Old 11-04-2012, 04:35 PM   #1
Sutherngintelmen OP
on the mend
Sutherngintelmen's Avatar
Oddometer: 977
Mystery Power Outage 84 R80
I put a new battery in this bike about 1,000 miles ago - Odyssey AGM.
I bought the bike recently and batt that came with quit on me a few hundred miles into custody. Good news is I was at the house when it Jumped it off, hooked up and verified charging at 14v so decided that it sat too many MI winters untended and replaced.
No warning yesterday 7 hours into an 8 hour ride bike stalled when I closed the throttle coming to a stop sign. I'd been riding some of our sportier two lane roads for 45 mins, not lugging along. There wasn't a drop of juice in the thing - I mean flat. About 10mins before stop, gps started 'lost external power' which I thought was jiggle but turns out I was below voltage spec. Idiot light is operational but never chose to glow.
Given some of the NGA goat trails I'd enjoyed, the interruption could have been much more of a pain in arse. Connections good. Kick start turned it over but no ignite. So the sun was going down and this town was closed except for Awesome Bill's Pool Hall, eateries and gas n go. Nearest source for new 12v was a big box 10 miles away so I found a wrecker and waited a few hours.
Was running PIAA 510s for some of the day + head lamp ~ 165 watts.
Gave it a 2 hours of 6amp charge back at the house and cranked right up.
Service manual says charge should be 14v making 280w / 20 amps with charging starting at 980 rpm. Regulator spec'd to deliver 13.5 to 14.2 at 5,000 RPM.
Observations this morning - batt at rest 12.85v, 900 rpm 12.5v. Climbs to 14v by 2250 rpm and maintains to 6,000 rpm.
Possible that regulator or diode has an issue with heat / use?
Pics
Day time fun - top of Hawk Mountain
Sun gone down
Juice for battery, a couple of bourbons and fires up.
Idle this morning
With revs
It did get up to 14.1, just below when I snapped pic.
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding.
All posted pics < 6/30/12 deleted courtesy of Apple
Sutherngintelmen screwed with this post 11-04-2012 at 07:08 PM Reason: english
Sutherngintelmen is offline   Reply With Quote
Old 11-04-2012, 05:32 PM   #2
hardwaregrrl
Shit for brains
hardwaregrrl's Avatar
Oddometer: 4,865
Did you test it under load? Shouldn't drop below 10 when starting. I have an known good extra battery if you want to swap it in.
Old 11-04-2012, 06:35 PM   #3
Sutherngintelmen OP
on the mend
Oddometer: 977
Thanks, Jenna. Forgot to mention that measure at crank was around 11v. Strong today but I will have a back up on board next weekend. Might be bad batt, in town this week so will be keeping an eye on it.
And....
Been thinking I should cary a bivy kit. Haven't had an unplanned woods night though I cary enough for most weather situations. Would be nice to have some comforts in case it's simpler to build a fire and see the next day.
Add: nylon tarp for burrito wrap sleeping, 8oz bourbon to assist tarp, 1 tin sardines for dinner. 2 lbs comfort
Old 11-04-2012, 07:33 PM   #4
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 3,879
I'd vote for a bad connection somewhere. Batteries don't (usually) go ABM-dead and then recover. Your charge put 12 AH (amp-hours) in a 28 AH battery, not nearly a half charge (43%).
165W of lighting on a 280W alternator should not have affected it so catastrophically, but of the charging system is marginal, it might not be able to keep up. I like LED lights for conspicuity lighting, I save the Halogens lamps for nightime.
http://www.advrider.com/forums/showthread.php?t=586134
An on-board voltmeter is a good thing to have. I like the Kuryakin LED bar-graph meter.
http://www.kuryakyn.com/Products/872/LED-Battery-Gauge
--Bill
'73 R60/5 Toaster
Old 11-05-2012, 08:36 AM   #5
Sutherngintelmen OP
on the mend
Oddometer: 977
--Bill
I'll take a closer look at connections, just checked to batt maybe there's a bad one elsewhere.
Battery was holding 12.85v this morning. I am delivering another 3 hours of 6 amps to top off. I like LEDs too, but these PIAA's 'look' right on this bike - not so much if it's on a tilt bed though.
I guess I could always upgrade
Thanks for pointers
Old 11-05-2012, 08:49 AM   #6
Bill Harris
Oddometer: 3,879
Remember, the open-circuit ("resting") voltage of a lead-acid battery is an indicator of the state of charge. The 12.85V you measure is close to 100% charge.
And once you get down to 12V, it's at half charge.
--Bill
'73 R60/5 Toaster
Old 11-05-2012, 09:36 AM   #7
SOLO LOBO
airhead or nothing
SOLO LOBO's Avatar
Oddometer: 7,934
I had a rotor that would fail upon reaching operatin temp, but worked and measured fine when cold... that was fun to diagnose!
