Old 11-07-2012, 06:23 PM   #1
Bearsfatha OP
Pirate on a GS!
Bearsfatha's Avatar
Oddometer: 24
Redline V-Twin Transmission Oil with ShockProof® in a GS?
Hey everybody, I've got a new to me '96 1100GS and I need to service the transmission. Is anyone using Redline V-Twin Transmission Oil with ShockProof® in their GS transmission? I kind of thought it might make it shift better.
Stupid should hurt!
Bearsfatha screwed with this post 11-07-2012 at 07:43 PM
Bearsfatha is offline   Reply With Quote
Old 11-07-2012, 07:46 PM   #2
Bearsfatha OP
Pirate on a GS!
Bearsfatha's Avatar
Oddometer: 24
Here is the reason I am asking. According to Redline The Heavy ShockProof® has a thickness greater than an SAE 75W250, yet low fluid friction like 75W90. I run it in my Harley and it really quietened the the transmission and shifting. Anyway I'm just checking.
Stupid should hurt!
Old 11-07-2012, 08:32 PM   #3
rdwalker
Oddometer: 2,545
I'd suggest contacting the very Guru of GS transmissions. You can PM Anton from his ADV profile page or contact him through his website.
Robert in Northern NJ __ '09 R12GS, '03 R1150RT, '01 F650GS
-->> James Bay & North Road Solo Blitz -->> Patagonia / Tierra del Fuego Cappuccino Tour
-->> Trans-Labrador Highway Solo Blitz --->> South African Cappuccino Tour
rdwalker is offline   Reply With Quote
Old 11-07-2012, 09:30 PM   #4
Gimpinator
This is my Mom's cat
Gimpinator's Avatar
Oddometer: 1,172
I've run it in my '05 R1200GS for the past year. It noticeably improved the neutral gear rattle I'd been experiencing, and shifting is butter smooth.
So far, so good!
"Son, I thought by now you would have run out of stupid."
Gimpinator is online now   Reply With Quote
Old 11-08-2012, 05:46 AM   #5
Bearsfatha OP
Pirate on a GS!
Bearsfatha's Avatar
Oddometer: 24
Thanks I appreciate the input. I like the "butter smooth"!
Stupid should hurt!
Old 11-08-2012, 07:54 PM   #6
Dark Helmet
Dark Helmet's Avatar
Oddometer: 724
I used Redline Shockproof in my 1100 and thought it worked great. Bought a used 1200 GSA w/ 12,000 miles on it in great shape. 2-3k later I have a tranny input seal go bad. Mechanic told me that he doesn't think that the seals on these bikes like synthetics He also implied a "red" synth. I have stayed away from Redline as a result. Then I put BMW BMW 75-140 GL 5 in the gearbox to see if it would quiet gear rattle. Guess what, it's a red Synth. Think I am going back to Redline.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD -40. If it shouldn't move and does, use the duct tape
BMW 1200 GS Adventure
BMW 1970 R75/5
Suzuki DRZ 400S
Dark Helmet is offline   Reply With Quote
Old 11-08-2012, 11:40 PM   #7
Bearsfatha OP
Pirate on a GS!
Bearsfatha's Avatar
Oddometer: 24
Thanks Dark Helmet. I really think I'm gonna go with the Redline I have had great luck with it in my Harley transmission.
Stupid should hurt!
Old 11-09-2012, 02:51 PM   #8
Poway
SHED (Shit Head)
Poway's Avatar
Oddometer: 500
Stay Away from this Sh@t!!
I'm a perfect example of trying to improve on the highly paid BMW's enginer specifications of using 90 wt GL fluid. This recommendation wasn't good enough for me. So I called Redline, and spoke to a nice gent. He informed me his product would be a great fit for my GS. So, I put this "miracle" stuff in my tranny and final drive here's what I experienced:
A) Smoothed out my trannies shifting
B) Destroyed my Final drive
C) Chunks of metal on my tranny's drain plug magnet, (Texas size)
All on 5000 miles.
I would never put this stuff in my GS again. In the mine field of life look for the foot prints in front of you. Watch out if you go this route.
PS:
Here's the stuff that cost me dearly. Wish I caught the the lack of a GL rating, this would have saved a lot of pain and $$$.
http://www.redlineoil.com/product.aspx?pid=44&pcid=4
Poway screwed with this post 11-13-2012 at 12:38 PM
Poway is offline   Reply With Quote
Old 11-09-2012, 03:12 PM   #9
jdbalt
Oddometer: 196
Yikes
Yikes
B) Desroyed my Final drive
All on 5000 miles.
jdbalt is offline   Reply With Quote
Old 11-09-2012, 10:22 PM   #10
vintagerider
vintagerider's Avatar
Oddometer: 1,975
Bearsfatha, Your 1100 has a 5 speed which calls for GL-5 gear oil. Redline V Twin Transmission fluid with Shock Proof is not GL-5:
"Same fluid as our unique Heavy ShockProof® Gear Oil"
per Redline here: http://www.redlineoil.com/product.aspx?pid=119&pcid=13
A good place to learn about your 1100 gear box:
http://www.largiader.com/tech/oiltrans/
You may have either an M94 or M97. You can identify which from the case numbers which are viewed behind the RS throttle body. Next, pay attention to Anton's description of M97 failure modes, particularly:
" the input gear rubs against the rear bearing and they wear into each other (there isn't really enough contact area between them)."
