Old 11-05-2012, 01:41 PM   #1
KEELAYMONSTER OP
BRRAAAAPPP!!!
KEELAYMONSTER's Avatar
Oddometer: 162
Gutted stock exhaust??
Has anyone gutted the stock cans and tried them out? Im not talking just de-cat them, I mean gut everything. Im curious how they sound. My thoughts are they might sound like crap. Im just looking for a cheap way to lighten them and make them run a little cooler. If they dont sound to horrible ill probably gut mine.
I have already checked the stock cans "guts" on the HOW. Looks easy enough to do.
Kyle Montagne #141K
KEELAYMONSTER is offline   Reply With Quote
Old 11-05-2012, 01:42 PM   #2
KEELAYMONSTER OP
BRRAAAAPPP!!!
Oddometer: 162
I suppose I should state these are off a 950 A. Could be helpful to know
Kyle Montagne #141K
Old 11-05-2012, 06:23 PM   #3
DeepInIt
DeepInIt's Avatar
Oddometer: 1,368
Define gut. If you truly gut them, it will sound like an obnoxious Harley and run like crap until you rejet it.
DeepInIt is offline   Reply With Quote
Old 11-05-2012, 07:26 PM   #4
tunp
tunp's Avatar
Oddometer: 279
yes it can be done. i run a truly gutted and reworked can.
But it takes some work. I cut both end caps right behind weld, then you need to hole saw out the exhaust outlet (1 1/2" hole) is what i used. On the back side of can you must cut all the way thru which will cut thru the cat pipe also
After that you can slide the whole baffle assembly out.
I then reweld rear cap back on, welded an 1 3/4 dia pipe to the end cap, then used a 1 1/2 stainless preforated baffle thru can packed with baffle material i suggest stainless steel wool as the normal packing did not last long.
for the end cap i cut a pc off the interal baffle and welded to the inside of can so it projects enough to rivet the end cap on for repacking.
It will work and sounds good but it is loud, i ended up fitting an FMF spark arrestor on the end cap to reduce noise level.
Ridin w/ a smile
Tony A
02 FLHT, 11 990 adv,13 TE449,
tunp is offline   Reply With Quote
Old 11-05-2012, 09:17 PM   #5
idahoskiguy
idahoskiguy's Avatar
Oddometer: 1,119
Really?...............Your bike won't run any better and actually worse until it is rejetted. Glad I have left the stock exhaust unmolested, seems like a waste of time and money on these bikes for NO GAIN.
2011 Ducati MTS 1200 S Touring....amazing
2004 Aprillia Futura....sexy Italian mistress
2006 KTM 950 ADV....dirty beast
2001 KTM 640 ADV....most versatile
1999 KTM 300 EXC....woods weapon
idahoskiguy is offline   Reply With Quote
Old 11-05-2012, 10:26 PM   #6
KEELAYMONSTER OP
BRRAAAAPPP!!!
Oddometer: 162
I am aware of the necessary re jet. Did the setup you made weigh significantly less than original or is it relatively the same. Also do the cans run cooler?
Kyle Montagne #141K
Old 11-05-2012, 10:54 PM   #7
WARRIORPRINCEJJ
Not in the clique...
WARRIORPRINCEJJ's Avatar
Oddometer: 9,747
The cats, not the baffling, is what makes 'em run hot...
I spent all my money on motorcycles, 4X4's, whiskey, and women...The rest I just wasted. (edited to fit/original phrase by "WIBO")
"There's a WEALTH of cool people and knowledge on ADV, there's also a decent sized pocket of douche bag assholes that think their ADV forum Post Count (Oddometer) is their badge at being experienced riders." goodcat8
WARRIORPRINCEJJ is offline   Reply With Quote
Old 11-06-2012, 08:59 AM   #8
KEELAYMONSTER OP
BRRAAAAPPP!!!
Oddometer: 162
aaahhh. good to know. maybe just de cat them then.
Kyle Montagne #141K
Old 11-06-2012, 10:20 AM   #9
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,556
If you want some nice cheap light pipes, buy some carbon cans from a ducati and have a welder make a quick flange to the stock mid pipe. Takes a lot less time than gutting the stockers and lighter too.
