Old 11-10-2012, 05:39 PM   #1
640Pilot OP
640Pilot's Avatar
Oddometer: 97
950 Adventure axle puller
Guys,
Just wanted to set up an axle puller on the front of the 950, checking online so far I can get confirmation of fitment or find a specific brand that clearly says it'll fit or that will give me a direction on internal axle sizes etc.....anyone got a particluar brand they've fitted and can offer some advice...
Thanks in advance
Cheers
950 Adventure
FE 550 Husaberg
82' FXR Harley Davidson
So much dirt...so little time...
640Pilot is offline   Reply With Quote
Old 11-10-2012, 05:45 PM   #2
Nailhead
Free at last!
Nailhead's Avatar
Oddometer: 6,328
I got a Zip Ty Racing axle puller last year-- works great.
Not much more to it than that.
-Chris
'7? Benelli 650S, '80 BMW R100 RS, '93 Ducati 900 SS, '07 KTM 990 Adventure
Nailhead is offline   Reply With Quote
Old 11-10-2012, 07:15 PM   #3
sonoran
you already know
sonoran's Avatar
Oddometer: 25,639
Tip: unscrew the axle nut until it's about to come off, give it a whack with the palm of your hand and the axle will push out far enough on the left side for you to grab it and pull it out.
Or buy the ZipTy.
sonoran is online now   Reply With Quote
Old 11-10-2012, 08:02 PM   #4
TheMuffinMan
Forest Ranger Magnet
TheMuffinMan's Avatar
Oddometer: 6,376
Or buy the ZipTy.
That doesn't work for me.
Touratech makes a nice one, small enough to go in the tool kit. Put the big end in the axle, and push.
http://www.touratech-usa.com/Store/2...l-Tool-KTM-LC8
"To strive, to seek, to find, and not to yield."
"You don't cross the mountains, they let you through."
KTM 525 XC-W // KTM 950 Adventure
TheMuffinMan is offline   Reply With Quote
Old 11-10-2012, 08:09 PM   #5
sonoran
you already know
sonoran's Avatar
Oddometer: 25,639
A little axle grease goes a long way...
Old 11-10-2012, 08:36 PM   #6
TheMuffinMan
Oddometer: 6,376
I always grease up my axles, quite well. There's not enough to grab ahold of with the nut method, and there's too much resistance even when the wheel's unloaded.
Old 11-10-2012, 08:38 PM   #7
640Pilot OP
640Pilot's Avatar
Oddometer: 97
I found the same actually mate, even on a clean well greased axle.....just took a look and will order a zip ty unit add that to the axle problem solved and happy days,
Thanks for the input guys
Cheers
950 Adventure
FE 550 Husaberg
Old 11-11-2012, 12:41 AM   #8
dmn0507
dmn0507's Avatar
Oddometer: 353
Am I the only one using a piece of broomstick to push out the axle?
Works great, cheap, lightweight, eco-friendly.
dmn0507 is offline   Reply With Quote
Old 11-11-2012, 02:02 AM   #9
Peanuts
Peanuts's Avatar
Location: Beautiful but often rainy North Yorkshire, UK
Oddometer: 1,736
A friend makes these
Peanuts is offline   Reply With Quote
Old 11-11-2012, 03:54 AM   #10
K2m
....58....
K2m's Avatar
Oddometer: 2,238
This method with a hole drilled through both sides slightly larger than the screwdriver ....... Works a treat with no weight added to the bike.
The News, those who are trying to control what we think, do not want us to see.
http://www.presstv.ir/live.html So good the British Gov. Banned it !!!
http://rt.com/on-air/rt-america-air/
K2m is offline   Reply With Quote
Old 11-11-2012, 04:04 AM   #11
Bumpaman
Location: Foot of the Sangre de Cristos and Music City, TX.
Oddometer: 164
+1 on the Zip Ty
Bumpaman is offline   Reply With Quote
Old 11-11-2012, 04:39 AM   #12
Blackbert
Factory Rambler
Blackbert's Avatar
Oddometer: 1,059
Honestly, have you ever heard of somebody looking back on his life thinking: "Oh, I should have travelled less and mowed the lawn more often"? (Pumpy)
want to save on Smugmug? use this code (VoUO8M1ukmnMY)
Blackbert is offline   Reply With Quote
Old 11-11-2012, 04:41 AM   #13
Sporting Wood
I <3 Energizer Bunny
Sporting Wood's Avatar
Oddometer: 896
Yup. If it needed one, it would have come with one.
Loosen bolt, tap, insert screwdriver if necessary and pull.
Sporting Wood is offline   Reply With Quote
Old 11-11-2012, 06:28 AM   #14
Hootowl
Oddometer: 1,280
Or a piece of schedule 40 plastic water pipe
Keep it Wild, Keep it Free
'07 990A
'12 Super Tenere
Hootowl is online now   Reply With Quote
Old 11-11-2012, 07:56 AM   #15
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,178
Not quiet so!
Mine was sticking badly. Some black PTFE coating made it very hard to come out.
I constructed a piece of pipe, screwing in the place of the aluminum nut and slightly slimmer than the fork's hole. It is heavy but works well. It also helps to sandpaper the axle to clean the black paint that makes it sticky.
Cheers.
Times are GMT -7.   It's 10:37 AM.
