GMT -7.   It's 08:35 AM.
