Old 11-12-2012, 07:15 AM   #16
R100RT Mark
Oddometer: 309
Originally Posted by Wirespokes View Post
.....As for the vapor blasting - the name implies it's just water but I've heard it's some sort of media plus water. Correct?
Correct. Typically a light slurry of water, glass beads and detergent. Think of it as an aggressive washing process rather than something that will strip paint or etch metal.
Mark
Current - '74 TR5T : '93 R100R : '99 Gran Canyon : '06 ST3s
Past - Variety of British, French, Italian, Czechoslovakian, and German bikes from the '70s, '80s and '90s
R100RT Mark is offline   Reply With Quote
Old 11-12-2012, 10:00 AM   #17
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,776
Originally Posted by Bluethumb View Post
If you sand it off, with what and how?
Not a dumb question at all.
Personally I use a fine paint brush with nitromors paint stripper. Paint the paint stripper onto the powder edges that need exposing, wait a few seconds for the stripper to soak in, you can see the colour change, and then lift the softened powder with a sharp knife blade. Once it's all off I polish it with a piece of fine emery on a piece of wood to keep it flat. Finish it off with solvol autosol. Takes a while to get into doing it but it's very therapeutic if you're that way inclined.
I bought a few covers on ebay a few years ago when they were cheap. Got them powder coated as a job lot and have swapped them out when needed. The covers I swap them with get sent off when I have enough for another batch.
Rob Farmer screwed with this post 11-12-2012 at 10:25 AM
Rob Farmer is offline   Reply With Quote
Old 11-12-2012, 10:15 AM   #18
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,776
You can use different types of media for different finishes. Just do a search on Youtube for some examples but it's essentially a slurry pump that circulates a mix of water and blast media. The slurry is accelerated using compressed air. The big advantage is that it's a dustless process and the water provides a cushion for the blast media stopping it cutting the material being blasted.
This is the swinging arm of the bike in my previous photograph
Close up of the surface. If it's done well the surface is peened making it easy to keep clean.
You can buy small machines that are ideal for bike parts, they aren't cheap though. They are getting very common in the UK with a cylinder head clean up costing around $25
http://www.vapormatt.com/products_vapormate_1_page.htm
Rob Farmer screwed with this post 11-12-2012 at 11:02 AM
Old 11-12-2012, 03:06 PM   #19
ywouldi
Oddometer: 46
I've been thinking about soda blasting. You can leave the engine fully assembled and it's pretty safe stuff, rinses off with water and not too abrasive. Seems to leave a nice finish and I've been quoted 100 to clean the engine and bevel box completely. Any one else tried that?
ywouldi is offline   Reply With Quote
Old 11-12-2012, 03:12 PM   #20
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,552
Yes. It gets oil, dirt, and paint off nicely, but will not remove aluminum oxide. It's not aggressive enough to get down to bright metal. At least not with the soda and pressure that I was using. No matter how long I hovered in a spot it never seemed to leave a mark on the metal. It's also not nearly as easy to rinse off as you'd think. You have to rinse it for a LONG time with hot water to get all the soda off. Also, you should note that unlike glass bead or other blasting media, soda is not chemically inert. It will corrode steel and aluminum parts if not rinsed off VERY well.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Airhead Wrangler screwed with this post 11-12-2012 at 04:14 PM
Airhead Wrangler is online now   Reply With Quote
Old 11-12-2012, 04:07 PM   #21
Bluethumb OP
Oddometer: 130
Is soda blasting something that can be done by buying a simple set-up? I have an air compressor.
I spent 6 hours, two cans of de-greaser, 2 cans of carb cleaner, a bunch of Simple Green, scrub pads, fine steel wool, and lots and lots of scrubbing until my hands are beat-up. The bike is clean but that's about it. The aluminum is still discolored plus there's grease is all kinds of crevices I can't get to.
By the way Supershaft, WD 40 and scrubbing didn't work for me. I soaked my FD, waited, soaked it some more, then scrubbed it like crazy. Results? Nothing!
Bluethumb is offline   Reply With Quote
Old 11-12-2012, 05:30 PM   #22
supershaft
because I can
Oddometer: 9,116
It doesn't work if it's real bad or even kinda bad. That takes bead blasting in my expereince. I haven't tried what Rob is showing. Some people let that staining crap set on them for a LONG time. Not me.
Old 11-12-2012, 05:32 PM   #23
supershaft
because I can
Oddometer: 9,116
I don't care for poweder coat on sealing surfaces. The stuff is sometimes so thick it causes issues.
Old 11-12-2012, 06:39 PM   #24
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,205
There are coarser grades of soda that cut better. Using the plain old washing soda from the grocery store worked very well. And so did the small boxes of Arm and Hammer - took two of them to clean up a long dormant airhead.
A trick for handling the stubborn staining that just won't come until the parts can be blasted, is to wipe some silver paint on a rag and then rub it on the aluminum. It'll blend right in and be totally invisible.
Old 11-12-2012, 10:45 PM   #25
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,776
I wouldn't dream of leaving powder on any sealing surface. You have to strip it off. Paint stripper and a craft knife do the job nicely.
Old 11-12-2012, 11:22 PM   #26
Hearse
Project n'gagi
Hearse's Avatar
Oddometer: 148
What about a high pressure water gerni? Say 4000psi that should do it shouldn't it?
Project n'gagi begins 07-11-2012 -- Get involved!!
2006 Honda VTR1000f
1975 BMW R90/6
Hearse is offline   Reply With Quote
Old 11-13-2012, 10:51 AM   #27
Bluethumb OP
Oddometer: 130
What is a "sealing surface"? Are you talking about the mating surface where a gasket goes? Like the back of a timing chain cover? So once a part is powder coated, the mating surface has to be taken back down to original?
Old 11-13-2012, 02:33 PM   #28
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,776
That's what I was talking about along with the surface for the bean can and crank seal. The threads all need to be cleaned out as well.
Times are GMT -7.   It's 02:37 PM.
