11-09-2012, 11:37 AM
#1 |
Sunburnt
Oddometer: 987
How to make a GPX file
I have a list of Lat/Long coordinates that I want to load into my Garmin Oregon. How do I convert that list into a GPX file?
11-09-2012, 03:22 PM
#2 | |
Long Haul Adventurer
Oddometer: 3,168
Then select your output Waypoint form: GPX XML Your Lat/Lon formate needs to be correctly formed for whatever format you have chosen. That should do it. Cheers,
Cheers, Dan |
11-10-2012, 04:16 AM
#3 |
Bazinga!
Oddometer: 11,655
What Dan said.
And if your list is really short, you can just create a new Mapsource file, create individual waypoints and copy/paste the coordinates (in the correct formate for the way your preferences are set in Mapsource) to each waypoint.
dunno..... |
11-10-2012, 08:29 AM
#4 | |
Oddometer: 3,971
Once you have the data in any type of GPS file, you can then conver that file to another type of file with GPSBabble etc. Like Dave said, you can hand enter or copy data into a new MapSource file which you can save as .gpx, .gdb, etc.
Jerry Counts |
11-10-2012, 09:05 AM
#5 | |
Oddometer: 3,168
lat lon 58.41108413 41.58592 57.22838402 40.7857132 70.05699998 46.95699996 59.49240002 37.98660002 67.63560997 38.75359001 71.55788996 33.41797002 63.61753464 35.03917694 60.909576 37.682161 63.69418002 32.95169002 74.47082997 36.13531999 73.44022997 32.37234998 57.90172594 41.10980988 59.59259033 39.14574606 56.34080904 41.2351226 69.19094997 34.28232 74.20854002 32.87481003 74.26996998 33.45395998 73.65478498 37.379395 55.99088 40.35287004 68.30535002 42.13797997 68.38758001 40.57662997 61.38825417 35.71861259 58.50399971 40.2101326 69.02034606 34.20522502 58.11673156 41.25649444 60.23159981 34.90777024 69.03731002 42.48798997 73.94132 39.35123001 58.82200241 40.21845818 73.14184603 38.65380898 68.95672004 43.19627001 70.84662404 33.893423 57.23310471 40.88707924 72.15873001 37.88697003 74.437744 38.08007802 63.86806 44.70194003 72.33544903 38.01879901 60.60041 34.00449 68.20947999 41.25159999 It takes one click of a button to convert that text data to GPX XML data in a GPX formatted file and any GPX-aware program can read; including MapSource. What's easier than that? Cheers,
Cheers, Dan |
11-12-2012, 12:42 PM
#6 |
Oddometer: 3,971
WOW I never used GPS Babel, that is really friendly to convert text to a GPS file. Do you copy the text or will it convert a Word or Excel file direct? Not that I ever do more that one way lon/lat at a time.
Jerry Counts |
11-12-2012, 12:57 PM
#7 | |
Oddometer: 3,168
If you use Excel, just save the output as a CSV formatted file. Then chose the CSV input file option. If you are using Word, just save as a Plain Text (unformatted) file. If you have more information than just LAT/LON in columns then you need to have the proper "header" row above the data columns - like this: Lat, Lon, Name, 58.41108413,41.58592, name1 57.22838402,40.7857132, name2 70.05699998,46.95699996, name3 59.49240002,37.98660002, name4 67.63560997,38.75359001, name5 There are additional GPX as well as Garmin specific "headers" that will create the complete "extended waypoint info" such as: Address, City, State, Country, Phone. More than you wanted to know most likely but I've found it worth learning over the years. Cheers,
Cheers, Dan |
11-12-2012, 03:23 PM
#8 |
Sunburnt
Oddometer: 987
Thanks Dan.
If you are doing this from a CSV file just make sure you select comma separated values as the input format and not Columbus/visiontac V900 files (.csv) Took a few tries before I figured it out. |
11-12-2012, 04:54 PM
#9 | |
Oddometer: 3,168
Cheers,
Cheers, Dan |
11-12-2012, 08:18 PM
#10 |
Sunburnt
Oddometer: 987
Well it worked sort of. It put all of the longitudes east instead of west so all of the sites are over in China. How do I tell it I want west longitude?
11-12-2012, 08:23 PM
#11 |
Oddometer: 3,168
You must use "-" for W & S when you use dd.ddddddd format.
Cheers,
Cheers, Dan |
11-13-2012, 07:42 AM
#12 |
Sunburnt
Oddometer: 987
I tried putting quotes around them and they still end up in the east
11-13-2012, 08:04 AM
#13 | |
Oddometer: 3,168
47.000000, -120.000000 (is in the northern latitudes and the western longitudes) -45.000000, 55.000000 (is in the southern latitudes and the eastern longitudes) Cheers,
Cheers, Dan |
11-13-2012, 08:22 AM
#14 |
Sunburnt
Oddometer: 987
Got it, thanks for your help.
