Old 11-10-2012, 05:44 PM   #1
ktmMike OP
roadscout
ktmMike's Avatar
Oddometer: 1,248
Eek KTM 450/520/525/530 EXC OWNER-BUILT SUPERMOTO Thread
I am thinking about turning a 2011 KTM 530 EXC into a SUPERMOTO, and I am looking for as many ideas as possible.
I'm guessing that many of you have already built KTM EXC Supermotos.
Please post lots of photos and specs for your EXC Supermoto.
What brands/WIDTHS of rims and tires are you running?
I am especially interested in seeing close-up photos of any clearance issues between the wider tires and the chain/swingarm/silencer etc.
KTM MIKE . . . . . . . KTM EQUIPPED SINCE 1999
three 640's (sold), two 950's (sold),
530 EXC Supermoto, 690 SMC, 990 SM-R
ktmMike is offline   Reply With Quote
Old 11-10-2012, 06:06 PM   #2
smokeeater495
smokeeater495's Avatar
Oddometer: 602
You might want to check out www.supermotojunkie.com. Lots of info there.
Harley, been there done that. Don't want to be a pirate.
smokeeater495 is offline   Reply With Quote
Old 11-10-2012, 06:42 PM   #3
Chris618
Chris618's Avatar
Oddometer: 846
04 400 exc, 5" rear rim with cush hub and 160/60 Pilot power, tight fit, rim pushed to the rear, no chain rub. Have since installed smr swingarm which is wider up front.
02 520 exc, same wheels as above
I have this lying around (less rotor) if you want to buy also forks and shock off 06 560smr I would sell.
Chris618 screwed with this post 11-11-2012 at 05:09 AM
Chris618 is offline   Reply With Quote
Old 11-21-2012, 03:23 PM   #4
smokeeater495
Oddometer: 602
I think the easiest way to convert an EXC into a sumo is buying a wheel set for a KTM SMR. It will bolt up with no muss/no fuss.
Old 11-23-2012, 01:13 PM   #5
ktmdude2002
Lost in transition
ktmdude2002's Avatar
Oddometer: 63
How much for the forks & shock?
Pinch it, pinch it, pinch it.....oh hell!
ktmdude2002 is offline   Reply With Quote
Old 08-27-2013, 10:25 AM   #6
_anatic
Plated
_anatic's Avatar
Oddometer: 1,157
Originally Posted by ktmMike View Post
I am thinking about turning a 2011 KTM 530 EXC into a SUPERMOTO, ...
No pics?
edit: Steve at Tracey's says: "If you see Mike again, tell him he has failed us by not sending pictures of his bike!!!"
Pisgah Forest Ridin'
_anatic screwed with this post 08-27-2013 at 10:44 AM
_anatic is offline   Reply With Quote
Old 08-27-2013, 04:57 PM   #7
ktmMike OP
roadscout
ktmMike's Avatar
Oddometer: 1,248
Originally Posted by _anatic View Post
No pics?
I forgot all about this thread!
Yeah, I guess I need to take some pictures of the "finished" supermoto. I've been so busy "test riding" it that I haven't really thought much about pictures.
Old 09-05-2014, 06:26 AM   #8
_anatic
Plated
_anatic's Avatar
Oddometer: 1,157
Again I say...
No pics?
Just yankin' Mikes chain.
Got a set of wheels from BLINKER 152 but he need to keep his sprocket support for his rally bike.
Originally Posted by BLINKER 152 View Post
fancyindigo being otherwise occupied was nice enough to let me borrow her's.
With everything working good i needed to get my own. When I looked in the hub I found a sticker.
Musta fell off James'. Yup, that's what I need.
But that number has been superseded. OK...
Looks good.
Turns out I needed this.
1.5mm smaller.
All good now.
Times are GMT -7.   It's 11:48 AM.
