11-03-2012, 02:47 PM
#1 |
Oddometer: 1,089
Shock Pre-Load Adjuster Oil
Looking for the amount and type of oil that can be used for '07 990A
Richard
Keep it Wild, Keep it Free '07 990A Parting '98 1100GS. Need Anything? |
11-04-2012, 01:06 AM
#2 |
Oddometer: 1,032
The preload adjuster is mechanical....
the shock body has oil in it, that has to be bled and refilled on a proper suspension rig to get all the air bubbles out. Good KTM dealers and WP agents have the rig. |
11-04-2012, 05:05 AM
#3 |
I love sand !!!
Oddometer: 2,575
I thought its only the SE which has the mechanical pre-load adjuster screw and the adjuster (with the turn - handle) on the Adv are hydraulic ?
'07 KTM Adv990S No myriad hues of laser lights no bottles that are oozing with nectars from heaven, no beautiful body soft and warm to the touch but, i have a very small desire.. Give me a dark.. long.. winding road, three gears to go and my Hellas on fire.. 950Rally picture thread |
11-04-2012, 07:05 AM
#4 |
Oddometer: 1,089
The pre load adjuster mechanism does (or did on mine) have oil in it.
11-04-2012, 08:49 AM
#5 |
Oddometer: 1,032
Really? Why the hell do they make it so complicated? I am please I did not try removing the movable part to clean under it!
11-26-2012, 06:09 PM
#6 |
suspension guy
Oddometer: 167
Hydraulic preload Adjuster
We use shock oil. Ohlins 1309-01 in our case.
The amount is more difficult to say as the process of bleeding the air out is complicated. Sufficient oil to move the spring seat through the full range. Less than 400cc is easily enough. The large O ring seal gets dirty and fails on those. Sometimes the pivot bolt backs out as well. Cheers James
www.superplushsuspension.com Never argue with stupid people, they will drag you down to their level and beat you with experience. |
