Old 10-30-2013, 10:07 AM   #586
Off Road Ryder OP
Off Road Ryder's Avatar
Oddometer: 2,540
Long Range Extreme now available
The longest throw LED light you can put on a bike is now available.
The only auxiliary light available with the SST90 25 watt single emitter, offering smoother light patterns and unequalled distance.
http://www.cyclopsadventuresports.com/Long-Range-Extreme-LED-Light_p_61.html
Our 24 hr team all ran these last weekend, a set of these blows away an 8" HID race light. We had by far the best lights on the course.
Now you can have race quality lights on your Adventure or street bike, You wont have to worry about overrunning your lights and the beam offers plenty of fill.
No marketing BS, No fancy names, just strait shooting and honesty.
They will work with a skeene or other type of dimmer.
When Quality matters,Its all about choices.
Cyclops Performance LED Vendors thread
http://advrider.com/forums/showthread.php?t=839163
1-800-624-0278
Off Road Ryder is offline   Reply With Quote
Old 10-30-2013, 10:33 AM   #587
WRThumper
WRThumper's Avatar
Oddometer: 48
Ok, so what does the "Euro" filter do?
"We're surrounded ...
that simplifies our problem." Lewis B. Puller
WRThumper is offline   Reply With Quote
Old 10-30-2013, 11:21 AM   #588
michigan400
Oddometer: 90
I like the look of them on that 690!! (I think it's a 690.) The double set up in the regular headlight position.
What is the weight like compared to the typical dual 4" HID set ups you see like that? Is the weight very noticeable on the bars?
michigan400 is online now   Reply With Quote
Old 10-30-2013, 11:37 AM   #589
Off Road Ryder OP
Oddometer: 2,540
The euro filter makes an elliptical beam pattern. spreading the light out more to the sides
We are still working on beam shots for all the lights, Its a lot harder than one would think.
1-800-624-0278
Old 10-30-2013, 11:41 AM   #590
Off Road Ryder OP
Oddometer: 2,540
950 SE we race the big boys.
That's our new extreme race light. Watch the Baja 1K coverage coming up soon and you should see several. It weighs in at just under 5 lbs
slightly lighter than an 8" HID and a whole lot more usable light, in both distance and fill.
a street version is also on the way.
1-800-624-0278
Old 10-30-2013, 09:33 PM   #591
WRThumper
WRThumper's Avatar
Oddometer: 48
Thank you!
Old 11-01-2013, 02:15 PM   #592
ohgood
ohgood's Avatar
Oddometer: 2,731
Quoted so I won't miss anything.
Do you have done nighttime throw shots of it ?
Yes, Android AND iphone GPS works without cellular data. Use offline maps and enjoy. (thanks drtbyk!)
ohgood is offline   Reply With Quote
Old 11-01-2013, 05:06 PM   #593
Off Road Ryder OP
Oddometer: 2,540
I'm working on getting good shots, I don't know if this will work, but here is a customer provided video of our new Extreme race light that uses the same lights but in a dirt bike style aluminum race frame. Video usually does not do lights justice, as in this case, but you might get an idea.
The reports on these lights from experienced off road racers, usually using 8" HIDs has been phenomenal.
https://www.facebook.com/photo.php?v=10201719756068977
1-800-624-0278
Old 11-01-2013, 07:08 PM   #594
ohgood
ohgood's Avatar
Oddometer: 2,731
Thanks for the reply, but please, whatever pictures and videos you have, host them anywhere but Facebook, OK ?
Old 11-01-2013, 08:18 PM   #595
Wreckluse
Will work for beer
Wreckluse's Avatar
Oddometer: 444
I am interested in your "LONG RANGE DUAL LED AUXILIARY LIGHT - Part Number CIL-210kit"
I only need 1 fixture with the two led's, a harness and a dimmer assembly.
What is included in the kit for $459.95?
thanks
Doug
Indecision is the key to flexibility.
07 950 SM R
09 450 EXC dual sport
08 DRZ 400 SM Adventure
12 GasGas 250 Pro
Wreckluse is offline   Reply With Quote
Old 11-02-2013, 08:51 AM   #596
Off Road Ryder OP
Oddometer: 2,540
Will do, it is the only footage we have at the moment.
1-800-624-0278
Old 11-02-2013, 08:54 AM   #597
Off Road Ryder OP
Oddometer: 2,540
thanks
Doug
HI Doug
I can set you up with a single, the kit is a two light set, with no dimmer. Usually those lights end up on Semi's or large equipment where no dimming is required.
It would be a custom order with the dimmer, and a single light, please pm me for specifics.
1-800-624-0278
Old 11-04-2013, 08:10 AM   #598
Off Road Ryder OP
Oddometer: 2,540
New Extreme LED Race light
1-800-624-0278
Old 11-06-2013, 10:02 AM   #599
Off Road Ryder OP
Oddometer: 2,540
Thanks!!
We sold out of the first round of Extreme Long Range lights in record time.
Thank you ADV members! a new batch will be available early December, most likely around the 6th.
Now that there are a bunch out there, How about some reviews?
I know nothing else comes close, but others need to hear it from you.
1-800-624-0278
Old 11-06-2013, 10:50 AM   #600
bitwrench
ADV SUMO
bitwrench's Avatar
Oddometer: 204
How will the street version differ? I'm looking for a single light with a wide beam for use as my lowbeam, possibly with a dimmer.
Thanks,
Jackson
bitwrench is offline   Reply With Quote
Times are GMT -7.   It's 08:20 AM.
