Old 11-06-2012, 04:58 PM   #1
Katoom119 OP
Mmmm....Orange Kool-aid
Katoom119's Avatar
Oddometer: 1,837
Voltage of the Low Octane Wire
I currently have a waterproof switch to activate the low octane map on my bike instead of disconnecting the wires. Only problem is the only waterproof switch I could find was a push button. I can't tell when the thing is pushed or not because it resets to the same position.
I want to wire it to a Highway Dirt Bikes handle bar clamp set up so my questions are:
1) Are the HDB buttons set up so that it is very clear if the button has been pushed or not?
2) Is there a way to wire it so that when it is activated it lights up the small LEDs that you can get with the kit?
I know I could just wire it so that I unplug the wire like stock, but what fun would that be?
Those who dance are considered crazy by those who do not hear the music.
I am not the same having seen the moon shine on the other side of the world. - Radmacher
5 Cylinders vs. Moab..........My East Tennessee.........Internships may go to Hell and I will go to Alaska
Katoom119 is offline   Reply With Quote
Old 11-06-2012, 05:01 PM   #2
spafxer
spafxer's Avatar
Oddometer: 2,649
Hard to say what voltage since it goes into the ECU.
Get out your voltmeter, unplug your existing connection and read across the 2 wires.. Then find out what the Led's need to operate.. Voila!
spafxer is offline   Reply With Quote
Old 11-06-2012, 06:39 PM   #3
tahoeacr
tahoeacr's Avatar
Oddometer: 2,210
Doubt you will find voltage. Most ECU's look for a ground to switch maps.
tahoeacr is offline   Reply With Quote
Old 11-06-2012, 06:53 PM   #4
Katoom119 OP
Katoom119's Avatar
Oddometer: 1,837
I knew this but I didn't want to cut the switch out that I've already installed and was hoping someone knew off the top of their head.
Makes sense. Ground for one map, no ground (no circuit) for the other. K.I.S.S.
On top of this I've realized that if there was a voltage running through the wire that the LED would always be on unless I had a DPST switch or something like that. Electrical circuits weren't my physics professor's strong point when he was teaching us.
Thanks guys!
Old 11-06-2012, 07:45 PM   #5
Sacal
Sacal's Avatar
Oddometer: 132
What he said, it's ground for sure...no guessing either, it says so in the wiring diagram
Talking switches, you should look at online chandlery (boat) stores, they sell waterproof toggle switches like this one that will fit the hdb switch mounts.
http://www.tcschandlery.co.uk/7213/E...mpaign=pid7213
ad astra per alia porci
Sacal screwed with this post 11-06-2012 at 07:57 PM
Sacal is offline   Reply With Quote
Old 11-06-2012, 07:54 PM   #6
kirb
should be out riding
kirb's Avatar
Oddometer: 1,836
Switching a line to ground to switch maps is common....there would be some DC voltage on one of the lines when not activated, but I wouldn't run an LED with it. You could measure it...might be anywhere from 5V to 12V when not switched on.
A Ducati, some Guzzi, a KTM, and a Excelsior...Indian in resto.
kirb is offline   Reply With Quote
Old 11-07-2012, 09:18 AM   #7
PS-RagE
PS-RagE's Avatar
Oddometer: 651
I ran mine through a relay. The NC coil voltage is also what lights the LED (on for low octane)
A. Dale McLean
aka PS-RagE
2007 Beta REV3 270
2012 KTM 350 EXC-F
2014 KTM 1190 Adventure R
PS-RagE is offline   Reply With Quote
Old 11-07-2012, 10:50 AM   #8
geometrician
let's keep going...
geometrician's Avatar
Oddometer: 1,030
short answer, "no" on the HDB push-button switch question
Britt
'06 KTM 950 Adv 'S'
'03 KTM 250 EXC
'87 KLR650 - <200K miles "Like the Energizer Bunny, just keeps going & going..."
geometrician is offline   Reply With Quote
Old 11-07-2012, 04:38 PM   #9
Katoom119 OP
Katoom119's Avatar
Oddometer: 1,837
Thanks everyone. Looks like I'm just going to put the thing back stock. Serves me right for overthinking something.
Old 11-07-2012, 07:03 PM   #10
go2cnavy
go2cnavy's Avatar
Oddometer: 561
? Why not just use a toggle switch like mentioned above ? It would work perfect in the HDB mount.
go2cnavy is offline   Reply With Quote
Old 11-07-2012, 07:59 PM   #11
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,487
Indeed.
Radio Shack, less than 5 bucks, not waterproof, slathered on a little silicon sealer to help with splash resistance. Works great, and I live in a wet climate.
I too thought about an indicator light, but worried the draw night affect the curve. The toggle is its own indicator: up for high octane, down for low.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is offline   Reply With Quote
Times are GMT -7.   It's 08:28 PM.
