Old 11-07-2012, 11:08 AM   #1
Moto Vader OP
Oddometer: 4
2005 1200GS known issues?
The wife and I are going to look at a 2005 R1200GS this weekend and I am trying to sort out the known issues with these bikes are particular years. Is there anything I need to be concerned with? I've heqrd reliability is great, but also likened to playing the lottery. Could end up with a bad one.
We are coming from japanese reliability standpoint.
Moto Vader is offline   Reply With Quote
Old 11-07-2012, 11:27 AM   #2
IJM
Hinderant Backbenderz
IJM's Avatar
Oddometer: 225
Cracks on rear flange
May be tough to see but definately check the flange that holds the read tire on, there can be cracks at the lugs or brake bolts. get a flachlight on that.
Do a search on this site, there's a thread all about it.
Horizontally opposed, Vertically challenged
IJM is online now   Reply With Quote
Old 11-07-2012, 11:49 AM   #3
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,172
To be clear, this concern is for all years of R1200Gs with the possible exception of 2012s, if they have a steel flange instead of AL. There was a running change to the part and I am not exactly sure when it happened.
Old 11-07-2012, 12:01 PM   #4
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,531
Others may agree or disagree with me but 2005 was the first year of the 1200. I just remember a lot of issues that were ironed out later. There were some that one cylinder would drop a valve or otherwise blow up. The Final Drive oil for life that was fixed later. Something about the fuel pumps shorting out. Front Brake rotors, rear brake flange as mentioned was big on 05 and 06 models.
Put your location on your profile, locals can better help you and point you to good deals in the area.
This site has a Flea Market section. Good deals come up there all the time. I prefer 2008 and newer.
http://en.wikipedia.org/wiki/BMW_R1200GS look for 2005 issues in lower right recall section of this article. 19 and 20
http://www.motorcycleinfo.co.uk/inde...vjxqtaqfhxwmvv
cylinder issue
http://www.advrider.com/forums/showthread.php?t=189778
scooteraug02 screwed with this post 11-07-2012 at 12:13 PM
scooteraug02 is offline   Reply With Quote
Old 11-07-2012, 12:42 PM   #5
Moto Vader OP
Oddometer: 4
The bike in question is being offered by a BMW dealership, so I am guessing any known issues "should" be updated or "certified" as being serviced properly. Not always the case I'm sure, but I'll bring up some of these points, thank you.
I have seen much of the FD issues being talked about.
Wife is more attracted to the RT/LT's than the GS. I am coming from a dirt bike/supersport background and feel like RT/LT's are for when I'm 60....sorry
I've always wanted a GS.
Old 11-07-2012, 12:55 PM   #6
NoVa Rider
Oddometer: 2,925
If it is an abs bike, i believe that model's abs pressure module has been flagged as a issue. If it goes, you may lose the speedometer, and get a flashing red light which will impede inspection. And don't forget the sticker shock -- IIRC, it is about a $2,500 part. . .. And don't forget installation, which could be another $1,000.
http://www.maxbmwmotorcycles.com/fic...6&rnd=08102012
NoVa Rider is online now   Reply With Quote
Old 11-07-2012, 01:04 PM   #7
Moto Vader OP
Oddometer: 4
What is your reasoning?
Old 11-07-2012, 01:10 PM   #8
SkiFly01
Govna Racepipe
SkiFly01's Avatar
Oddometer: 592
ESA
TPMS
Enduro Trans
Upped in HP
Non-wizzy brakes
updated FD w/ drain bolt
Kai
2008 BMW GSA
2000 Kawasaki Super Sherpa
SkiFly01 is offline   Reply With Quote
Old 11-07-2012, 01:15 PM   #9
Moto Vader OP
Oddometer: 4
Sound reasons
Old 11-07-2012, 01:42 PM   #10
NoVa Rider
Oddometer: 2,925
Current threads discussing the abs pm issue:
http://advrider.com/forums/showthread.php?t=838196
http://advrider.com/forums/showthread.php?t=839490
Old 11-07-2012, 01:52 PM   #11
Masterpotter
Oddometer: 44
I have a 05 and so does my riding buddy, Both are doing fine. Check for oil between the engine and the trans, rear main . Dino oil seems to work best for us. No other issues for me 35,000 miles . A great bike but you knew that.
Masterpotter is offline   Reply With Quote
Old 11-07-2012, 02:38 PM   #12
GB
Mod Squad
GB's Avatar
Oddometer: 56,719
Main seal leaking was pretty much on all 05's and early 06's, once the bike had about 10 to 12K miles..
Old 11-07-2012, 02:41 PM   #13
blockpass270
Oddometer: 65
I bought an 05 R1200GS w/42k miles.
In the first 1k miles I was greeted w/a rear wheel carrier (aka flange) w/cracks.
4k later it was the ABS failure. Module Masters could not fix it, so it got an ABS-ectomy.
If I could do it again, I'd wait for a 2007 or newer.
15 500 EXC / 13 150XC / 05 R1200GS
blockpass270 is offline   Reply With Quote
Old 11-07-2012, 03:53 PM   #14
CheckerdD
CheckerdD's Avatar
Oddometer: 1,292
I have close to 100k miles on an early production 05. The second such bike sold in Reno. I don't want to scare you off, but there were problems with the first production run of those bikes that were fixed later, and also fixed under warranty. Before I ran out of the warranty at 36k miles my bike went through 3 final drives, one transmission, one clutch due to the seal leaking oil on it, one CANBUS, and one fuel pump controller. Since 36k miles I have only had to replace the drive shaft. That broke due to my being a bit too enthusiastic off road. If I were looking at an 05 I would want it to have enough miles on it that I would think all the defective stuff in the early model run had broken and been replaced by now. If the bike has more than 30k miles it is probably OK, but if it only has 5k miles I would not buy it. I agree look at the crack between the trans and engine for signs of an oil leak, spin the rear wheel and see if seems to grind in any way - a sign of final drive or drive shaft problems. I would ask about things like whether the brake fluid had been changed which can affect the life of the servo brake system. I like my 05 a lot and I intend to run it into the ground which I expect to be after I have several hundred thousand miles on it. Dave
Pavement! We don't need no stinkin pavement.
CheckerdD is offline   Reply With Quote
Old 11-07-2012, 04:09 PM   #15
rebake
rebake's Avatar
Oddometer: 1,058
Just turned 76000 miles on mine.Had bearings and seals for counterbalance shaft at 12000.Clutch slave cylinder and seal at about 35000.About it so far.Ed
amish people think i dress funny
rebake is offline   Reply With Quote
Times are GMT -7.   It's 06:07 AM.
