Old 11-11-2012, 09:10 AM   #1
Deepc OP
Oddometer: 299
ACC2 Fuse location
05.5 950A My newly installed heated grips stoped working. They are attached to ACC2. I switched them over to ACC1 and they work just fine. Tried plugging my cell phone into ACC2 and it's not giving out juice. Checked all fuses in box and everything seems cool. No visual damage to the wiring throughout and all connections are tight. What gives?
Deepc is offline   Reply With Quote
Old 11-11-2012, 10:34 AM   #2
6732cash
6732cash's Avatar
Oddometer: 161
try pulling the fuses out and checking the blade ends they go cruddy
6732cash is offline   Reply With Quote
Old 11-11-2012, 12:09 PM   #3
Deepc OP
Oddometer: 299
Checked & cleaned. Nothing
Old 11-11-2012, 12:29 PM   #4
Peanuts
Peanuts's Avatar
Oddometer: 1,598
Check the brown wire is a good ground.
Peanuts is offline   Reply With Quote
Old 11-11-2012, 01:15 PM   #5
6732cash
6732cash's Avatar
Oddometer: 161
You need a small test light to see if you have lost pos or neg
Old 11-12-2012, 01:30 PM   #6
Deepc OP
Oddometer: 299
Acc2 fuse
Which fuse is Acc2 in the gllove box?
Old 11-12-2012, 01:39 PM   #7
6732cash
6732cash's Avatar
Oddometer: 161
From memory which is fading fast its no 2 from left but dont quote me
Old 11-12-2012, 03:00 PM   #8
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,241
Correct - second from left. First one is Acc1.
Chuckracer is online now   Reply With Quote
Old 11-13-2012, 12:09 PM   #9
Deepc OP
Oddometer: 299
Thanks for the help.
Old 11-15-2012, 03:15 PM   #10
Deepc OP
Oddometer: 299
ACC2 still wont work.
I checked the ACC2 fuse in the glove box and the fuse is fine. As stated earlier, my heated grips worked before and just stopped. I plug them into ACC1 and they work just fine. This tells me there is problem between the ignition and the ACC2 wiring. Am I missing a fuse somewhere or should I be looking for a Fried relay or something. Its getting cold !
Old 11-15-2012, 06:38 PM   #11
spafxer
spafxer's Avatar
Oddometer: 2,606
Pull the fuse. Turn on the key. Use a 12 volt DC voltmeter and check the receptacle the fuse tabs plug into.. If you have power there then you know the problem is after the fuse. If not, then you know the problem is before the fuse.
spafxer is offline   Reply With Quote
Times are GMT -7.   It's 09:10 PM.
