Old 12-10-2012, 06:27 PM   #1
Bluethumb OP
Oddometer: 126
Removing emission system
I'm removing the gas recirculating system on my airhead. I know to use rubber timing plugs to plug the holes in the air box, but I can't remember which plug to use to plug the heads. I know a drain plug threads in, but I can't remember which one.
Anyone has the part number?
I did a search on this forum but couldn't figure out the right search terms so got nothing.
Bluethumb is offline   Reply With Quote
Old 12-10-2012, 06:36 PM   #2
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,544
It's the 16mm plug used on oilheads. Get the crush washers too.
07119902292
SCREW PLUG - M16X1,5
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 12-10-2012, 08:21 PM   #3
Bluethumb OP
Oddometer: 126
Perfect, thanks
Do I use loctite thread lock, semi-thread lock, anti-seize, or nothing at all?
Old 12-10-2012, 09:50 PM   #4
supershaft
because I can
Oddometer: 9,116
I use ant-seize and torque them just as they were in the sump. I have never had one come loose.
Old 12-11-2012, 03:09 AM   #5
100RT
100RT's Avatar
Oddometer: 737
Mine stripped the threads when taking them out. Becareful!
100RT is offline   Reply With Quote
Old 12-11-2012, 05:30 AM   #6
some_guy
some_guy's Avatar
Oddometer: 144
Originally Posted by Bluethumb View Post
I'm removing the gas recirculating system on my airhead. I know to use rubber timing plugs to plug the holes in the air box...
I was wondering what to use to plug the air box holes, thanks!
some_guy is offline   Reply With Quote
Old 12-11-2012, 10:11 AM   #7
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,822
Ahh... about to do this m'self... starting on the winter to-do's....
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Old 12-11-2012, 10:17 AM   #8
CptImagine
NCC-1701-B
CptImagine's Avatar
Oddometer: 241
Bulkhead fittings in air box
While getting bulkhead fitting at the plumbing supply, Put a hose on the nipple sticking outa the air box, and run the hose aft . I've used PVC valve in the end as check valve . I get the head plugs from the plumbing supply also . I always apply heavy never sieze to the head plugs and drill across the head, into the allen hole, for a safety wire . SS wire it to the exhaust spigot . I've had 2 blow out on mountains before the safety wire idea .
CptImagine screwed with this post 12-12-2012 at 07:06 AM
CptImagine is offline   Reply With Quote
Old 12-12-2012, 07:54 PM   #9
Velocipede
Velocipede's Avatar
Oddometer: 455
Or,you could loosen the nut where the tube enters the Airbox and insert a copper cent piece.Retighten the nut and everything looks stock.
John
Velocipede is offline   Reply With Quote
Old 12-12-2012, 08:01 PM   #10
supershaft
because I can
Oddometer: 9,116
I don't like the timing hole covers there. I have seen too many fall out. I have had the same modified carriage bolts in my airbox for 25 years now. Air tight/water tight and they are still there just like I put them in so many years ago.
Times are GMT -7.   It's 12:10 AM.