"punkrocks what it's all about" - J. Strummer
SOLO LOBO is offline   Reply With Quote
Old 11-05-2012, 10:32 AM   #8
RecycledRS
Along for the ride
RecycledRS's Avatar
Oddometer: 912
I think it could just be that the lighting load and the ignition load were too much for the output of the alternator given the type of riding you were doing.
The combined loads would be well into the 200 watt range and given that the 240 watt output the alternator is rated at is at over 3500 rpm. Your idle rpm should also be around 1150 rpm so that you are not discharging the battery while idling.
__________________________________________
"There's a fine line between a skinning and a shearing"
RecycledRS is offline   Reply With Quote
Old 11-06-2012, 05:05 PM   #9
Sutherngintelmen OP
on the mend
Oddometer: 977
I found it! Well, a friend of mine found it. Or at least the problem is on here somewhere.
I kinda of feel like it may have been the riding I was doing except when I think about it. Most of day was 2nd/3rd gear gravel, 1st gear for some sections (not a whole lot of time - for those in this neck of the woods: climb from Old Bucktown to Camp Amicalola, last pitch of Hawk Mt and Flatland Rd.) Maybe 30 mins all in with Flatland being the bulk and at the end.
I started the day with slab then 2 lane, had a couple of short transits then rode 60 from Cooper's Creek then 9 south to Awesomeville - this is 45 mins revved up curvaceous delight. I run the PIAA on tarmac only - except when I forget - fairly often. Revs would have been above 3k almost all day which shows charge of 14v when it's in the shed.
Shouldn't have been enough lug drain to strand me.
Battery is holding charge at 13.05 volts after I gave it second bump of 6 amps. I'm planning on some time Thursday eve to id bad connections. Wish I could rig multi meter to batt for Sat ride - might give it a shot.
Where's Waldo!!
Sutherngintelmen screwed with this post 11-06-2012 at 05:19 PM
Old 11-06-2012, 05:31 PM   #10
hardwaregrrl
Shit for brains
Oddometer: 4,865
Nice area to ride!! Big thumbs on Flatland. I agree with Bill that an onboard Voltmeter is the way to go. Here's a nice one from an inmate. I have a Stock Rotor if you would like to swap it in and test. Like SOLO mentioned, it was hard to diagnose.
Where's Waldo!!
Old 11-07-2012, 03:52 AM   #11
Sutherngintelmen OP
on the mend
Oddometer: 977
Thanks, Jenna That's really nice and I might take you up on it
How do you diagnose this as an issue? Was it trial and error? Replace parts until the problem goes away or can I make a definitive determination somehow?
Some good reading on bmwmotorcycletech Probably written by one of you guys.
Am going to order up that voltmeter - very good sense.
And to Flatland - love that stretch. So much fun. Was interesting Saturday as blanket of fresh leaves made for moments of wonder.
Old 11-07-2012, 04:53 AM   #12
hardwaregrrl
Shit for brains
Oddometer: 4,865
Like SOLO said, he had a difficult time diagnosing the rotor issue since it only happened once heated up. Usually you can test the rotor across the slip rings, but you can also get a rotor that only throw the OL code when hot. Most people aren't going to test their rotor when the engine is hot after a ride. Do you have a charging bible? You should get one, or borrow and copy mine... Rick's gonna kill me. Check your brushes, shouldn't be shorter than 7mm I think, then slip a piece of paper under them to get them off the rotor slip rings. Then test the slip rings, if you have a stock system (which sound like you do) should read around 3 ohms. I can't remember what year your bike is, it matters as to what the rotor will read. Googlefu that crap.
Old 11-07-2012, 06:32 AM   #13
Airhead Wrangler
More tacos than you
Airhead Wrangler's Avatar
Oddometer: 5,103
... then 9 south to Awesomeville ...
There's really a town called Awesomeville? That's... um.... awesome.
R80ST Gets The HPN Treatment
Ducati Pantah 500SL Rebuild
Seattle to TDF on an airhead
WTB R100R Mystic sidestand and mount.
Airhead Wrangler is online now   Reply With Quote
Old 11-07-2012, 06:45 AM   #14
Bill Harris
Oddometer: 3,879
Shoot no, WE don'ts write like that...
'73 R60/5 Toaster
Old 11-07-2012, 05:05 PM   #15
Sutherngintelmen OP
on the mend
Oddometer: 977
Linky like bike. I tried search for 'charging bible' et varietals but apparently there are fewer interested in mc electrics than the other mystery, or google is having a bad day.
Battery is still holding 13.05V
I'm riding Saturday fix or no. I've got one of those new weigh nothing batts that I'm pulling out of another bike (bought before Joel did his Shorai Adv Batt Test) as a back up. Signed up for a AAA membership (that was a very expensive hook last Saturday. ) and just a very few perfect Fall days to ride before Winter wet sets in.
No PIAA's will be lit during this exercise. If I kill the AGM will swap and run for the shed. I may not be the best decision maker but I'm consistent. Be a test anyway.
Times are GMT -7.   It's 07:32 AM.
