11-03-2012, 11:03 AM
#1 |
Oddometer: 472
Replacing Top Triple Clamp on 2007 990
I found this thread to remove and transfer the ignition: http://www.advrider.com/forums/showt...light=ignition
...but I am wondering how to remove the two pieces that the handlebars rest on. Any pointers?
not all those who wander are lost | two earthlings ride around the world Home | Photo Blog | The Route | The Bike | About Us | Participate! |
11-03-2012, 11:27 AM
#2 |
High Plains Drifter
Oddometer: 733
dude
make sure you dont bite off more than you can chew.
you can remove the top triple with everything attached. The two towers that hold the handle bars can be remove once the handle bars or off. There is a nut on the underside of the clamps that will release the towers. Remove handle bars and you will see the other bolt head |
11-03-2012, 11:31 AM
#3 |
High Plains Drifter
Oddometer: 733
this might help
11-03-2012, 11:37 AM
#4 |
Oddometer: 4,939
Nothing tricky to it Rocky.
Remove the 4 bolts that hold the upper halves of the handlebar mounts, lift off the handlebars, then you will have access to to the 2x M10 bolts that hold down the lower halves. Should be a 5 or 6mm hex I think. Hold the bolts from the top, remove the nut on the bottom side, and you are done.
Proud member of the HUSABERG ADVENTURE TEAM! '12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6 |
11-03-2012, 12:04 PM
#5 | |
Oddometer: 472
I have the triple clamps off. Don't see a way of removing those top pieces, unless they just pull apart once removed. ![]()
11-03-2012, 12:06 PM
#6 |
Oddometer: 472
Hey Lukas! About to finally put together the forks that you sent me!
11-03-2012, 12:19 PM
#7 | |
Oddometer: 4,939
There is a small metal tube inside those rubber bushings, if you knock it out then they will come apart, and you can just pull out the top one and the bottom separately. They are not one piece, and the metal thing on the bottom is just a cover so that the nut doesn't tighten directly against the soft(ish) rubber.
11-03-2012, 05:49 PM
#8 |
Oddometer: 472
thank you, that worked. how do i take the rubber dampener out? just tap it?
11-03-2012, 05:52 PM
#9 |
Oddometer: 4,939
Yeah just use some kind of driver that fits through the hole and tap on it from the opposite side, just like you would tap out a wheel bearing.
11-04-2012, 08:59 AM
#10 |
Oddometer: 472
OK...that was easy. I guess I should have looked at the assembly diagram (patrs 8, 9 & 10):
![]() Going to be tacking the entire fork assembly today. I got stuck on that damn air box for so long yesterday. I usually have Paula and her small hands around to help out with the clamps and throttle cables, but I had to struggle with them myself yesterday. I'll have to check through all my parts, but I am not sure that I received a new o-ring support (part 17). If not, can I reuse the old one, or should I wait and order a new one? Any other pointers on the fork assembly? I found this video on the HOW which seems really informative: http://www.ktm950.info/how/Orange%20...97&postcount=1
11-04-2012, 09:08 AM
#11 |
Oddometer: 4,939
If you have access to a hydraulic press you can just press out the stem from your old lower triple without damaging the seal that the lower bearings sits on, then it's not a problem to reuse it.
If you remove it with a puller it will be hard to keep it in good shape due to the interference fit of the lower bearing and because the seal will prevent your puller from getting a bite on the edge. I've got about ten of those here and you'd be welcome to have one, but I'm afraid it won't get to you any quicker than if you order locally...
11-04-2012, 09:32 AM
#12 |
Oddometer: 472
No hydraulic press here.
I was sure that I did order a new one. I have two new bearings (upper and lower), new stem, etc. Maybe the seal is sitting at the bottom of a box. I'll have to take a look. If I didn't order one, I should be able to pick one of these up at the local dual sport shop. These seals are standard/common parts, aren't they, or are they specific to these bikes? My general plan is to assemble the bearings, stem and triple clamp onto the bike. If I do this first, will I then be able to insert the fork legs from the bottom? This is my first time doing this, so I'm not sure about the best plan of action. Thanks for all your help. If all goes well and the bike starts up after the rebuild, we hope to be somewhere in Europe by next summer.
11-04-2012, 09:43 AM
#13 |
Oddometer: 4,939
Not sure if you will find the seals at a local bike shop, they are specific to this size bearing which probably not a lot of other bikes have (all KTMs do however). Maybe an industrial or bearing supplier?
Is the new stem already in the lower clamp? You will definitely need a hydraulic press for that. The lower bearing can be softly hammered on by using a tube that just fits over the stem but is small enough to only contact the inner part of the bearing so that it doesn't get damaged. When that is done and you have replaced both cups in the frame, grease up both bearings, slide the lower triple in from the bottom, put the upper bearing in on the stem, then the metal cover with the rubber O-ring inside, then the upper triple, and then the top nut to hold everything together. The manual should have instructions on how to get the correct torque / preload on the bearings. Once the triples are held together then you can slide in the fork tubes one by one. Definitely let me know when you make it to Austria and I'll set you up with a garage and a place to crash.
11-05-2012, 08:48 AM
#14 |
Life is a trip
Oddometer: 3,199
I replaced my 2006 fork legs with 2004 taller ones.
Or at least that was the initial plan. What we found out was the ID of the triple clamps has changed on 990 models, so we had to exchange all inner parts, keeping outside of the legs OEM. So in case you collected pieces from different year bikes, be warned.
Cheers.
There is always a reason!! |
11-05-2012, 09:01 AM
#15 | |
Oddometer: 4,939
What measurements did you get?
