11-06-2012, 01:32 AM
#1 |
Oddometer: 15
lc8 engine sounds like machine gun
so ive had an lc8 engine for a few years and it would click really loud while trying to start it almost like a backfire,and now its doing it alot more than it used to. Sounds like a really loud machine gun or a starter ten times louder than normal. Anybody ever have the same issue or know what is going wrong with this thing? thanks for your input!
cheers |
11-06-2012, 02:22 AM
#2 |
Oddometer: 270
Hi, sounds like oil pressure and the cam chain clattering away
. Firstly, are you using (loosing) coolant. The waterpump seal is a common fault and the coolant swells the oil filter and limits oil movement and pressure. The filter becomes wavy. Probably where I would start. Lots more to work though if this looks good .
11-06-2012, 04:46 AM
#3 |
LC8 Adventurer
Oddometer: 1,315
Not sure your year of bike but there was a service bulliten on a starter clutch issue that would cause the loud noise when starting and could continue if not replaced. Check that out on the 950.info page.
If your truly experiencing back fires then you may have some jets blocked if your bike is carbed. Correction, it was a starter torque limiter. Here is a link and scroll down the page to read. http://www.ktm950.info/how/ktm_950_issues.html
2004 KTM 950 Adventure S 2012 Ducati Multistrada 1200 Pikes Peak |
11-06-2012, 03:38 PM
#4 |
Green Cantern
Oddometer: 6,510
I'm just going to add that a person should do some basic observations themselves first. I'd say at a bare minimum is to describe the bike's setup, stock engine, intake & exhaust or otherwise. Also you should pull your spark plugs and take a look at them. There's a big difference between plugs that are wet and oily and ones that are dry and burnt. Have you checked anything yourself, and if so, what? Ever checked your valves or timing chain tension? Does it have oil in it?
The more you list, the better your responses will be.
950/990 CRASH BAR BAGS, FENDER BAGS, and more. Made with pride. Pachaug Map '08 KTM 450 xcr-w, '10 KTM 990 Adventure '85 Honda CR500 NETRA #24519 |
11-08-2012, 11:50 AM
#5 | |
Isn't that dangerous?
Oddometer: 1,222
Good luck.
EastSideSM: '06 950SM Black, '01 Honda RC51 |
11-10-2012, 05:06 PM
#6 | |
Sand seeker
Oddometer: 1,104
I'm starting to get a minor case of the clack. Is this a warranty item? The local dealer said he wasn't sure.
Everybody's on the run |
11-11-2012, 01:01 AM
#7 |
....58....
Oddometer: 2,238
What year is it? It may not be the touque limiter. This is important.
The News, those who are trying to control what we think, do not want us to see. http://www.presstv.ir/live.html So good the British Gov. Banned it !!! http://rt.com/on-air/rt-america-air/ |
