Old 11-11-2012, 05:12 AM   #1
woodly1069 OP
woodly1069's Avatar
Location: Louisville, KY...really too far from the hills!
Oddometer: 1,989
Seats for LWB and SWB bikes?
Hey guys I was wondering if someone may know about this. I have a LWB R75/5 with a rusted out seat pan. I found a nice replacement from a SWB bike via internet so I can't measure it, any idea if they are the same or will mine be longer?
If you can't fix it with a hammer, you've got an electrical problem!
woodly1069 is offline   Reply With Quote
Old 11-11-2012, 07:47 AM   #2
boxerkuh
Oddometer: 236
Sorry, will not fit... the Long wheel base is longer, not by much, but enough were it does not work.... It will not line up.
Don't ask me by how much (maybe 2 inches or more... somebody else will know exactly), but I redoing one of my bikes and held both short and long wheel base rear subframes to the bike.... there is a maked difference.
boxerkuh is offline   Reply With Quote
Old 11-11-2012, 08:00 AM   #3
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,951
Making it fit can be done by converting the LWB bike into a SWB bike. But then for that money you could buy several correct seats.
---Albert Einstein
Old 11-11-2012, 08:00 AM   #4
blaine.hale
blaine.hale's Avatar
Oddometer: 3,204
What he said. On the plus side, you can use /6 seats
1974 BMW R90 /6
1968 Bultaco Matador MK3
1973 BMW R75 /5 Toaster LWB
1969 Bultaco Bandido MK2
2013 Husqvarna Terra TR650
blaine.hale is offline   Reply With Quote
Old 11-12-2012, 05:42 AM   #5
woodly1069 OP
woodly1069's Avatar
Oddometer: 1,989
/6 seat...hummmm. thanks guys, didn't think it would work but thought I should check
Old 11-12-2012, 06:12 PM   #6
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,463
[QUOTE=boxerkuh;20019375]Sorry, will not fit... the Long wheel base is longer, not by much, but enough were it does not work.... It will not line up. QUOTE]
+1..... Been there....tried that.....it just won't fit.
http://jupiterhack.blogspot.com/
Living proof you shouldn't play with matches
ABC# 1992
Old 11-13-2012, 07:18 AM   #7
cycleman2
Oddometer: 580
You have to change the rear sub frame as well if you are converting from a SWB to LWB or LWB to SWB. The fenders are the same its just that everything else has to match up to the 2" difference in length of the swing arm.
The early SWB seat is a much smaller rounded seat with just the 2 handles bolted to the rear sides of the seat. It didn't have the big wrap around handles that later /5's had. Also tank fitting is an issue when going from a Toaster Tank model to the traditional /5 tank.
2013 DL650 Adv
cycleman2 is offline   Reply With Quote
Times are GMT -7.   It's 03:30 AM.
