Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 03-23-2014, 10:31 AM   #3181
Drunk_Uncle
Drunk_Uncle's Avatar
Oddometer: 2,281
I'm just going to mount Touratech 3l fuel cans to the back of Happy Trail cans later this year. Right now just going to rely on the tanks.
"I refuse to tiptoe through life only to arrive safely at death" '13 Tiger 800XC, '14 Street Triple, '00 KLR 650(finished project), and 2010 Honda NT700V wife's.
Drunk_Uncle is offline   Reply With Quote
Old 03-23-2014, 07:07 PM   #3182
jpr
jpr's Avatar
Oddometer: 403
Originally Posted by ram1000 View Post
Anyone seen any raising links. I want to use the incidental effect of stiffening the spring rate when links are fitted to raise the bike, plus I will get an extra inch+- of ride clearance.
This same company has raising links.
http://www.projection-components.co....kits-214-p.asp
'12 Triumph Tiger 800XC
'03 Triumph Speed Four
'03 KTM 400 EXC (Sold)
'02 Kawasaki KX250 (Sold)
jpr is online now   Reply With Quote
Old 03-23-2014, 07:13 PM   #3183
The Haymaker
The Haymaker's Avatar
Oddometer: 644
What do these do with an already odd geometry in the chain tension department?
Sent from my SCH-R970 using Tapatalk
Haymaker who?
https://www.facebook.com/groups/adventureridemaine/
The Haymaker is offline   Reply With Quote
Old 03-24-2014, 04:05 AM   #3184
boinoodle
Old and Cautious
boinoodle's Avatar
Oddometer: 1,276
I raised my bike with Soupy's raising links a little more than an inch, I had more than enough adjustment in the rear wheel to get correct chain tension
Sealed with a curse as sharp as a knife. Doomed is your soul and damned is your life
Lord John Whorfin
boinoodle is offline   Reply With Quote
Old 03-24-2014, 04:22 AM   #3185
The Haymaker
Oddometer: 644
Reason I ask is this bike wants a LOT of slack so things don't over tighten when axle, pivot, and cs are in line, only bike I've had that was worse is my KTM. Does this require even more slack?
The chain slap on this thing is annoying, bumps and low rpm. I let a friend ride it and first thing he said was "that kickstand banging would drive me nuts. "
Haymaker who?
Old 03-24-2014, 04:47 AM   #3186
boinoodle
Old and Cautious
boinoodle's Avatar
Oddometer: 1,276
I haven't noticed needing more than the recommended slack. Not much we can do about the slap
Lord John Whorfin
Old 03-24-2014, 05:23 AM   #3187
GearHd6
GearHd6's Avatar
Oddometer: 166
There is a cure for the slap. My Roadie did the same thing. I have since cured it.
2015 Tiger 800 XCx
2004 CRF250X
GearHd6 is offline   Reply With Quote
Old 03-24-2014, 05:54 AM   #3188
boinoodle
Old and Cautious
boinoodle's Avatar
Oddometer: 1,276
What's that, don't ride it off road?
Lord John Whorfin
Old 03-24-2014, 06:31 AM   #3189
GearHd6
GearHd6's Avatar
Oddometer: 166
I didn't even have to ride mine off road to make that horrendous noise, hit a sharp bump and it banged like it was falling apart. Take it on a rough dirt road and it was ready to launch it into the woods. I have taken it out a few times now since the mod and haven't heard the noise once yet. I'm not flying it through the air though like some of you guys might be.
2015 Tiger 800 XCx
2004 CRF250X
Old 03-24-2014, 06:45 AM   #3190
boinoodle
Old and Cautious
boinoodle's Avatar
Oddometer: 1,276
Did you document the mod? I can't find it.
Lord John Whorfin
Old 03-24-2014, 08:01 AM   #3191
GearHd6
GearHd6's Avatar
Oddometer: 166
Nah, I didn't document it. It seems like a crazy fix but I think the noise was the hard plastic guide smacking off the swingarm.
I used a piece of this stuff about 8"-9" long. The stuff I used was 3/8" wide but I think I'd try something 1/2"-3/4" wide if I were going to the store to buy it. This stuff I already had on hand.
Next I removed the chain guide attaching bolt and pried the guide down, wiped out the dirt and cleaned the guide best I could so the adhesive would stick. Then I stuck the foam to the inside/bottom of the chain guide. You can just barely see the white between the guide and the swingarm.
2015 Tiger 800 XCx
2004 CRF250X
Old 03-24-2014, 08:20 AM   #3192
boinoodle
Old and Cautious
boinoodle's Avatar
Oddometer: 1,276
That's brilliant, I'll have to check it out before next ride.
Lord John Whorfin
Old 03-24-2014, 10:40 AM   #3193
snakebitten
Small Town Hick
Oddometer: 977
Clever indeed.
XT1200Z BIGGEST Dirt Bike in the world
500 EXC Dirtiest Street Bike in the world
snakebitten is offline   Reply With Quote
Old 03-24-2014, 03:21 PM   #3194
Rubberlegs
Oddometer: 195
Not a crazy fix at all. This is a recommended repair procedure by many car makers. You would be surprised how much of this stuff is used on a car dashboard.
Bood job!
Rubberlegs is offline   Reply With Quote
Old 03-25-2014, 08:44 AM   #3195
Dubl-A
SuckerDucker
Dubl-A's Avatar
Oddometer: 1,808
It's not the guide.
I swapped bikes with my Dad on a washboard road and watched for any contact on my XC's suspension/ Center stand/ guide/ etc and chain does not contact the swingarm during the clank.
Take another ride and see that the clank does not happen when the throttle is closed only when open. What you're hearing is the excess slack getting yanked during swingarm movement.
Properly set your rear shock per the manual and check back
Hope this helps.
Aaron
Keep your $0.02 if it ain't going towards the bill
Dubl-A is offline   Reply With Quote
Times are GMT -7.   It's 01:55 AM.
