Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 04-10-2014, 01:26 PM   #3301
Dubl-A
SuckerDucker
Dubl-A's Avatar
Oddometer: 1,808
Originally Posted by Dirigo View Post
I picked up my '14 last week. Had a moment when I first touched the boxes and they shifted. Service guy said the same thing, it's for shifting weight, wind, and some "give" for when you drop it. Dunno about the last part, but for the most part I haven't noticed too much of an issue so far.
Load em up and it really feels like nothings there. I immediately noticed the lack of this design when I switched to a solid rack pannier setup.
Keep your $0.02 if it ain't going towards the bill
Dubl-A is offline   Reply With Quote
Old 04-10-2014, 06:36 PM   #3302
Sound Farm
Art x Science
Sound Farm's Avatar
Oddometer: 104
Originally Posted by boinoodle View Post
Is that the "all in one" design? How about some pictures?
Pic. Of how I mounted it. Used the oem mount. Just had to loosen it and reposition it to make the horn fit
And where I mounted the relay. Just used the original bolt.
All u needed was some wire to get back to the battery, an inline fuse, and a few connectors. Super simple. Didn't even take an hour.
2012 Triumph Tiger 800 XC
99 KTM Adventure-R 640 (sold)
Garmin 550
Sound Farm screwed with this post 04-10-2014 at 06:44 PM
Sound Farm is offline   Reply With Quote
Old 04-10-2014, 07:08 PM   #3303
XCRider803
Loftin' the wheel
XCRider803's Avatar
Oddometer: 903
Looks a little low. My fender goes almost all the way to the triple clamps when the suspension is compressed.
2013 Triumph Tiger 800 XC
2013 Husky TE 449
XCRider803 is online now   Reply With Quote
Old 04-10-2014, 07:08 PM   #3304
The Haymaker
The Haymaker's Avatar
Oddometer: 636
Fender doesn't hit on full compression? I had to split my Stebel to get the horn to fit up in there.
Sent from my SCH-R970 using Tapatalk
Haymaker who?
https://www.facebook.com/groups/adventureridemaine/
The Haymaker is offline   Reply With Quote
Old 04-10-2014, 07:18 PM   #3305
Sound Farm
Art x Science
Sound Farm's Avatar
Oddometer: 104
The pics are a little misleading The bike is. Strapped down to a trailer with suspension compressed. It barely hangs down past the beak. When its on
Garmin 550
Old 04-10-2014, 07:20 PM   #3306
The Haymaker
Oddometer: 636
Must be a lower profile than Stebel.
Haymaker who?
Old 04-10-2014, 08:18 PM   #3307
Wandering Dane
We are the luckiest guys
Wandering Dane's Avatar
Oddometer: 356
Fiamm Horn on Roadie
I just mounted a Fiamm Highway horn (coincidentally the unit just recommended by Motorcycle Consumer News) on my Roadie.
Clearance is definitely an issue. I measured less than 1" clearance between the top of the fender and the bottom of the Roadie beak when the forks are fully compressed. Therefore, I had to modify the Fiamm horn but sound volume is barely affected:
Wandering Dane is online now   Reply With Quote
Old 04-11-2014, 08:09 AM   #3308
XCRider803
Loftin' the wheel
XCRider803's Avatar
Oddometer: 903
Just out of curiosity, what was your method of fully compressing the forks? I was going to tackle that little project and measure some clearances myself.
2013 Husky TE 449
Old 04-11-2014, 08:15 AM   #3309
cory1848
Oddometer: 312
Just remove the fork caps. Very easy. Support the bike underneath though or you wont get it back up.
Current ride: 2013 Yamaha Super Tenere
Past rides: 2013 Triumph Tiger 800XC, 1997 Honda Goldwing SE, 2003 Kawasaki Ninja 6RR, 1997 Suzuki TL1000S, 1995 Suzuki Katana 600, 1985 Suzuki GS550EF, 1980 Suzuki GS250T
cory1848 is offline   Reply With Quote
Old 04-11-2014, 10:04 AM   #3310
PYG RYDR
Adventure-Dual Sport
PYG RYDR's Avatar
Oddometer: 387
Sorry, this item is no longer available!
Originally Posted by Meteos View Post
Here is where I got mine:
http://www.aliexpress.com/snapshot/6033120188.html
$30 total
I placed an order, then received notice that my order was canceled and would be 6-7 days for cc refund.
I checked their site and here is their latest message
http://www.aliexpress.com/item/1-SET...573643379.html
PYG RYDR
T800XC-VFR800-XR650L-WR250R
MSTA-NVR
There are two things to aim at in life: first, to get what you want; and, after that, to enjoy it.
Only the wisest of humans achieve the second.
Logan Pearsall Smith
PYG RYDR screwed with this post 04-11-2014 at 10:05 AM Reason: To add information
PYG RYDR is online now   Reply With Quote
Old 04-11-2014, 10:57 AM   #3311
jpr
jpr's Avatar
Oddometer: 398
you should be able to find those on ebay too!. I bought mine for the speed four there.
http://www.ebay.com/itm/Adjustable-F...e394c3&vxp=mtr
'12 Triumph Tiger 800XC
'03 Triumph Speed Four
'03 KTM 400 EXC (Sold)
'02 Kawasaki KX250 (Sold)
jpr is online now   Reply With Quote
Old 04-11-2014, 11:27 AM   #3312
cory1848
Oddometer: 312
Happened to me as well. Suggested I buy them for the 675. Not sure of they are the same levers or not.
I just ordered the set via ebay.
cory1848 screwed with this post 04-11-2014 at 11:43 AM
Old 04-11-2014, 02:39 PM   #3313
Wandering Dane
Oddometer: 356
I did not compress the forks, have a simpler method:
I have a tie-wrap around one of the fork tubes. While off-roading, I've bottomed the forks and the top of the tie wrap was about 3/4" above the end of the fork tube.
So with the bike on the center stand, I measured the length of the fork tube below the female slider, subtracted 3/4" and then compared that dimension with the dimension from the bottom the beak to the top of the fender.
Old 04-11-2014, 07:27 PM   #3314
XCRider803
Loftin' the wheel
XCRider803's Avatar
Oddometer: 903
Seems a little messy, maybe a couple tie downs is in my future.
Dirt on the tubes gives me that. I want to see what it takes to get clearance and this isn't enough to figure out all the nooks and crannies. Thanks for the suggestion, but I want to experiment with things so the forks need to be bottomed.
2013 Husky TE 449
Old 04-12-2014, 03:41 AM   #3315
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,816
Maxton inserts.
Ready to fit. Just need buy some 5W oil as they didn't supply any.
3 black Tigers. 955i+800XC+800XC=113000 miles of fun.
blacktiger is offline   Reply With Quote
Times are GMT -7.   It's 07:58 PM.
