Old 11-11-2012, 07:04 AM   #16
Al Tuna
PUI... Deal with it
Al Tuna's Avatar
Oddometer: 14,005
I click on a thread... and common sense has me beat every time.
Al Tuna is online now   Reply With Quote
Old 11-11-2012, 07:20 AM   #17
DirtDabber
cultural illiterate
DirtDabber's Avatar
Oddometer: 8,282
The title did not say need A-hole.
Hiya Tuna.....
I wonder where that road goes?
DirtDabber is offline   Reply With Quote
Old 11-11-2012, 07:24 AM   #18
Al Tuna
PUI... Deal with it
Al Tuna's Avatar
Oddometer: 14,005
Hiya Tuna.....
Old 11-11-2012, 09:16 AM   #19
JStory
JStory's Avatar
Oddometer: 2,857
How exact do your holes have to be? An electrical knockout cutter can cut
your round hole in seconds. A 3" conduit knockout is about 3.5".
Jeff
"He who makes a beast of himself gets rid of the pain of being a man." Dr Samuel Johnson.
JStory is offline   Reply With Quote
Old 11-11-2012, 01:13 PM   #20
Bloodweiser OP
honestly
Bloodweiser's Avatar
Oddometer: 2,618
have some wiggle room. It's a cutout for a tach.
Tach body = 3 3/8"
Bezel is ~1/4"
I'd like it to be as snug as possible,
guess I could pad it out with some rubber or electrical tape.
Bloodweiser is offline   Reply With Quote
Old 11-11-2012, 01:44 PM   #21
MotorradMike
MIL-TFD-41
MotorradMike's Avatar
Oddometer: 1,018
Is there a reason you can't use aluminum?
Things get easier.
Mike
So far, everything that has surprised me has been completely unexpected.
BMW R1100RS
MotorradMike is offline   Reply With Quote
Old 11-11-2012, 04:20 PM   #22
speedracertdi
speedracertdi's Avatar
Oddometer: 985
Jigsaw, fine tooth blade, and a little WD-40. You'd be there all week with a Dremel.
Roads? Where we're going we don't need roads.
-Doc Brown
speedracertdi is offline   Reply With Quote
Old 11-12-2012, 03:54 AM   #23
josjor
Location: The largest geological formation in the U.S.A.
Oddometer: 2,919
With the tools you have I would just chain drill it.
1. Mark your 3 3/8 circle.
2. Use an 1/8" bit to drill a series of holes that touch/almost touch around the INSIDE perimeter of your mark.
3. Once you're all around the circle, you can knock out or wiggle the piece to remove the center.
4. Smooth and fit the final hole with a half-round file.
Should take you about 15-20 minutes with a good bit. Over the course of four years in the USAF working on bombers and tankers I would be afraid to count the number of holes I've cut this way.
Neutiquam erro.
Originally Posted by Stagehand View Post
listen mister, we didnt evolve porcelin shitters just so we could squat to take a shit, like monkeys.
josjor is offline   Reply With Quote
Old 11-12-2012, 04:54 AM   #24
jules083
jules083's Avatar
Oddometer: 4,043
You need one hole right? Ever plan on drilling a hole that size again?
Go to a machine shop. By the time you mess around with getting it 'close' you should be able to get it done for a few dollars.
Otherwise I'd probably chain drill it or use a jigsaw. I'd probably make a practice cut inside the hole with a jigsaw to see how it looks then go from there.
COBDR and UTBDR on my klx250:
http://advrider.com/forums/showthread.php?t=1003485
jules083 is offline   Reply With Quote
Old 11-12-2012, 05:28 AM   #25
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,400
For round holes in sheet metal, use a chassis punch of the desired size. See here: http://www.mcmaster.com/#chassis-punches/=k4qaw6
(shipping is fast from this company)
Taking it to a machine shop is very likely to have you end up paying a minimum one hour charge which will be at least $60, unless the shop is small and has nothing else to do or you know somebody who works there. This is especially true if you ask them to do both the hole and the rectangle cutout. A waterjet shop is almost certain to charge you a minimum one hour fee. The abrasives in the water are not cheap and they are generally not reclaimable.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt screwed with this post 11-12-2012 at 05:34 AM
LuciferMutt is offline   Reply With Quote
Old 11-12-2012, 08:55 AM   #26
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 14,614
+1 on aluminum -- it works very nicely with woodworking tools (lower the speed), and looks great - - - - I grok using material that's on hna, but there no need to make things tough on yourself . . ..
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance. T.R.
Old 11-12-2012, 12:56 PM   #27
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,720
Go buy one of them diamond coated round hack saw blades.About $5.00 or less. Drill one hole about 1/2", put blade through and install on hack saw. Cope away....!
Have tools, will travel!
Old 11-12-2012, 08:20 PM   #28
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,699
Scroll saw, jig saw.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is offline   Reply With Quote
Old 11-13-2012, 02:28 PM   #29
ttpete
Oddometer: 6,039
They want $320 for a 3" Greenlee punch.....
If there's only one hole, I'd buy a Harbor Freight jigsaw and cut it and then have a jigsaw for other projects.
Old 11-13-2012, 07:50 PM   #30
P B G
Oddometer: 10,001
Just buy an appropriate hole saw, Then use it to drill a hole through 1/2" wood (plywood is fine).
Clamp the plywood over where you want your hole, and remove or shorten the central drill so it doesn't protrude too far, you want the hole-saw into the plywood before you start.
Second the handle to keep it from torquing on you, but in addition to the plywood you won't wander off center on the material.
Times are GMT -7.   It's 10:58 PM.
