Old 12-08-2012, 11:15 AM   #46
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,359
Originally Posted by Dan Alexander View Post
Not to have any resistance at all, even with the adjuster nut fully screwed in must mean that spring is waaaay flat. Is that even possible?
It called memory loss...wait 'till your my age sonny...you learn all about.....
...what were we talking about???
def is offline   Reply With Quote
Old 12-08-2012, 12:11 PM   #47
Dan Alexander OP
Ride Far - Ride Fast
Dan Alexander's Avatar
Oddometer: 7,598
Gee it's nice to be called sonny at a tender age of 61
I've been afflicted with the memory loss ever since the mid 60's
Beemers Past and Present: 74 R90S, 77 R100RS, 85 K100RS, 2x 87 K100RS, 96 R1100GS (getting hacked), 99 R1100S, 2002 R1150GS, 2005 F650 Dakar, 81 GL500/Velorex
Plus the occasional Triumph, BSA, Yamaha, Honda, Suzuki and KTM but who's counting
Dan Alexander is offline   Reply With Quote
Old 12-08-2012, 12:37 PM   #48
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,716
Yeah, I admit it, I tried to be cheap.
Oh well, at least the labor is cheap
Can't tell from your original pic on post 1. I'd say yes it does look a little flat. Maybe the same specs or close but I have a good one from an R100GS if you want to compare.
Was looking at a clutch pack for a K on fleabay not long ago. Cheap and looked good but for the springs all blue at the tips.
I could mock up mine back together on the airhead but not much time today for that. But don't you think that removing material from the plates when resurfacing without compensating for it with the thickness of the friction disk could also contribute to that from their design?
Have tools, will travel!
Old 12-08-2012, 01:04 PM   #49
def
def's Avatar
Oddometer: 10,359
Sounds reasonable? How much material did they remove?
Old 12-08-2012, 01:57 PM   #50
Dan Alexander OP
Oddometer: 7,598
I'll measure the thickness of mine and post it.
I'm not sure how much they removed but I did ask and they said they calculate it all when doing the friction material. They've been doing clutches since 1930 so you'd think they have it pretty well figured out.
http://www.ottawaclutch.com/
"We specialize in the remanufacturing of all
Industrial and Automotive clutches, custom applications,
Racing Clutches,
Cranes and Overhead Cranes,
Forklifts and Tow Motors,
Mines, Mills and Quarries,
Buses, Transit, Passengers Coach and School Buses,
On and Off Road Heavy Equipment
Winches, Draglines and Logging applications
Farm Equipment and Agriculture application
Truck and Trailer shoes and brake block sets
Commercial laundry applications, shoes, bands and pads
Automotive and Light truck shoes and pads
Punch Press and Brake Press bands, shoes and clutches
Construction Equipment applications
Steel uncoiler friction rings
Gear tooth facings and segments for the rebuilders
Heavy duty woven lining for Marine applications
Motorcycle shoes and pads
Friction Rings and Specialty Brake Pads
Landscape applications
Golf Course applications and golf cart shoes/pads
Antique and Classic Automobile shoes and pads
Printing Industries applications"
Old 12-09-2012, 06:54 AM   #51
Dan Alexander OP
Oddometer: 7,598
Mine is slightly off level but the total thickness ranges from 15.85mm to 16.5mm
Wonder if that is close to yours.
Just read that RBRacing recommends using an 1150 spring instead of an 1100 as it's 2.00mm instead of the 1100's 1.75mm
bottom of the page
http://www.rbracing-rsr.com/bmw_clutches.html
Old 12-09-2012, 10:16 AM   #52
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,716
bottom of the page
Don't know if I'd believe any of the BS coming out of RBRacing..... Well maybe for some tips but DON'T try to buy parts from them,they may not even exist yet.
That one I have here is 15.6 so no comparisons there. But add them lost millimiters from parts wear...cable stretch etc...etc...may all add up to more than the adjustments can take. My old GS I could even see the actuating arm bend when applying the clutch, had to reinforce that.
Got to wonder now if I could put it on the larger scale I just bought and see what it takes to compress it.May overload the 300lbs scale. Shop should be warm(er) by now.
I'd replace that spring anyway,"off-level" is not that good that would introduce clutch chattering and uneven wear in the long term. Had to go back in my old GS just for that reason so now won't take any chances, clutch work= new spring. Got to be a reason why that lining got cooked to that point and that would create lots of heat, more than enough to weaken them springs.Doesn't take all that much heat to remove temper on spring steel, off the top of my head 650F is MAX for most of them.