We're not out here to rough it. We're here to smooth it . Things are rough enough in town.
Nessmuk
Old 11-06-2012, 10:21 AM   #10
Sporting Wood
I <3 Energizer Bunny
Sporting Wood's Avatar
Oddometer: 895
The search button can be your friend. Theres several old threads about this, many with pictures and directions.
Sporting Wood is offline   Reply With Quote
Old 11-06-2012, 10:32 AM   #11
tunp
tunp's Avatar
Oddometer: 279
so wieght savings was part of my goal when i did this and yes it easy drops 10-15 lbs between the two cans. My other goal was to go to a 2 into 1 setup and use the other can as a storage box which now holds my elec pump, a front and rear tube, first aid, spare plug, zip tyes and jb weld.
So was it some work, yes, does my bike look stock w/ addtioanl storage and more rumble, yes. are the cans much cooler, yes. Did it affect performance and or mileage, no.
I looked at it this way if it all worked it cost me a few bucks for material and some time which i was willing to put into it. If it did'nt work, well then i buy after market cans which i was going to do. And now i dont have to.
Ridin w/ a smile
Tony A
Old 11-06-2012, 12:52 PM   #12
KEELAYMONSTER OP
BRRAAAAPPP!!!
Oddometer: 162
My thinking exactly. If i can spend some of my time to save some money Im all for it.
The used cans was actually my next route if this doesnt work. I have access to a welder and a bunch of other fun tools at my work.
Also the search button sucks. Every time I try and use it it shows me a bunch of totally irrelevant stuff if anything at all. I did try manually looking through the OC posts though and didnt see anything. I have also checked out the HOW and saw whats all inside the stock cans.
Thanks for the input everyone. Ill post whatever I end up doing. Working on cutting my stock windshield down a bit today.
Kyle Montagne #141K
Old 11-07-2012, 02:42 AM   #13
K2m
....58....
K2m's Avatar
Oddometer: 2,242
The cats, not the baffling, is what makes 'em run hot....
Sorry WP Not True ;-) Remove the cats as I did in 2005 and nothing changes heat wise.
1/ The exhaust run through the middle of the bike makes the middle of the bike bloody hot
2/ The standard muffler has 1mm of insulation under the outer skin to protect it from internal heat. This does 5/fifths of fuck all to help cool the outer skin down.
3/ An aftermarket muffler is a perforated tube with 2 1/2 inches of insulation wrapped around it under the outer skin. with the exception of a little conduction of heat at either end where inner joins outer the outer it is well insulated.
4/ The whole standard muffler is designed to function as a cat.
There is only one way to get rid of the heat, get rid of the exhaust.
You can build your own like I did or the GPR is a very attractive proposition.
If you do not like the heat............
You need to move the exhaust system out into the flowing air along with your voltage RR
The News, those who are trying to control what we think, do not want us to see.
http://www.presstv.ir/live.html So good the British Gov. Banned it !!!
http://rt.com/on-air/rt-america-air/
K2m is offline   Reply With Quote
Old 08-28-2013, 11:47 AM   #14
KEELAYMONSTER OP
BRRAAAAPPP!!!
Oddometer: 162
Allright.
So I have been running a 2-1 setup with a de-cat stock muffler for a while now. It's just as hot as before and really made no difference in sound or performance.
My next route is to use the outer of the stock can and replace the innards with a perf core and lots of packing. Im sure it will be loud, require a re-jet, and still be relatively heavy but it should be much cooler. Im have a stock muffler off an 08 CRF450 that i am going to rob the innards from. I'll report when I finish it...
Kyle Montagne #141K
Old 08-28-2013, 04:49 PM   #15
Zander
Zander's Avatar
Oddometer: 194
Hi K2M,
Where do you relocate your voltage regulator to get it into clean air and keep it protected ?
Beginner's mind !
KTM 950
Zander is offline   Reply With Quote
Times are GMT -7.   It's 04:56 AM.
