Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 02-21-2013, 02:12 PM   #676
fbj913
I ride
fbj913's Avatar
Oddometer: 2,394
Originally Posted by mint julep View Post
hey guys, here's a noob question.
I like/want to change for the folding Touratech shift lever.
Is it as easy as bolt off/on?
Thanks,
Dave.
yes and no. the lever will simply bolt on bolt off but then you will need to adjust the position of the lever. its easy.
fbj913 is offline   Reply With Quote
Old 02-21-2013, 02:13 PM   #677
fbj913
I ride
fbj913's Avatar
Oddometer: 2,394
Originally Posted by BryanCO View Post
Do you have the AltRider bars? I see the lever in the pic...
when i went down in the grass i had the triumph bars. now i have happy trails bars.
Old 02-22-2013, 05:18 AM   #678
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,895
Thanks,
Dave.
Yes. Just remove the plastic kick guard and you'll see what needs to be done to get the OE one off. Loosen the lock nut on the rose joint and spin off the OE lever. Then it's simply a reverse assembly. To adjust the height of the lever loosen the lock nut on the top rose joint as well and twiddle the rod one way or the other. The rod has a left hand thread one end and a right hand thread the other, unlike the BMW I owned where you had to completely remove the lever to adjust the height. German engineering? Absolute rubbish!
3 - 1 black Tigers. 955i+800XC (sold)+800XC=113000 miles of fun.
blacktiger is offline   Reply With Quote
Old 02-22-2013, 07:08 AM   #679
ducnut
Oddometer: 3,321
Are you implying that the HT bars keep the lever sufficiently off the ground?
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 02-22-2013, 08:37 AM   #680
fbj913
I ride
fbj913's Avatar
Oddometer: 2,394
I don't know. I was just answering the question about the bars I had on at the time...
Old 02-22-2013, 02:25 PM   #681
BryanCO
CO Rider
Oddometer: 506
Thanks - both fbj and jd. Looks like most (all?) crash bars leave the lever exposed.
BryanCO is offline   Reply With Quote
Old 02-22-2013, 08:21 PM   #682
mint julep
mint julep's Avatar
Oddometer: 187
Thanks fbj913 & blacktiger.
I'll be doing this as spring comes around.
Cheers,
Dave
mint julep is offline   Reply With Quote
Old 02-24-2013, 05:24 PM   #683
JWalton
How do I wheelie?
JWalton's Avatar
Oddometer: 22
Bluhduh Broken Lever...Uhggg.
I suppose it was going to happen eventually. At least it was the brake and not the clutch! Time to upgrade. Anyone replace their levers with the break-away type yet? Fitment? Other suggestions?
-JW
Mean Green Machine '13 Tiger 800XC
JWalton is offline   Reply With Quote
Old 02-25-2013, 01:00 AM   #684
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,895
-JW
Once you fit decent handguards you don't need special levers. Any decent pattern part http://www.triumph-online.co.uk/tige...le-14208-p.asp will do.
Old 02-25-2013, 06:12 AM   #685
Dirtysouth
Stud fee waived for noobs
Dirtysouth's Avatar
Oddometer: 4,976
Here's my bike a few days before I sold it. The buyer didn't want all the accessories so if anyone is interested in any of the items left, I have a thread in the fleamarket.
"...When your time comes to die, do not be like those whose hearts are filled with fear of death,
So that when their time comes, they weep and pray for a little more time to live their lives over a different way.
Sing your death song, and die like a hero going home." - Tecumseh
Dirtysouth is offline   Reply With Quote
Old 02-25-2013, 07:48 AM   #686
Dubl-A
SuckerDucker
Dubl-A's Avatar
Oddometer: 1,809
Originally Posted by DropinParts View Post
I wanted to let you guys know about the Saddlemen one piece seat I just purchased from Revzilla.
I'm a big guy and the riders portion of the stock two piece seat is too short for me (front to back). My butt is partially on the passenger seat, which after 30 minutes feels like I'm leaning on a sawhorse.
Because the riders portion of the Saddlemen seat tapers back about 1 1/2", it is MUCH more comfortable.
Here's a shot of the seat.
The only thing I thought might be a drawback was that it does not have the option to be placed in the higher position like the stock seat. It only mounts in the low position, but turned out not to be a problem at all.
Welcome to the BEST Tiger seat club!
Funny I feel it sits right between the high/low position. When I put the stock seat on I dont feel too much lower but more flat with the Saddlemen. I would however suggest they make it a two-piece as well.
Keep your $0.02 if it ain't going towards the bill
Dubl-A is online now   Reply With Quote
Old 02-25-2013, 04:18 PM   #687
backwoodsKLR
backwoodsKLR's Avatar
Oddometer: 9,719
Alt-Rider Rack and Givi Tracker 33L case...
2013 Tiger 800XC
Explore: Backwoods, MS
MS Tag-O-Rama Map / Jackson, MS Local Tag-O-Rama Map
backwoodsKLR is offline   Reply With Quote
Old 02-25-2013, 04:34 PM   #688
lmychajluk
Oddometer: 2,116
That seat does look comfy, but won't that channel collect water in the rain? Maybe OK in the summer to have the boys soaking in the tub, but when it's cooler out, I dunno....
-Lee
NE ADV Event Calendar (Request Additions here.)
2013 Triumph Tiger 800
2008 Suzuki SV650n (Sold... I miss that bike...)
lmychajluk is offline   Reply With Quote
Old 02-25-2013, 05:07 PM   #689
advtenn
advtenn's Avatar
Oddometer: 1,373
Originally Posted by cyclingtom View Post
Mine just took some minor alterations (notice the small socket ) to fit the XC. They seem to be quite sturdy and priced right.
After seeing these guards, I found them on sale at Motorcycle Superstore.
Right out of the box, they appear as if they will never work, but a little reshaping in a vice, and they fit great.
I removed the black, stock hand guard bracket and did not have to use the socket/spacer.
and as a bonus the guards come with summer and winter plastics.
I may loosen the banjo bolt and turn it up a bit...
Summer vs winter plastics..
bikes guns and shine
"My body thinks my brains gone crazy" ..........Corky McMillian
advtenn is offline   Reply With Quote
Old 02-25-2013, 05:32 PM   #690
advtenn
advtenn's Avatar
Oddometer: 1,373
OEM Heated grips
I can't find that discussion anywhere, I know I've seen here somewhere.
I have them..and I have a question..
Times are GMT -7.   It's 10:22 AM.
