Old 03-12-2013, 12:42 PM   #16
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,410
Anybody have a pic of the PMB setup mounted? If im reading it correctly, the damper mounts backward on the frame and the pin mount on the triple clamp. My only concern is if the damper pivot mounts directly over the steering head. I talked to Scotts about this issue a couple years ago and he explained that they need to be on the same axis.
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 03-12-2013, 12:58 PM   #17
rider914
Agnostic Adventurer
rider914's Avatar
Oddometer: 2,461
Originally Posted by Zuber View Post
PMB has a new mount for the 950/990 Advs using the stock triple clamp>
http://www.promotobillet.com/catalog...roducts_id=752
Their dampers are good, with high speed damping. You can mount a Scotts on it also if you get an extra long arm.
Given the parts shown in the link, I really don't see how that will work with a Scotts or a PMB/Fastway damper (very similar to Scotts).
Somebody buy one and take pics
-M
'05 950ADV
'04 525EXC D/S
'07 Tiger1050
Will herd cats for beer (... but I rescue puppies for free )
SmugMug (coupon: bLfv2vBXZicd6)
rider914 is offline   Reply With Quote
Old 03-12-2013, 06:33 PM   #18
rossguzzi
990 Adv.
rossguzzi's Avatar
Oddometer: 1,038
If it does fit/work it would be a great solution !
rossguzzi is offline   Reply With Quote
Old 03-12-2013, 09:50 PM   #19
motokeith
Oddometer: 111
Pics in this thread...
http://www.advrider.com/forums/showthread.php?t=806201
motokeith is online now   Reply With Quote
Old 03-13-2013, 06:11 AM   #20
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,410
Thanks for searching that out,,,,, I was wrong in the way I thought it mounted. But it still makes me leary because the pivot center is so far from the center of the steering head. The moment will be inconsistant as the bars are turned.
Old 03-13-2013, 09:03 AM   #21
rider914
Agnostic Adventurer
rider914's Avatar
Oddometer: 2,461
Originally Posted by motokeith View Post
Interesting, but the sliding action between the lever arm and tower pin cannot be good in the long run
-M
'05 950ADV
'04 525EXC D/S
'07 Tiger1050
Old 03-13-2013, 01:00 PM   #22
muscly
muscly's Avatar
Oddometer: 74
Hello, I have rox raisers less Than 2" lift and original handle bar.
Will steering damper and a RC high be higher or lower Than my current Running?
Why I love Offroad bikes?
Because 99,999% of the earth,
are not pavement.
muscly is offline   Reply With Quote
Old 03-13-2013, 05:12 PM   #23
rossguzzi
990 Adv.
rossguzzi's Avatar
Oddometer: 1,038
I contacted Promotobillet and this was their response.
Hey Ross, the damper set we have is intended to work with our damper, we've not tested it on the Scotts, I'm unsure if it would fit. The main reason being that the transfer arm we use (the piece that connects to the bottom of the stabilizer) is of different length than the Scotts transfer arm, also that arm has a 'dogleg' bend in it as well, whereas ours just comes straight out to meet the post.
Will Huffman
Customer Service/Sales
Pro Moto Billet & Fastway Performance
Old 03-13-2013, 06:21 PM   #24
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,410
Will Huffman
That's kind of a BS reply. I've had plenty of Scotts dampers over the years and they don't all use the same arm. Some longer, some shorter and some with doglegs in them, you can buy an arm for any application you can dream up from Scotts. I understand the reason he gave you that answer though,,,, because they would rather you buy their product. A quick search around the internet reveals the Scotts and the PMB damper are interchangable as far as mounting. GPR also fits the mounting.
Old 03-13-2013, 06:28 PM   #25
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,410
Here's another option but at the price you may as well go with the full Scotts setup.
http://www.rallemoto.com/contents/en-us/d27.html#p27
Times are GMT -7.   It's 08:14 PM.
