Old 11-25-2012, 05:12 AM   #1
Mike Figielski OP
Oddometer: 494
Question on hooking up aftermarket brake switch to bike
Hi All,
Picked up an HP2 and I am attempting to improve the brakes for road use. Fitted a radial master cylinder which works well but I am having trouble getting the brake switch which comes with the new master cylinder to work. Just 2 wires on the OEM switch and the new one but it won't work. Is there some Canbus magic I am missing here? The wiring diagram looks like the OEM switch is fed through the ZFE. Anyone know a way to make this work? Thanks!
Mike
Mike Figielski
Check Out:
beemerboneyard.com
Mike Figielski is offline   Reply With Quote
Old 11-25-2012, 05:22 AM   #2
GSMarc
GSMarc's Avatar
Oddometer: 1,107
nothing speific with the HP2 brake switch.
When you press the lever very few, you must hear a 'clic' which close the circuit I imagine.
In opposition, you must press the clutch lever fully to hear the 'clic' .
Hope this helps.
2014 KTM EXC450 6Days
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
2005 HP2E SM Prototype
GSMarc is offline   Reply With Quote
Old 11-25-2012, 05:45 AM   #3
Mike Figielski OP
Oddometer: 494
Hope this helps.
Thanks, I hear the click and the stock switch works fine. When I splice the wires for the new aftermarket master cylinder switch into the stock wires the brake light does not work (brake light on all the time). When I switch wires and it works the opposite way (brake light goes out when I press the lever).
Mike
Mike Figielski
Check Out:
beemerboneyard.com
Old 11-25-2012, 07:08 AM   #4
bemiiten
League of Adventures
bemiiten's Avatar
Oddometer: 4,970
The switch on the BMW is normally closed, perhaps the new one is N.O. That would mean the brake lite would go off when you Squeeze the lever
bemiiten is offline   Reply With Quote
Old 11-25-2012, 02:28 PM   #5
Mike Figielski OP
Oddometer: 494
I thought of that but when I reverse the wires it still does not work. Not sure if reversing the wires would reverse the operation of the switch though.
Mike Figielski
Check Out:
beemerboneyard.com
Old 11-25-2012, 02:31 PM   #6
Twilight Error
Going nowhere slowly
Twilight Error's Avatar
Oddometer: 22,749
No, it would not.
You'd have to renovate the switch internals to change them from NC to NO.
If you wanted to take the LONG way around, use the switch to energize a NC relay, which in turn completes the brake light circuit.
If you're all about the destination, take a fucking flight. - Frank Turner
Got brap, and twice as much fuel as you. - Akarob
Twilight Error is offline   Reply With Quote
Old 11-25-2012, 02:33 PM   #7
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,417
Reversing the wires does not change the mechanical action of the switch from NO to NC. It merely reverses the direction the current takes through the switch.
You'll need to change the switch from NO to NC.
def is online now   Reply With Quote
Old 11-25-2012, 02:34 PM   #8
Mike Figielski OP
Oddometer: 494
Thanks, I'll have a look at the switch and see what I can do with it.
Mike Figielski
Check Out:
beemerboneyard.com
Times are GMT -7.   It's 07:57 AM.