Interested in that anyway,reminds me of my youth dropping clutches & brakes at Asbestonos(?) in Quebec City and the smell in that shop. My K will probably need clutch work at 100,000 miles if I judge from my measurements at 20,000. I know that some have had theirs relined with success on the Ks, short term as "it works" but I haven't seen any long term reports.
Old 12-09-2012, 10:27 AM   #53
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,109
If slack is needed to take up, the 1150 pushrod is 12mm longer and can be machined down to fit.
Old enough to know better....
Young enough to try it again
GS Addict is offline   Reply With Quote
Old 12-09-2012, 12:47 PM   #54
Twilight Error
Going nowhere slowly
Twilight Error's Avatar
Oddometer: 22,743
You got that right.
A couple weeks ago, I called their tech support line with a question about whether the Street 360 or ceramic 4 paw clutch disc would be better for my riding style.
I didn't even get to finish before the person on the other end interrupted and told me all the BMW clutches were still in development. I thanked her for her time and hung up.
If you're all about the destination, take a fucking flight. - Frank Turner
Got brap, and twice as much fuel as you. - Akarob
Twilight Error is offline   Reply With Quote
Old 12-09-2012, 01:21 PM   #55
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,716
RBRacing....haven't checked on them for 3 years or so but back then the parts were "under development".They'll develop them with customer's money it looks like. If you go on their website there used to be some pretty funny comments from them about some of their customers. Enough to keep me away from them that's for sure.
I just had another tought....did you lift the part number from mainly the spring but the other parts also? Should be stamped on most of them, BMW is good for that. Then punch that into the MaxBMW parts finder to see what it fits. Older machines, never know who could have gone in there and done some hacking/mismatching.
I know for a fact that clutch parts mismatch is a big NO NO for some of the Ks. BMW switched suppliers at some point in the 90s. There are bulletins on that but I don't know if there are any for the R-GSs.
If you feel inclined to dig through that , and there are a lot of bulletins to dig through, I'll send you a link as to where to look. I won't post it here but as a courtesy to a fellow Canadian....no problems.
Old 12-09-2012, 01:47 PM   #56
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,716
Do I have a spring test for you....Takes 200 Lbs to flatten that spring. That means I can't do that just standing on it, I tried. Gotta eat more.....
Now why did I buy that scale......
Old 12-10-2012, 09:05 PM   #57
Dan Alexander OP
Oddometer: 7,598
I wasn't quite as scientific but the 'heel on the spring on the scale' number got me about 135 pounds to flatten it. A lot different than 200# .... but I still don't think that's the non contact issue.
Old 12-11-2012, 11:29 AM   #58
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,716
Need more pics of your parts. Engagement hole in the spring? them could wear out according to my manual.
And the clutch lever behind the transmission? those do bend. Someone may just have taken up all the adjustments to keep that bike rolling and then bent it.Clutch sure looked....abused. I could see my lever flex by eye, had to reinforce it sticking a piece of alu pipe over it.
135....does sound weak. Yes also did the heel dance on mine, no way I can flatten it. But I am only 170 with the winter gear on.
Scientific......Flunked all that to ride & wrench way back then. The near new "medical" scale from the Salvation Army. $3.99....I am cheap.
Old 12-11-2012, 12:21 PM   #59
Dan Alexander OP
Oddometer: 7,598
I thought you'd like that 'scientific'
I could compress it easliy with my heel but I'm 225
I pulled the throwout bearing yesterday and checked the clutch arm and everything looks fine. That spring must be really compressed.
I'm going to get a new spring and start fresh and see how that goes. Should I replace the throwout bearing too .. feels fine but I've read a couple of threads wehere the guys did a new clutch and 100 miles later that bearing is gone. I'm not thinking long term right now as I'm not sure if I'll keep the bike after I get it running. I may sell it and my Dakar for a 800GS or keep the both of them and ride one on the Alcan 5000 I'm registered for in 2014
Old 12-11-2012, 12:38 PM   #60
def
def's Avatar
Oddometer: 10,359
Originally Posted by def View Post
Its called memory loss...wait 'till your my age sonny...you learn all about.....
Memory loss in the clutch spring not in yer noggin'...are you daft boy or have you forgotten we were talkin' about your clutch...Hmmmm, that fella is loosin' it.
Times are GMT -7.   It's 05:31 AM.