I'll add to that:
Bearing cover weakens, then gear oil flows in to the grease packed bearing. If the gear oil is not compatible with the grease then it coagulates. Lubrication within the bearing is then lost.
Can the choice of gear oil make a difference?
Using an oil which is miscible with the bearing pack may delay total bearing failure (anecdotal). Conventional GL-5 and some synthetics are miscible. Many synthetics are not. If the oil drains brown then bearing grease pack wash out has occurred. As long as the bearing is not starved from coag then many additional miles may still be possible.
Best advice in the 1100 5 speed is probably to stick with conventional GL-5 in BMW specified weight. If you use a syn then choose one which is fully miscible with the bearing grease pack and one which is GL-5 rated. Sometimes the oil refiner will tell you which base stocks it uses (Group II, III or IV). Generally you should avoid using economy syn gear oil such as Mo 1 75w90, (their V twin 20w50 syn is excellent in the 11xx engine for summer). Store brand syns like Penzoil, Valvoline are usually made from cheap non miscible stocks.
Seal failure was more common when syns were first introduced. These days seal conditioners are usually added to quality syns.
Anecdotal: Ted's Beemer shop uses the GL-5 version redline syn, I believe in the 75w90 weight. "seems to work for many." keep in mind that syn formulations change. CRC's Sta-lube Syn-Go OEM was highly miscible at one point, not sure if it still is. Shifting and fuel economy are better with syns but the advantages must be weighed against the risk.
>>Interesting report from Poway on his "final drive failure"after using a Redline product (which one?). FD bearings have no grease pack. Could be the failure mode there was poor shim or just a crap bearing.
edit: reply to comments from others:
"I use (super duper brand syn)" ..."11 years, no leaks, failures ect"
reply: You have an 1150 not an 1100
"I thought this was gonna be easy...
reply: It is. Just use non-syn in the weight appropriate for ambient. But wait, there's more...
The Third Choice:
Bio-Based Gear Lubes (Vegetable Oil) Ultra Lube 10400 GL5 80w90:
http://www.amazon.com/Ultra-Lube-104...s=gl5+gear+oil
"less friction and heat" (less than what, turkey drippings?)
"virtually odorless"
"safe for your health" (can we cook with this?)
Who wants to be the first to run UltaLube veggie GL5?
vintagerider screwed with this post 11-11-2012 at 04:30 PM
vintagerider is offline   Reply With Quote
Old 11-10-2012, 03:33 AM   #11
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,768
I use Super Tech 75W-140 GL-5 to which I ad a bit of moly (makes it shockproof). So far after 11 years, I have no leaks or failures and my Getrag gearbox shifts like new (quietly).
Quality synthetic GL-5 gear oils do not cause seal failure.
Insist on GL-5 API grade.
def is offline   Reply With Quote
Old 11-11-2012, 04:02 AM   #12
Bearsfatha OP
Pirate on a GS!
Bearsfatha's Avatar
Oddometer: 24
And I thought this was gonna be easy... OK I'm doing a lot more research. Thanks for the recommendations!
Stupid should hurt!
Old 11-11-2012, 04:18 AM   #13
Beemerlover
Oddometer: 334
Seems like, with these bikes at least, it might make sense to just use the BMW-labeled lubes sold by the dealers - even though they're ridiculously overpriced.
Beemerlover is offline   Reply With Quote
Old 11-11-2012, 04:47 AM   #14
ragtoplvr
Oddometer: 6,598
rattles and noise is the nature of the beast. The motor rattles like a can of marbles on a paint shaker, so does the tranny. It is nothing wrong. use mineral 75W90 and embrace the rattle.
If you increase the idle speed to 1200 it idles smoother and is a lot quieter. Some prefer that, some don't. I did it for a while on my RS with no lowers. Not a good idea for an RT though.. I have gone back to slower idle for more engine braking and ignore all the noise.
Rod
ragtoplvr is offline   Reply With Quote
Old 11-11-2012, 09:41 PM   #15
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,615
No..just use the recommended grades...ie. GL5..simple enough..
Def uses a GL5 from Wally World..adds some Moly..several of us use Amsoil Severe Gear..all with no problems and MANY MANY miles...
"Ignorance is a powerful tool when applied at just the right time..sometimes even surpassing knowledge.." EJ Potter
Bill-66 is offline   Reply With Quote
Times are GMT -7.   It's 10:37 AM.
