11-06-2012, 11:39 AM
#16 | |
Location: Berkshire, England. Just off the Beaten Track!
Oddometer: 2,556
11-06-2012, 11:48 AM
#17 |
Oddometer: 3,733
11-06-2012, 04:22 PM
#18 |
Mercury Freefall
Oddometer: 53
Doesn't the motor sit lower in the R65? I just wonder about dragging the valve covers. The R80 motor will be wider, but I don't know if it's enuf to matter.
I ride with a short guy occasionally who rides an R65/80. It gets his tip-toes on the ground but it seems to drag hard parts before my /5 does.
Adventure is when everything goes wrong. That's when the adventure starts. - Yvon Chouinard |
11-06-2012, 11:01 PM
#19 | |
Von Hochstaden's son
Oddometer: 44,959
i am weary of leaving my r80 unnatended now
mikuni vm32-33 both sides :\ 5000 feet altitude/ 140 main \ 159 02 needle jet\ 6F4 needle in the middle setting\ 0.5 air jet\ pilot 25/3.0 slide 35 mpg around town riding like a asno |
11-14-2012, 10:57 AM
#20 |
De Oppresso Liber
Oddometer: 30,297
I don't have a motor yet, but am on the lookout for a cheap one that hasn't been molested. It is a long term down the road project, but I really want to do it. Maybe I'll get lucky and find a cherry R65LS in trade for my 1973 CB350F....
or some other nice Airhead....
"I claim to be frightened of horses but do so only to get out of attending parades. It's peculiar but ...it works. The Horses get it. RESISTANCE IS NOT FUTILE. IT'S VOLTAGE DIVIDED BY CURRENT |
#21 |
De Oppresso Liber
Oddometer: 30,297
After the carbys went on, you should be!
11-14-2012, 11:26 AM
#22 |
because I can
Oddometer: 6,045
A R80 engine will bolt right in. The exhaust won't work but the R80 exhaust can work with some setup. Don't plan on cornering very hard. Twin shock R65's are a LOT lower than the other models and those longer cylinders stick out like wings (or road hooks depending on the situation). I have setup a few 850 kits like wireworker has. They are savage. It involves modifying the R65 engine into a super short stroker. The cylinders are bored out so far that the nothing but the fins are left on a good portion of them until you put the liners in. The liners rust were they are exposed. Talk about cylinder wall instability! I did it because it was my job but I wouldn't recommend that set up to anybody. I have heard tha you can get nikisil R65 850 kits that work a lot better but you are still going to have a bore/stroke setup that can't take advantage of the heads OR the valve train.
I forgot to add that R80 engines do run noticably stronger than R65 engines. I always advise to not pay very much attention to BMW's power ratings. Why a R80? If you are going to put that much wider engine in, why not make it a R100? The biggest bore that enigine is real good for IMO. supershaft screwed with this post 11-14-2012 at 11:40 AM |
11-14-2012, 04:58 PM
#23 | |
More tacos than you
Oddometer: 5,088
R80ST Gets The HPN Treatment Ducati Pantah 500SL Rebuild Seattle to TDF on an airhead WTB R100R Mystic sidestand and mount. |
11-14-2012, 05:38 PM
#24 |
Stay Horizontal
Oddometer: 1,600
It's in Oz, but seems like a nice get for someone wanting one.
http://www.ebay.com.au/itm/BMW-R65-L...item484b86169b
R100RS Gallery, over 800 pictures... |
11-14-2012, 06:24 PM
#25 |
because I can
Oddometer: 6,045
I am pretty sure you can't for the push rod tube angle but why do it to start with. The stroke is then way too short for the heads and valve train regardless.
11-14-2012, 07:16 PM
#26 |
More tacos than you
Oddometer: 5,088
Even if they're shortened? I thought I've read of people doing it.
11-15-2012, 05:02 PM
#27 |
because I can
Oddometer: 6,045
People do do it (pun intended). That doesn't make it right. Those pushrod seals barely work when everything is lined up right.
11-15-2012, 10:01 PM
#28 |
Yeah, right!
Oddometer: 4,250
Wouldn't it be easier to take and R80 and swap the relevant bits over?
R1150GS R80GS Basic __________________ |
