Old 11-12-2012, 10:23 PM   #16
ChadHahn OP
Oddometer: 262
Tucson is a dark skies city. Lots of the streets don't have much in the way of street lights. It was a real pain driving home the other night with no headlight.
Chad
ChadHahn is offline   Reply With Quote
Old 11-13-2012, 12:41 AM   #17
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,571
Originally Posted by ChadHahn View Post
It was a real pain driving home the other night with no headlight. Chad
Was high beam not working as well?
David Hunn:
R100GS Ray Peake special.
http://www.advrider.com/forums/showt...uild+australia
gsd4me is offline   Reply With Quote
Old 11-13-2012, 07:15 AM   #18
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,359
Note to self;
Self, carry a spare headlamp and tail lamp in tool kit for future replacement roadside.
def is offline   Reply With Quote
Old 11-13-2012, 10:17 AM   #19
Lobby
Viel Spass, Vato!
Lobby's Avatar
Oddometer: 28,606
I rode my 99 GS at night for the first time yesterday.
A 1999, huh?
Thirteen years and you've never ridden it at night?
Gracie's Gold
Lobby is online now   Reply With Quote
Old 11-13-2012, 10:38 AM   #20
def
def's Avatar
Oddometer: 10,359
I don't ride at night either...so what?
Old 11-13-2012, 10:48 AM   #21
def
def's Avatar
Oddometer: 10,359
Chad
Years ago, while attending ASU, (circa 1961...Frank Kush was ASU football coach) I was returning from Tucson to Tempe when my 1960 Triumph TR6C headlight bulb decided it had had enough. I rode for miles without anything but starlight...not something I recommend. However in those days, there was little traffic and few Arizona Highway Patrol so, I made it back to campus without incident.
Fast forward...the current BMW motorcycle electrical system is very reliable and night time riding should not be a crap shoot like those days of Joe Lucas electrics and British motorcycles with positive ground systems.
Either carry spare lamps or convert your headlight to HID and never have a headlamp burnout again. Don't forget the tail lamp...go LED and never be without rear end lighting again in your lifetime.
Old 11-13-2012, 10:58 AM   #22
CanadianGS
GS'n
CanadianGS's Avatar
Oddometer: 82
Convert to HID. Did so on my 1150GSA. What a difference! And cheap Asian suppliers on FleaBay
There are many threads, here's one:
http://advrider.com/forums/showthrea...version&page=2
R1150GSA
73 Moto Guzzi Eldorado (Police)
R65LS (WIP, 75% done)
CanadianGS is offline   Reply With Quote
Old 11-13-2012, 12:09 PM   #23
def
def's Avatar
Oddometer: 10,359
Changing headlamps from incandescent to HID is likely one of the best modifications you can perform on your motorcycle. Doing so provides better daytime conspicuity (primary reason to change) and improves night time riding safety by providing much more light at longer distances.
Beware, if you go this route, there are several things to take into account;
1- Your state's safety inspection may flag an HID installation and not pass your vehicle.
2- You may make the wrong choice of HID lamp color and give up additional illumination (Lumens, the measure of the amount of light output of the bulb) while also creating dangerous glare for oncoming drivers.
3- You may create additional load for the headlamp wiring on your motorcycle and cause wiring failure if not properly installed.
4- You headlamp optics may not properly focus the light from the HID lamp and cause light scatter and poor down road light focus.
The older GS asymmetric headlight design with the projector low beam headlamp design is ideal for HID conversion because it employs a projector lens and utilizes a mask cutoff to control light scatter and blinding of oncoming drivers.
Some things to consider;
1- HIDs generate less heat and so preserve the headlight housing.
2- HIDs require an ancillary ballast which must be mounted on the motorcycle.
3- At cold strike, the HID system may consume upwards of 20 amps of current momentarily which exceeds the capacity of the wiring.
4- Some vintage BMW headlight circuits are not fused and so, a relay is needed to eliminate overloading the headlight circuit.
5- HIDs with a lamp color of 4300K provide ~2.5X greater Lumens that the OE headlamp.
6- HIDs with a lamp color greater than 6000K (color toward the blue, UV spectrum) provide less than the OE lamp Lumens and are objectionable to oncoming drivers and are easily spotted by LEOs. The human eye does not see UV light so keep your headlamp color in the visible spectrum.
7- The 4300K lamp color is the same used on automobiles with OE HID headlamp systems. This lamp color was chosen because it provides the most visible light in the spectrum which is most visible to the human eye and creates improved daytime conspicuity. Remember, most everything we see is the result of light reflected off the object of interest. Therefore, the more light provided for reflecting off the target image (Bambi, street signs, rocks in the road, pot holes) results in our increased ability to discern the target image at a longer distance.
