Old 11-08-2012, 02:33 PM   #1
Homeboy OP
Oddometer: 1
help
New to dual sport/ adv riding , but not new to dropping bikes. Yesterday while taking advantage of beautiful weather went for probably the final ride of the season. While rounding a curve hit ice & went down- immediately turned off ignition switch & picked up bike '07 990 ADV. Would not restart! Bike fell on left side & after getting home began trouble shooting. Took off left tank hoping it was the quick disconnect on fuel line - not so, should the next step be to deal w/ the fuel pump? I'm not hearing any noise from the pump when I turn on ignition- should I? Bought bike w/ 40k miles from a buddy who is gonna help me w/ wrenching , but He is outta touch ( touring in Copper Canyon).Any thoughts?
Homeboy is offline   Reply With Quote
Old 11-08-2012, 02:57 PM   #2
Katoom119
Mmmm....Orange Kool-aid
Katoom119's Avatar
Oddometer: 1,837
Could be a number of things. Easy thing first is to determine if the kickstand kill switch is broken. If the dash lights up when you turn on the key, then that's not it. Kill switch would also keep the dash lights off.
Those who dance are considered crazy by those who do not hear the music.
I am not the same having seen the moon shine on the other side of the world. - Radmacher
5 Cylinders vs. Moab..........My East Tennessee.........Internships may go to Hell and I will go to Alaska
Katoom119 is offline   Reply With Quote
Old 11-09-2012, 08:34 PM   #3
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,170
when mine takes a nap, it cranks but doesn't start up on the first try because the line probably loses pressure. So i switch the ignition a few times to pressurize the line and then it starts immediately. But then all this time my fuel pump is working and i can hear it.
You said you dont hear the fuel pump when turning ignition on, but does everything (instrument cluster, lights etc) work on the bike ?
defn. worth checking the side stand switch and if the neutral indicator is working (when its in neutral). Try starting it with the clutch pulled in (assuming your clutch switch is good)
Building a KTM 690Exc - the ultimate dirt tourer
2007 KTM Adv990S - Sold, 2010 KTM530Exc-Rally, 2012 KTM Adv990
Vicks is offline   Reply With Quote
Old 11-09-2012, 08:46 PM   #4
dunerat
WTF?
dunerat's Avatar
Oddometer: 14,367
make sure the handle bar run switch by the throttle is on
GO KINGS!!!!(Edit:2 TIME STANLEY CUP CHAMPION KINGS) 00'KX500 (dune wrecker)08'SE ,06'EXC,02'YZF/W,76'04'H-D
92 YJ extreem ,76 CJ 5 sand beast ,07 JK cruiser
dunerat is offline   Reply With Quote
Old 11-09-2012, 08:52 PM   #5
Tee2
I SAID! Woo Hoo!
Oddometer: 1,276
Been there...Done that.
Tee2 is offline   Reply With Quote
Old 11-09-2012, 08:55 PM   #6
srad600
srad600's Avatar
Oddometer: 683
I'd check the tip over switch also, maybe it got damaged in the fall?
srad600 is offline   Reply With Quote
Old 11-10-2012, 04:04 PM   #7
Central Cali Rider
Central Cali Rider's Avatar
Oddometer: 415
Might be the fuel pump. Mine went out without notice. It was the Facet and I just pulled over in Colorado to take some pictures fired it back up and it started coughing about 20 yards on the road and .......
Central Kali Coast
2005 KTM 950 Adventure
1965 Meyers Manx Dune Buggy
2006 Suzuki SV1000S for wifey Sold !
1997 KLR650 For sale SOLD !!
Central Cali Rider is offline   Reply With Quote
Old 11-10-2012, 08:46 PM   #8
Groundhog
Groundhog's Avatar
Oddometer: 188
I don't believe in coincidence and I've been trouble shooting mechanical issues for many years. IMO it would be a coincidence if your fuel pump failed because you dumped it. Not impossible, just improbable (I think).
I haven't looked at a wiring diagram for a while, but if there is an easy way to run jumper wires from your battery to your fuel pump you could test your fuel pump.
If you need help with this let me know and I will research it further.
Luck.
PS where are you located? (just curious)
Groundhog
Horsepower determines how fast you hit the wall. Torque determines the size of the hole you make.
Groundhog is offline   Reply With Quote
Times are GMT -7.   It's 01:06 PM.
