Old 08-28-2013, 09:12 PM   #16
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,572
zzzzzzzzaaaaaaaaaaapppp...... dead thread revived
As you start to cut the OEM muffler apart, you will discover that it is possible to gut and reconfigure. You also will discover that it can be a bit of a PITA to work with because the outer shell is not single walled so welding it all back together can be challenging at times.
I believe that the OEM mufflers 'run hot' because the exhaust spends a bunch of time in the muffler traveling between the three chambers before it finally exits. The cat can be a contributing factor, however I do not believe it really makes all that much difference in surface temps one way or the other.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 08-29-2013, 10:52 PM   #17
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,065
I've completely gutted a stock muffler, but did not install it. When you pull out the double wall with the soft packing, the muffler shell will ring like a bell. These would make a good high pitched wind chime. I suspect it will ring the same way when used on the exhaust too.
"Son, you can't do both"
Old 08-30-2013, 08:24 AM   #18
tunp
tunp's Avatar
Oddometer: 288
My experiance with this will disagree. Once you get your preferated tube and packing material in place its now a muffler not a wind chime
Ridin w/ a smile
Tony A
02 FLHT, 11 990 adv,13 TE449,
tunp is offline   Reply With Quote
Old 08-30-2013, 09:49 AM   #19
K2m
....58....
K2m's Avatar
Oddometer: 2,239
The reason Zuber did not install it is because even gutted it's a heavy heap of shit and a waste of time................ just buy some mufflers
I have just had a complete year away from bikes, and ADV.... a sabbatical
The News, those who are trying to control what we think, do not want us to see.
http://www.presstv.ir/live.html So good the British Gov. Banned it !!!
http://rt.com/on-air/rt-america-air/
K2m screwed with this post 09-08-2013 at 02:00 AM
K2m is offline   Reply With Quote
Old 08-30-2013, 10:03 AM   #20
K2m
....58....
K2m's Avatar
Oddometer: 2,239
Originally Posted by Zander View Post
Hi K2M,
Where do you relocate your voltage regulator to get it into clean air and keep it protected ?
I guess the simple way would be........... anywhere the wires reach. I have changed my bike so much that it would no longer be relevant to a normal LC8.
K2m screwed with this post 08-30-2013 at 10:17 AM
Old 08-30-2013, 03:15 PM   #21
KEELAYMONSTER OP
BRRAAAAPPP!!!
KEELAYMONSTER's Avatar
Oddometer: 163
I have bike envy... Cant wait to see the finished product.
Kyle Montagne #141K
KEELAYMONSTER is offline   Reply With Quote
Old 08-30-2013, 03:59 PM   #22
Zander
Zander's Avatar
Oddometer: 194
I will look at relocating the VR this winter when I take the bike apart.
Thank you for your answer.
Beginner's mind !
KTM 950
Zander is offline   Reply With Quote
Old 08-30-2013, 04:02 PM   #23
K2m
....58....
K2m's Avatar
Oddometer: 2,239
The design is all about centering the weight distribution. I recon the LC8s are way too heavy on the front wheel for dirt work, especially in outback Oz.
I stoped working on it one year ago to do some skiing, and get out of the garage for a while.........
Old 08-30-2013, 04:35 PM   #24
K2m
....58....
K2m's Avatar
Oddometer: 2,239
Zander
I recon under the headlight, behind the LC8 grill would be the best spot. You would have to lengthen the wires....... simple enough
Triumph dose that.
Old 08-30-2013, 04:59 PM   #25
Zander
Zander's Avatar
Oddometer: 194
Zander
I just went into the garage and it looks like there is plenty of space.
It's now on my tear down and rebuild list.
Beginner's mind !
KTM 950
Old 03-06-2015, 07:55 PM   #26
casaytierra
Francisco
casaytierra's Avatar
Oddometer: 29
Originally Posted by KEELAYMONSTER View Post
Allright.
So I have been running a 2-1 setup with a de-cat stock muffler for a while now. It's just as hot as before and really made no difference in sound or performance.
My next route is to use the outer of the stock can and replace the innards with a perf core and lots of packing. Im sure it will be loud, require a re-jet, and still be relatively heavy but it should be much cooler. Im have a stock muffler off an 08 CRF450 that i am going to rob the innards from. I'll report when I finish it...
I decated my cat HOWEVER what really made a difference Heat wise was the dongles (rottwailer performance, 29 bucks) you connecto on the O2 sensors (eliminating O2 sensors)
Then you get a real 10 C difference
ANd by the way I removed the SAS
Now I didnt love the stock exhaust sound, just opened it and made it a straight and shit its loud. Man! loud
casaytierra is offline   Reply With Quote
Times are GMT -7.   It's 07:25 PM.
