Old 05-24-2013, 02:34 PM   #376
kajj
kajj's Avatar
Oddometer: 192
Nice!
One thing thou, isn't the master link clip facing the wrong direction?
It should face the other way around to prevent something to release the clip when the chain is moving?
kajj is offline   Reply With Quote
Old 05-24-2013, 03:14 PM   #377
sailah OP
Lampin' it
sailah's Avatar
Oddometer: 5,689
Good eye. The clip master was just to get the chain on I plan to use a rivet once the bike is running. I just didn't want to rivet now in case I had to remove chain
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 05-24-2013, 04:28 PM   #378
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,168
Might need tightening too
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Mercury264 is online now   Reply With Quote
Old 05-24-2013, 04:35 PM   #379
sailah OP
Lampin' it
sailah's Avatar
Oddometer: 5,689
You shut your mouth when you are talking to me mister
I haven't adjusted that yet jeez, can't a guy get a break. Actually going to need a lot of slack due to how high the swingarm pivot is.
Nessmuk
Old 05-24-2013, 04:42 PM   #380
Mercury264
Mercury264's Avatar
Oddometer: 22,168
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 05-25-2013, 12:29 AM   #381
kajj
kajj's Avatar
Oddometer: 192
Okey, fair enough
Old 05-25-2013, 04:22 PM   #382
sailah OP
Lampin' it
sailah's Avatar
Oddometer: 5,689
Every once in awhile you do something that makes you really proud of your work. Today was that day for me. I needed to make up a steering stop so the fork legs won't smack the frame. Started off with a 1.5" x 1.5" bar of aluminum
I'm a total n00b on the mill. I just started using one a few weeks ago, so to a normal machinist this might seem like a cakewalk. Basically in this shot I had already drilled the holes to bolt to the lower triple and was machining it down to the final hieght.
Couple steps in between but here is the rough product
Bolted in place
And powder coated
This powder really looks gray in the pics but it's def black in person. Looks really nice against the orange anodizing. Too bad no one will ever see it
Anyways that's it. Took me all of 5 hours start to finish, probably the most expensive steering stop in history. Lots of milling operations to get there though.
Nessmuk
Old 05-25-2013, 04:27 PM   #383
kajj
kajj's Avatar
Oddometer: 192
Wow. That turned out awsome
Old 05-25-2013, 04:36 PM   #384
4play
Next?
4play's Avatar
Oddometer: 2,561
Nice.
Family isn't always about blood
4play is offline   Reply With Quote
Old 05-25-2013, 05:23 PM   #385
Mercury264
Mercury264's Avatar
Oddometer: 22,168
+1 Fantastic.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 05-25-2013, 05:28 PM   #386
DRjoe
DRjoe's Avatar
Oddometer: 5,115
Very nice.
I hope to get a mill soon but I don't think I'm going to be as quick to learn how to use it as you have been.
Old 05-25-2013, 05:45 PM   #387
sailah OP
Lampin' it
sailah's Avatar
Oddometer: 5,689
Originally Posted by DRjoe View Post
Very nice.
Thanks guys I wanted to bring it home and fondle it
regarding a mill if you have used a lathe, it's not a hard transition. I'm spoiled as the shop has 3 brand new Jet milling machines with DRO on them. I guess my only advice is to not buy cheap endmills. I bought a set of Interstate (china) endmills because I wanted a set. Well the reality is that you can do a lot with just a couple endmills that are specialized. I bought a dedicated aluminum endmill that does and awesome job and leaves a perfect finish. Until you run it in reverse
I also did most of the work here with a monster 3/4" roughing endmill that just hogs the chips off. Making the counterbore for the head of the socket cap screw I used a 7/16" end mill and bored it out.
The only other operation I used was a boring head to make the radius to fit the steering neck. I blocked the part up on a pair of parallels and used holddowns to secure it. I used the edgefinder to get me right on the edge (the part was 100mm long) then jogged in half the radius of the edgefinder (0.100") + 50mm to get me on center. The I just kept plunging the quill while advancing the table in. Easy.
The angles I set up a V block and clamped it to the table so that I could keep taking the part off and checking.
BTW, thanks Kawasaki for not making the steering stop you welded to the neck symmetrical that was really helpful
Getting into the mill is fairly simple, there are a bunch of things you want to know before you even turn one on though. I watched a ton of videos mostly by Keith Fenner on YouTube. I also had to take a 2 hour class to get cleared on the machine and that was helpful for learning the controls.
Nessmuk
Old 05-26-2013, 01:34 AM   #388
OaklandStrom
Oddometer: 1,612
Originally Posted by Roadracer_Al View Post
I assume that is at Tech Shop?
That's so cool they have that gear. Neither of our local locations have powder coating.
Al,
There are 3 Bay Area TechShop locations and all of them offer powder coating. SF has a sand blast cabinet large enough for a motorcycle frame, and the oven is 6x4x4 (rough outside dimensions).
PM me if you have any TechShop questions.
OaklandStrom is offline   Reply With Quote
Old 05-26-2013, 11:22 AM   #389
Roadracer_Al
louder, louder, louder!
Roadracer_Al's Avatar
Oddometer: 1,605
Seriously? They don't have powdercoating listed in the class offerings. Good to know!!!
Daaayum, that's a nice piece of work, Mister Sailah.
You're right: the tool IS the cutter. Being self-taught, I struggled a lot with cutters (there are a zillion different ones in the catalogs, what to choose) until I got a roughing cutter, when I realized that "normal" end mills are best for finishing cuts, after the roughing cutter hogs off the bulk of the waste.
Actually, your best roughing cutter is a bandsaw!
Suck, Squeeze, Bang, Blow
Roadracer_Al is offline   Reply With Quote
Old 05-26-2013, 12:03 PM   #390
sailah OP
Lampin' it
sailah's Avatar
Oddometer: 5,689
Actually, your best roughing cutter is a waterjet!
Nessmuk
Times are GMT -7.   It's 05:57 AM.
