Old 11-10-2012, 11:58 AM   #1
Pepperjack OP
Oddometer: 135
2012 model, KTM 990, adv : can't open fuel filler...????!!!
Hey gang...
On my 990 I can't open the little protective cap which stops dust getting into the key slot on my right hand side fuel filler cap. I can life it up about 3mm but no further...I have used quite a bit of force, and have stopped as I don't want to break it..!
It's as if a little rock or something has gotten in there but I have poured water over it..and also blown in there as hard as I can several times...no joy.
Wierd..!!! Anyone else had this issue..??
Sent from my iPad using Tapatalk
e-mail : Ian@gilian.net
Mobile : 0408 52 88 00
Spot : http://ozadv.com/ian
Rides : '14 BMW R1200GSA
Pepperjack is offline   Reply With Quote
Old 11-10-2012, 12:23 PM   #2
Masa
Masa's Avatar
Oddometer: 301
It has happened to few of us..
http://www.advrider.com/forums/showthread.php?t=735100
Masa is offline   Reply With Quote
Old 11-10-2012, 12:50 PM   #3
Ladukebob
lost in hood river
Ladukebob's Avatar
Oddometer: 1,853
Ktm warrantied mine and replaced it. Be sure to replace the key barrel in the new one with your original so you can use the same key.
You don't know what you don't know, 2011 WR250, 2015 ktm 690r
findLadukebob
Ladukebob is offline   Reply With Quote
Old 11-10-2012, 01:04 PM   #4
Pepperjack OP
Oddometer: 135
Damn...that sucks...can I just force it open and break it..not keen on not being able to open my tank filler...I guess I can fill the left then let it equalize tho..? How long does that normally take..is it practical to just do that, at a servo..or do you need to wait a while etc...I'm planning to ride today..!
Sent from my HTC One XL using Tapatalk 2
Old 11-10-2012, 01:05 PM   #5
Pepperjack OP
Oddometer: 135
I'm thinking ...I'll take a video of the problem..stick a screwdriver under and lever the hell out of it..then they can replace, yes, under warranty still, thank f..k
Old 11-10-2012, 01:10 PM   #6
Ladukebob
lost in hood river
Ladukebob's Avatar
Oddometer: 1,853
Mine would stick about every other fill up. And the last time it stuck it pissed me off and I just pried it up and snapped it off. If the bike wasn't still under warranty I probably wouldn't have worried about it too much. But since it was it was worth getting it taken care off. Took it into the dealer and they had one in stock. Changed out the barrel and I was out of there in about 30 minutes.
findLadukebob
Old 11-10-2012, 02:19 PM   #7
billbob412
Oddometer: 11
Don't break it , It needs lube. I used some Superlube on mine, hasn't given me a problem since.
billbob412 is online now   Reply With Quote
Old 11-10-2012, 03:00 PM   #8
knobbyjoe
knobbyjoe
knobbyjoe's Avatar
Oddometer: 524
Mine stuck. Oiled and then worked it up and down with a piece of wood and hammer. Just taped it up and down for awhile and it unstuck. If you pry it up in one motion it might break.
KTM 400 XCRW with Thumper Racing 450 kit and 450 cam 2007
KTM 450 XCRW with Christini AWD and Plated 2008 now has 520 Thumper Racing kit
KTM 990 Adventure 2008
knobbyjoe is offline   Reply With Quote
Old 11-10-2012, 03:41 PM   #9
Ladukebob
lost in hood river
Ladukebob's Avatar
Oddometer: 1,853
Mine was more of a defective part than a lube problem. And that's why it was covered under warranty.
findLadukebob
Old 11-10-2012, 06:31 PM   #10
xcflyn
xcflyn's Avatar
Oddometer: 1,157
http://www.advrider.com/forums/showthread.php?t=763543
xcflyn is offline   Reply With Quote
Times are GMT -7.   It's 03:27 PM.
