Old 11-09-2012, 08:32 AM   #1
Azmontana OP
Oddometer: 31
KTM 950 Scottoiler Question
Hello all,
I had a 990 Adventure until I had a crash and the bike was a write off. Anyway I took some of the trinkets that I had installed on the bike. One of them was the Scottoiler.
When I installed the scottoiler on the 990 I fitted the brass spigot on the right hand side of the engine and everything worked nicely. Since the accident I decided to buy a 950 Adventure but when I came to fit the scottoiler I found on the right hand side of the engine some piping already connected there, which confused me as this was not the case on the 990. I looked on the left hand side of the engine and there seems to be a nut without any piping connected to it, I was wondering if I can use this to connect to the scottoiler?
This is the right hand side of the engine.
This is the left hand side of the engine.
Any help would be appreciated, for those with 950A's and scottoilers where did you connect the vaccum tubing and valve on the engine?
Az
Azmontana is offline   Reply With Quote
Old 11-09-2012, 09:00 AM   #2
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,961
I believe what you are looking at is the vacuum tube that is used to balance the carbs (I think). There is one at the base of each carb body.
hard to tell in the pics.
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 11-09-2012, 08:15 PM   #3
Katoom119
Mmmm....Orange Kool-aid
Katoom119's Avatar
Oddometer: 1,837
+1
One side is used to balance the carbs, the other side is where the charcoal canister used to connect to the engine before the canisterectomy was done. I don't know enough about those to tell how they work, but if it runs off of a vacuum then you pull one of the bolts out, thread the stock brass spigot looking piece back in, and connect it to the Scottoiler.
Those who dance are considered crazy by those who do not hear the music.
I am not the same having seen the moon shine on the other side of the world. - Radmacher
5 Cylinders vs. Moab..........My East Tennessee.........Internships may go to Hell and I will go to Alaska
Katoom119 is offline   Reply With Quote
Old 11-10-2012, 12:03 AM   #4
Azmontana OP
Oddometer: 31
Ok thanks guys. I'll give it a go and see if it works. Thanks.
Old 06-27-2014, 06:52 AM   #5
B46LACK
Oddometer: 5
950 scottoiler
Just ran into this too, although i have ordered the 950 kit.. WTF Scottoiler?
What was the solution for this please??
B46LACK is offline   Reply With Quote
Old 06-27-2014, 07:56 AM   #6
Chewy750
Chewy750's Avatar
Oddometer: 52
950 and 990 kits are the same, the difference is which vacuum connection you use, on the 990 it is the lhs of the throttle boddies and on the 950 it is on the rhs of the carbs. The easiest to get to carb balancing spigot is the one to go for!
Chewy750 is offline   Reply With Quote
Old 07-09-2014, 01:56 AM   #7
B46LACK
Oddometer: 5
I put it on the left hand side of my 950 like in the picture above.
I emailed Scottoiler for support too, till today no reply. Impressive..
Old 07-14-2014, 05:00 AM   #8
B46LACK
Oddometer: 5
Seems to be working fine.. also had a problem with the positioning of the container as my shock is somehow longer than everyone else's. So it's now installed there but installed a little to the side, not 100% happy about it.. Shall I post a pic or is anyone familiar with this?
Cheers guys
Times are GMT -7.   It's 05:57 AM.
