Old 11-04-2012, 08:34 AM   #1
Moto Mikey OP
Moto Mikey's Avatar
Oddometer: 456
Bleeding brakes with ABS equipped F800GS
I got a Speigler extended brake line for my F800GS and plan on installing it this weekend. How do I go about bleeding the brakes if I have ABS? Is there a special procedure or is it just like a normal bike?
Moto Mikey is offline   Reply With Quote
Old 11-04-2012, 08:39 AM   #2
Motorfiets
Motorfiets's Avatar
Location: North of Jack Daniel's, South of Country Music
Oddometer: 2,997
normal... I have however spoken to one individual who needed to leave his key on to allow the abs pump to operate to properly bleed the brakes
Motorfiets is offline   Reply With Quote
Old 11-04-2012, 09:53 AM   #3
Reaver
Outta Here
Reaver's Avatar
Oddometer: 4,352
+ 1 on the Normal.
If you don't introduce air upstream, then it's easy. I was involved in countless brake line changes on the R12GS's for warranty. A batch of lines cracked and were replaced. Then the new ones cracked, then.......anyways, I've done plenty of ABS and non without any issue. I believe Motorfiets was talking about "Servo" brakes that are on some older R12's and K bikes. We can't make our ABS pumps run without the BMW computer attatched so disregard since it doesn't apply here. Just clarifying, all due respect. Servo brakes are a major PITA to service and I've said many a word in "praise" of the designers.
HINT: pull the front brake, bleed off the pressure with a nipple till the handle touches the grip and cable tie it that way. With the brake handle fully actuated this way, the port in the master cylinder will be covered preventing the brake fluid from siphoning down through the system. You can remove a brake line and it won't drip from upstream. When all is reinstalled, bleed the air from the nearest caliper hydraulically speaking to remove the air. Then go to the other caliper and bleed but you probably won't see any air if all went well. Don't let the reservoir get low!!!! Get a good feel for your brakes before you start then compare after. I've replace dozens of lines without spilling a drop of brake fluid. Turn the bars full left so the reservoir is the highest in the system when bleeding and only bleed from that tiny nipple on the reservoir if you have to. Remember it's tiny and weak, don't snap it off.
Have fun.
Leaving it all behind 2014
Pura Vida my Ass.
Reaver is offline   Reply With Quote
Old 11-04-2012, 10:16 AM   #4
Moto Mikey OP
Moto Mikey's Avatar
Oddometer: 456
Originally Posted by Reaver View Post
+ 1 on the Normal.
Have fun.
Awesome, thanks. Gonna do it today.
Old 11-04-2012, 03:32 PM   #5
Moto Mikey OP
Moto Mikey's Avatar
Oddometer: 456
New line installed. Brake bleeding process was very easy. Thanks.
Old 11-04-2012, 07:08 PM   #6
Reaver
Outta Here
Reaver's Avatar
Oddometer: 4,352
Did you get a test ride or is it a wee bit chilly up there?
Happy to give back when I can.
Pura Vida my Ass.
Old 11-04-2012, 08:33 PM   #7
Moto Mikey OP
Moto Mikey's Avatar
Oddometer: 456
lol, too cold and there's snow/ice on the roads
Times are GMT -7.   It's 04:25 PM.
