Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 05-31-2013, 02:13 PM   #1096
live2ridetahoe
RN
live2ridetahoe's Avatar
Oddometer: 1,506
Played around with some of the 3M 1080 carbon wrap yesterday...
JG
live2ridetahoe is offline   Reply With Quote
Old 05-31-2013, 02:53 PM   #1097
MotoTex
Miles of Smiles
MotoTex's Avatar
Oddometer: 1,849
Originally Posted by TAMPAJIM View Post
I would argue that acrylic is a better choice for ADV motorcycle windshields. Polycarbonate is very tough stuff-you can hit it very hard with a hammer and nothing happens. In a fall it is very likely to take out the brackets and attachment points which could be very expensive. Acrylic will shatter before any such damage.
Replacement shields are only around $100. Headlight assemblies, fairing etc are much more expensive.
Finally the acrylic used by Cee Bailey and Madstad is aircraft grade and is pretty thick stuff so they are not fragile.
If you hit hard enough to bend the shield to where it bends things, chances are those things may get bent regardless of which flavor of plastic is there. An acrylic shield shattering in no significant way diminishes the forces at play.
On the KTM, the OEM shield is used beneath the Aeroflow as an assembly. The OEM part is poly. When I broke that acrylic Aeroflow shield, the poly OEM bent a lot. Enough to pinch my Zumo into the handlebar and break its display. When I picked the bike up the OEM bent itself back into place. No damage to anything other than the Zumo. And the shattered acrylic shield. I should mention that when the acrylic broke it left many long, sharp-pointy-end bits. Some large enough to go well into, um, soft stuff. That is one more thing I would prefer to engineer out of the equation should a collision occur.
With this knowledge the $100 replacement cost of the acrylic seems an expensive choice over a shield that isn't easily shattered, and, is warranted against breakage for three years.
Based on experience, with some degree of certainty, I may eventually put the shield in a position for harm to come to it. When this time comes, the shield needs to brush it off and keep working for me.
Stock Triumph is a polycarbonate. There's probably a good reason for this choice by the manufacturer.
I can also see your point. Acrylic functions well enough, and using acrylic helps keep the price point in a happy place. Same with replacement costs. I can't fault your argument, but there may be more to consider than replacement cost.
This is The Internet. Confirm for yourself anything you may see while visiting this strange and uncertain land.
MotoTex is online now   Reply With Quote
Old 05-31-2013, 09:21 PM   #1098
Dubl-A
SuckerDucker
Dubl-A's Avatar
Oddometer: 1,811
JG
Tight!
Keep your $0.02 if it ain't going towards the bill
Dubl-A is offline   Reply With Quote
Old 06-03-2013, 06:02 PM   #1099
Applevalleyguy
Oddometer: 28
Sidestand Shoe
I think that I saw this in this thread, but can't find it now. Can someone point me in the right direction?
Thanks,
Applevalleyguy is offline   Reply With Quote
Old 06-04-2013, 04:37 AM   #1100
PBee
_
PBee's Avatar
Oddometer: 9,429
Originally Posted by Applevalleyguy View Post
Sidestand Shoe,I think that I saw this in this thread, but can't find it now. Can someone point me in the right direction?
Thanks,
QUORN SCHNITZEL CLUB Est 2011.
When in the FLINDERS RANGES SA stay at the
ANGORICHINA VILLAGE
PBee is online now   Reply With Quote
Old 06-04-2013, 05:01 AM   #1101
fbj913
I ride
fbj913's Avatar
Oddometer: 2,405
Thanks,
touratech
altrider
maybe others, not sure.
fbj913 is offline   Reply With Quote
Old 06-04-2013, 07:48 AM   #1102
cug
Oddometer: 5,031
Thanks,
If you don't have a center stand that could interfere - I have one at home I would sell. But it does interfere slightly with the Triumph center stand. Either some grinding or no stand would make it work.
cug is offline   Reply With Quote
Old 06-04-2013, 08:10 AM   #1103
TAMPAJIM
Oddometer: 494
I had one that interfered with the centerstand. I mounted it backward and it worked fine. Looked funny though
__________
Jim
TAMPAJIM is online now   Reply With Quote
Old 06-04-2013, 08:21 AM   #1104
cug
Oddometer: 5,031
Don't think that would work:
I also wasn't in the mood of grinding it down. So far I never had an issue with the side stand sinking in, but I also live in a dry climate + avoid sand like hell.
Old 06-04-2013, 06:15 PM   #1105
ttime4four
ttime4four's Avatar
Oddometer: 273
Thanks,
I can confirm that the sidestand foot extender from Adventure Spec does not interfere with the OEM centerstand.
A fellow 800XC rider in my area informed me that the Touratech foot does interfere with the center stand.
'14 KTM 690 Enduro R
'14 BMW R nine T
ttime4four is offline   Reply With Quote
Old 06-04-2013, 08:15 PM   #1106
vanjoosten
Oddometer: 111
I bought this one from Wild @ Heart. It is super solid and does not interfere with the stock center stand.
vanjoosten is offline   Reply With Quote
Old 06-04-2013, 09:40 PM   #1107
Applevalleyguy
Oddometer: 28
Sidestand foot extender
Thanks to all that posted! I have ordered the Tourtech as they are in Seattle while Adventure Spec is in the UK, and Wild@Heart is in So Africa.
Old 06-05-2013, 05:17 AM   #1108
fbj913
I ride
fbj913's Avatar
Oddometer: 2,405
Oof, I was just going to tell you not to buy the Touratech one. Mine fell off after continuous tightening and the center stand issue is annoying. AltRider is the best I've seen.
Old 06-05-2013, 08:57 AM   #1109
OB1UK
OB1UK's Avatar
Oddometer: 61
Anyone know of anywhere in the UK where I can get one of those Raid Toolboxes or something similar for a Tiger 800XC?
Like this one:
OB1UK is online now   Reply With Quote
Old 06-06-2013, 12:35 AM   #1110
erikh58
Oddometer: 4
I bought mine here... It hasn't arrived yet, but I ordered just 2 days ago.
You can also find them on eBay.
http://www.dsbikeprotection.com/inde...gory&id_lang=1
Sent from my iPad using Tapatalk HD
erikh58 is offline   Reply With Quote
Times are GMT -7.   It's 06:20 AM.
