Old 11-10-2012, 07:29 AM   #1
Sabre170 OP
Sabre170's Avatar
Oddometer: 283
Interchangeable Fork Lowers?
How interchangeable are fork lowers between different airhead models?
I've got a '78 R100/7 and am looking to put a set of r65LS fork lowers on my 100/7 forks (maintaining the rest of the fork assembly 100/7 parts.....just swapping the fork lowers.
Can I do this or is there a compatability issue?
Sabre170 is offline   Reply With Quote
Old 11-10-2012, 03:54 PM   #2
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,068
The easiest way to check a specific part for compatibility is to look up each respective part on a fiche such as Max BMW's.
Having said that, I know that the R65 LS lowers are the same part numbers as the lowers on my R80 ST. (I have a set hanging on the garage wall). And the caliper lugs are for Brembo calipers. If your bike has ATE calipers, you may have a mismatch - not sure since I never dealt with ATE brakes.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is online now   Reply With Quote
Old 11-13-2012, 05:24 PM   #3
Sabre170 OP
Sabre170's Avatar
Oddometer: 283
Yeah, mine has ATE calipers. I am pretty sure i can't interchange them. Unless someone can tell me I can, Im not going to take the gamble.
Old 11-13-2012, 06:52 PM   #4
Voltaire
Bored Of The Rings
Voltaire's Avatar
Oddometer: 1,626
I put an ATE front end on my racer only to find one slider was bent....had a set of Brembo forks from a later bike and used the slider and internals. only mod was to drill out the bottom plate of the ATE lowers to accept the larger 8mm bolt ( from memory)
You want the opposite so the lower fixing bolt may be too small.
Personally I like the ATES, 13 mm bar m/c, stainless hoses and cast iron discs haul up my racer pretty damn good.
Sold of the Brembos....pfft.
The Ractech kit and linear springs make for a good ride...but saying that its not a road bike.
Also have an R65 and the fork lowers have the axle in the centre and I think they might be a bit shorter too.
Voltaire is offline   Reply With Quote
Times are GMT -7.   It's 10:36 AM.
