Old 11-06-2012, 08:48 AM   #16
papalobster
With Gusto!
papalobster's Avatar
Oddometer: 13,423
I saw this a bit late to comment. Used to work R&D at Baldor Generators and we would flash a dead gen with a 9 volt battery into the outlet.
Drill trick works too, essentially you are taking the residual magnetism in the drill rotor and turning it by hand, making it a small generator thereby introducing a small voltage into the generator "remagnetising" the rotor.
Now, why it lost it's magnetism during operation is a whole different problem
Is it an inverter generator?
papalobster is offline   Reply With Quote
Old 11-06-2012, 10:25 AM   #17
D.T.
Up in this MF'er!
D.T.'s Avatar
Oddometer: 10,986
Laugh
Exciter on a generator...
Interesting stuff. I've heard of it before. Must be like loosing "magnetism" in a field coil. Magnetism is what makes the electricity...
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 11-06-2012, 10:57 AM   #18
Beezer
Oddometer: 5,748
ah.... turn the drill to make it generate.... that makes sense. drills typically have a series wound (universal) motor. the brushes in the motor would serve as a rectifier. in any case, a voltage at the generator outlet would be fed into the regulator system & re-establish the electromagnetic field which re-establishes the residual (permanent) magnetism. there is no such thing as permanent AC magnetic field right.... so somewhere the exciter current is rectified & can then re-magnetise the cores of the exciter
Beezer is online now   Reply With Quote
Old 11-07-2012, 04:53 AM   #19
WayFar
Oddometer: 153
Not sure if it'll work with your particular generator, but if you need to flash the field, and it's electric start, just hit the key again for a split second. Works every time for me, and if you have a starter lockout switch, you get the voltage you need through the system, and no starter grinding. If not...well...whats a little starter overspeed between friends?
Interestingly, I also used this trick on a forklift that we started by arcing the starter, but once running it produced no power. Couldn't get it onto a trailer. Hit the key again just for shits and grins, and voila!--full power.
"Down, Right, Aft, WHEEEE!!!!!!!'
1973 FL
2006 Uly
WayFar is offline   Reply With Quote
Old 11-07-2012, 10:52 AM   #20
ttpete
Rectum Non Bustibus
Oddometer: 5,851
If you have a brushless AC generator (alternator), it has a permanent magnet field similar to those used in most modern motorcycles. It's always energized, and "flashing" is never necessary. Almost all of the small AC generators today are the brushless type.
15 BMW RnineT
09 Kaw Versys
Old 11-09-2012, 10:42 AM   #21
papalobster
With Gusto!
Oddometer: 13,423
Um
Honda does not make any brushless generators.
All Baldor Generators I worked on from the 1.7kw PC17 to the TS250 (that largest they made while I was employed there) were all brushless as well. No magnets in any of them.
Old 11-09-2012, 11:32 AM   #22
DirtyDog
Lust for dust.
DirtyDog's Avatar
Oddometer: 7,912
I tried to do the 12V battery trick (suggested by my manual... like jump-starting) AND the reverse corded drill trick to excite mine. Neither worked. Took it apart and the rectifier board was fried. Don't know if it was fried before I tried to excite it or not.
While trying the 12V battery method, my 110v incandescent bulb illuminated a bit, but didn't stay on. Then it was dead after that.
Once my new rectifier board arrives, I'll re-diagnose. Hope to have a reliable generator for the potentially shitty winter.
Still 80 degrees F here. Should be freezing by next week.
"This place fucking runs on beer, you buy the right person a beer, and you get a job, a blow, a place to sleep, whatever.
You're hot, cold, thirsty, hungry... beer will fix that.
Beer is a god damn miracle, and don't you forget it!"
-DustyRags
DirtyDog is offline   Reply With Quote
Old 11-09-2012, 06:56 PM   #23
Beezer
Oddometer: 5,748
there are several ways to do the excitation, but on most, the excitation voltage, no matter where it comes from, is fed into a rectifier to convert it to DC, then regulated and sent to coils that excite the main generator windings. the main windings also feed into the control regulator.
put another way, the initial excitation is from a permanent magnet field and causes a small AC voltage to be generated in the main windings. that voltage is fed into a rectifier/regulator to power the electromagnetic field which produces a much larger excitation, and drives the generator up to system voltage. then system voltage is (also) fed into the R/R circuit for the field, so the main output is also powering it's own field
I would NOT put 120VAC on a generator that is set up to deliver 12VDC.
Old 11-09-2012, 07:09 PM   #24
ttpete
Rectum Non Bustibus
Oddometer: 5,851
My big generator is an ex-military unit driven by a 4 cylinder Jeep engine, and it has a separate 12 volt generator on the end for excitation and for battery charging. It also cranks the engine up by running it as a motor from the battery. Output is 240/120 volts single phase 3 wire, the same as the house wiring. It only runs at 1800 rpm, so it's very quiet.
15 BMW RnineT
09 Kaw Versys
Old 11-11-2012, 12:40 PM   #25
Peanuts
Peanuts's Avatar
Oddometer: 1,607
My standby Honda generator has not been used for a couple of years. I guess I need to dig it out from the back of the shed..... thanks for the advice :)
Peanuts is offline   Reply With Quote
Old 11-12-2012, 09:11 PM   #26
DirtyDog
Lust for dust.
DirtyDog's Avatar
Oddometer: 7,912
Update- got my gen working today after replacing some parts. I used the corded drill flashing method to re-magnetize the field. Worked like a damn charm.
Highly recommended for simplicity.
-DustyRags
Old 11-13-2012, 12:38 AM   #27
buickid
Lets ride!
Oddometer: 310
For the record, what was busted?
2005 Yamaha Zuma YW50, 2009 Kawasaki Super Sherpa KL250
buickid is offline   Reply With Quote
Old 11-13-2012, 03:35 PM   #28
DirtyDog
Lust for dust.
DirtyDog's Avatar
Oddometer: 7,912
See above. And yes, it's now down to freezing (at night).
-DustyRags
Old 11-13-2012, 05:36 PM   #29
buickid
Lets ride!
Oddometer: 310
Whoops, missed that bit. Stay warm. Forecast calls for a low of 68F on Thursday night here, yikes.
Old 11-13-2012, 06:04 PM   #30
ttpete
Rectum Non Bustibus
Oddometer: 5,851
My condolences.......
Maybe you'll get a volcanic eruption to warm things up......
15 BMW RnineT
09 Kaw Versys
Times are GMT -7.   It's 06:09 PM.
