Old 04-28-2015, 11:19 AM   #1
Hobbes950 OP
Darth Kitten
Hobbes950's Avatar
Oddometer: 4,044
Headlight and taillight out
Not too keen on reading wiring diagrams. Fuse is good, dash lights and turn signals working. No headlight or tail light. No high beam or high beam flash. No brake light. Would my issue be with the switch? Need to know where to start looking. Made for an interesting ride home last night. Watched my six hard and thank goodness for that auxiliary fog light!
When in doubt, take it as a compliment.
My Ride Reports
Hobbes950 is offline   Reply With Quote
Old 04-28-2015, 11:40 AM   #2
Hobbes950 OP
Darth Kitten
Hobbes950's Avatar
Oddometer: 4,044
Correction: I do have a brake light. I didn't think it was working. That would have made me feel a bit easier last night dammit.
My Ride Reports
Old 04-28-2015, 01:50 PM   #3
darkstarmoto
Am I evil? Yes I am
darkstarmoto's Avatar
Oddometer: 418
Pull headlight bucket and check if plug fell off back of bulbs?
05 KTM 950ADV - 08 KTM 690 SMR - 07 Ducati MTS1100S - Redneck Engineering Mutant
darkstarmoto is offline   Reply With Quote
Old 04-28-2015, 02:20 PM   #4
Hobbes950 OP
Darth Kitten
Hobbes950's Avatar
Oddometer: 4,044
Nope, all tight
My Ride Reports
Hobbes950 screwed with this post 04-28-2015 at 02:32 PM
Old 04-28-2015, 03:08 PM   #5
Tha Rick
Shake and bake!
Tha Rick's Avatar
Oddometer: 5,546
Bulb's OK/replaced? When I blew my tail light, the head light was a bout 3 day's later.
Or...
Put in a new fuse...I know it sounds stupid, but i've had an intermittent/cracked fuse before that gave me fit's for a while.
Good luck.
Happy Trails Y'all.
It's not about tha bike nor tha ride; it's about tha adventure in life we all seek. Great memories are made of taking tha trail less traveled and explored.
Tha Rick is offline   Reply With Quote
Old 04-28-2015, 04:02 PM   #6
motomal
motomal's Avatar
Oddometer: 175
When my 950 started blowing the headlight and tail light bulbs I didn't realise it was the rectifier cooking them until it had boiled my battery. Worth checking the charging rate doesn't exceed 14.8 volts when revved if your bulbs have actually blown?
Hope this helps
2007 KTM 950 SM
motomal is offline   Reply With Quote
Old 04-28-2015, 04:24 PM   #7
Hobbes950 OP
Darth Kitten
Hobbes950's Avatar
Oddometer: 4,044
If I am using the voltmeter right I have no power to the headlight, and no power to the switch. I tested the turn signal and got a reading, but for the head light- brown ground, tested the green and the blue- nothing and for the switch white ground and the other wires blue and yellow i think it was? -nothing. Don't know where to go next besides tearing into the harness and going over all the wires. Anything else I should test first? There was no prelim to this, it was fine then it wasn't. I believe I replaced the brake bulb a couple months ago.
My Ride Reports
Old 04-28-2015, 05:30 PM   #8
Hobbes950 OP
Darth Kitten
Hobbes950's Avatar
Oddometer: 4,044
Tested the fuses. Hi/low beam fuse has no reading, but how does that affect the brake light. The wiring diagram shows a light switch, but I do not have one, just a hi/low beam.
My Ride Reports
Old 04-28-2015, 05:45 PM   #9
oldfuddy
oldfuddy's Avatar
Oddometer: 813
Interesting and like to see the fix. When you had pwr to the blinker wires did the blinkers actually light up? All 4?
oldfuddy is online now   Reply With Quote
Old 04-28-2015, 05:46 PM   #10
oldfuddy
oldfuddy's Avatar
Oddometer: 813
What year/model bike?
Old 04-28-2015, 11:59 PM   #11
Hobbes950 OP
Darth Kitten
Hobbes950's Avatar
Oddometer: 4,044
I am going with the bad ignition switch theory. No power to the fuse box, only thing between it and the battery is the ignition. I will try a dousing of contact cleaner, but I am pretty sure that unless I find a broken wire, I will be getting a new ignition. Damn thing is riveted on too.
2005 KTM 950 Adventure. The blinkers all work.
My Ride Reports
Old 04-29-2015, 12:26 PM   #12
Hobbes950 OP
Darth Kitten
Hobbes950's Avatar
Oddometer: 4,044
Solved!
Here you can see the spring loaded contacts are stuck down.
My Ride Reports
Old 04-29-2015, 12:40 PM   #13
darkstarmoto
Am I evil? Yes I am
Oddometer: 418
Wow! note to self...go home and spray some WD40 or similar in my ignition switch.
Old 04-29-2015, 01:01 PM   #14
DirtyADV
DirtyADV's Avatar
Oddometer: 2,420
Had the exact same problem on my 950, it had been hard to get lights to fire up blamed the HID ballasts for it.
Ended up with no lights except indicators, last few kilometers in the dark on the highway was a bit scary but following some slow moving car and living on his lights got me to my goal for the day.
Checked the contacts in the ignition lock but they looked good, and lights worked again, only drove during the day getting home again.
Looked over wiring from ignition and found this:
Might be worth opening the protective sheet if having ignition lock contacts out, especially if high mileage bike even the older models that dont have the wiring cutting plastic added to them.
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Times are GMT -7.   It's 04:54 AM.
