Old 11-05-2012, 03:44 PM   #1
supershaft OP
because I can
Oddometer: 9,116
Velocity stack sources?
I found one that has even close to what I am lookng for. Do you guys know of any out there?
Old 11-05-2012, 03:53 PM   #2
Houseoffubar
fine beer sampler
Houseoffubar's Avatar
Oddometer: 1,790
I looked around, and did not see much either. do you have some dimensions? I may be able to make a set for you.
Old 11-05-2012, 04:04 PM   #3
bikerfish
flyfishandride
Oddometer: 1,625
you know everyone is gonna tell you your gonna blow up your engine! but, I'd like to know a good source as well, hell with the engine!
bikerfish is offline   Reply With Quote
Old 11-05-2012, 04:23 PM   #4
Renner
rockin' the toaster
Renner's Avatar
Oddometer: 2,247
maybe somewhere here:
http://www.piercemanifolds.com/product_p/52840.001.htm
"If you want to fix it with a rock, you have to stick to stone-age technology" -Anton
"...solving the latest crisis that is preventing my Airhead from taking me to the bar." -Beater-
Renner is offline   Reply With Quote
Old 11-05-2012, 05:01 PM   #5
Voltaire
Bored Of The Rings
Voltaire's Avatar
Oddometer: 1,609
http://www.bevelheaven.com/
I just ordered one for my 36's as it fell off during a race recently.....wondered why the guy passing me was waving.....
They have the 40 mm ones on special, I'm going to wire them on now.
Voltaire is offline   Reply With Quote
Old 11-05-2012, 05:39 PM   #6
supershaft OP
because I can
Oddometer: 9,116
People have been telling me that I am going to blow up my engine for at least 40 years now. "You can't do that!" "That will never work!" It's a good thing I am pretty adept at knowing who to listen to.
After looking for stacks I decided to try again with my cut off stock ones. Maybe it will work this time.
First off I need to find some aluminum tubing and machine a longer velocity stack/snorkel junction. The same thing as stock but with a 3/4" longer smaller OD. Then I can use the first half inch of the stock stack to hold the junction in place and then hose clamp on a stack from the inside of the box. I basically need just a bell mouth in order to keep it as short as possible because I already have the length of the snorkel. 49.7mm ID and about as short as possible is what I need.
supershaft screwed with this post 11-05-2012 at 07:36 PM
Old 11-05-2012, 07:16 PM   #7
Big Bamboo
Aircooled & Sunbaked
Big Bamboo's Avatar
Oddometer: 3,724
Try your local Midas muffler dealer or similar. The have the stock and could fab you up something.
Big Bamboo is offline   Reply With Quote
Old 11-05-2012, 07:30 PM   #8
supershaft OP
because I can
Oddometer: 9,116
Thanks guys because now after going back and forth a few times and now having a shorter stack setup that so far hasn't bounced loose, I am 110% sure that it is running way stronger everywhere above 3k rpm with the shorter stacks. Big diff! Way more intake noise too but so be it. If I can't get the rubber stacks to stay put, I am definitely going to fab a setup for some metal bell mouths. That's really all I need and what I am going to call them from here on out since my snorkels are the 'stack' portion of my stacks. If that makes sense!
I hope I am helping someone out there but remember that I have already done a bunch of mods before I got to moding my airbox setup. Before the raised CR and port work what I have done would have KILLED my midrange! But not now. It is a different animal now! My setup has tons more midrange now! The best thing about 336's! Yea!
Old 11-05-2012, 09:01 PM   #9
Uncle Pollo
happy cachiporra
Uncle Pollo's Avatar
Oddometer: 48,108
Why?
Uncle Pollo is offline   Reply With Quote
Old 11-05-2012, 09:58 PM   #10
supershaft OP
because I can
Oddometer: 9,116
8.5:1 to a guestimated 10.0:1 CR. 44mm intake valves in place of 42's with a lot of port reshaping. Dual plugs with two .7 ohm Dyna coils with the stock bean can advance curve remapped. All on top of a lot of mods I had done earlier. Then I basically eliminated the top of my square airbox and shortened the stock velocity stacks by three of four inches for even more.
Old 11-06-2012, 01:52 AM   #11
pommie john
pommie john's Avatar
Oddometer: 1,466
I bought mine from here. They're in Australia but they might send them to the USA
http://www.jntperformance.com.au/index_c269035.html
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt.
Bertrand Russell
pommie john is offline   Reply With Quote
Old 11-06-2012, 07:01 AM   #12
US_Marshall
Oddometer: 46
I picked up some off the Bay. $50 for 4 off them, allows you a couple spares to work with.
http://www.ebay.com/itm/400319735164
The one on the left (right carb) has a filter I made from an extra K&N, it is too restrictive. The one on the right (left carb) is just a screen.
US_Marshall is offline   Reply With Quote
Old 11-06-2012, 07:11 AM   #13
RGregor
Oddometer: 465
This guy over here would make them according to your specs.
http://www.mactrumpet.de/
Don't know if he ships to the USA.
RGregor is offline   Reply With Quote
Old 11-06-2012, 07:15 AM   #14
backdrifter
Wannabe rider
backdrifter's Avatar
Oddometer: 1,364
This place seems to have quite a bit of custom velocity stacks available. Their prices seem pretty reasonable too.
http://www.velocity-of-sound.com/
"We are very good at preparing to live, but not very good at living."
-Thich Nhat Hanh
1973 BMW R60/5:
http://www.advrider.com/forums/showthread.php?t=608166
backdrifter is offline   Reply With Quote
Old 11-06-2012, 02:20 PM   #15
supershaft OP
because I can
Oddometer: 9,116
Thanks pj! I haven't looked through them all yet but so far they are IMO the best looking ones I have seen. I could be wrong but I am thinking that style bell mouth works the best. It also happens to be real close to what BMW used in rubber.
I should have waited until I read everyone's posts! Thanks everyone! Some good sources!
supershaft screwed with this post 11-06-2012 at 02:25 PM
Times are GMT -7.   It's 02:32 AM.