8- Light (lumens) diminishes by the square of the distance. Also, since nighttime riding relies on reflected light and this reflected light must make a round trip from your headlamp, to the target and back to your eyes, you had better have plenty of light (Lumens) output from the headlamp to begin with.
9- Reliable HID kits are now rather low cost, good ones available for ~$50.00.
10- HID systems are unaffected by vibration so offroading will have no affect on lamp life.
Old 11-13-2012, 12:27 PM   #24
vintagerider
vintagerider's Avatar
Oddometer: 1,962
Will you 1150 guys please stop assuming that what works for you is valid for 1100 riders? Thanks.
edit: what works, sorta
Scatter is bad with the HID in the 1100 bus reflector. It does not have the projector beam of the 1150. I did one using a DDM 55 watt slim ballast.
http://www.ddmtuning.com/Products/DD...ast-35W-or-55W
2 x slim DDM 55 watt- kit-
2 x 3,000K arc tubes
why 3k bulbs? When driven at 55 watts the color shifts toward yellow white, close to halogen. Much less fatiguing for yourself and for on coming drivers, Best color for daytime riding.
added 2 x 4500k spare bulbs at time of order
skipped optional harness
cost was very reasonable
slim ballasts have external igniter. did not cause any 1100 faulting.
Wiring (simple/easy/clean/reliable/safer for harness):
-separate the DDM power wire fromDDM lamp harness.
-cut ballast plug then joined it to tinned marine (West Marine)14 ga double insulated run directly to battery
-fused above pos wire with posi-fuse at battery
-cut above wire (pos only) and inserted relay in series
-tapped above ground wire for relay coil (posi-tap)
-ran trigger wire to under-tank oem connector (posi-tap)
-mounted ballast to steer head with HD hook loop
-Taped, tucked away oem H4 socket for emergency re-fit
Wiring/load is completely independent of oem harness except for milli-amp trigger. Load is off oem wiring (important, oem not fused)
-done-
kept the spare ballast and arc tubes, can re-sell
The above gives you single beam only. Works fine in conjunction aux halogen or led for high beam. Some scatter but not too bad. Riding behind another driver- they tend to let you pass. Wide beam lights side of road. YMMV
Not DOT legal. Won't pass state inspections.
TIPS:
Relay type and mounting: Relay should have screw tab. There is a hole on the side of steer head. Also mounts very well to tail of under tank connector plate with zip ties.++ Use a pre-made relay socket and pigtail! Can re-purpose from salvage yard. Volvos have fully potted heavy relays.
Make connections with posi-lock barrels.. If you later decide to go with 100 watt halogen then your relay and wiring is already in place (leave enough extra marine wire to reach head lamp).
You don't need to access the yellow or white wires at the oem H4 for trigger, you can tap these under the tank, physically close to relay.
Can't emphasize how easy and reliable this wiring system is if you use posi-taps and marine duplex double insulated tinned wire. Most problems with aux lighting stem from splicing, use of low grade wire, using crimp terminals, not using dedicated ground for everything. Always wire direct to battery. No soldering required. Unobtrusive to oem harness.
It's pretty easy to add three or four relays to the tail of the BMW under tank connector plate. All relay coil grounds can be tied together. Leave enough duplex wire from each relay to reach typical aux lamp mounting location. Coil can be left under tank until needed.
Three or four posi-fuse holders can zip tie together near battery.
Trigger points can be changed simply by adding additional posi-taps to oem harness trigger points.. Un-used pre-wired relay/wires won't have any power until you connect the trigger.
Don't worry about adding switches at first. Lights will come on with engine. Switch if desired just connects to trigger so it doesn't carry load. OEM high beam switch is already in place to trigger one or more relays.
Not much to think about if you follow these instructions. Very versatile wiring method that adapts easily to changing needs. guarantees both dedicated batt + and ground to each load and prevents damage to oem harness.
vintagerider screwed with this post 11-13-2012 at 04:34 PM
vintagerider is offline   Reply With Quote
Old 11-13-2012, 12:43 PM   #25
def
def's Avatar
Oddometer: 10,359
There are conversions that work for 1100s as well.
Old 11-13-2012, 01:18 PM   #26
ChadHahn OP
Oddometer: 262
Originally Posted by Lobby View Post
A 1999, huh?
I've only had the bike since May and I didn't get to ride it much this summer, although night would have been the time to go for a ride.
Chad
Old 11-13-2012, 01:43 PM   #27
Lobby
Viel Spass, Vato!
Lobby's Avatar
Oddometer: 28,606
Chad
I knew it was something like that. But this is Advrider, so...
BTW, I have an HID lamp on the low beam of my 12GS. It really made a difference in the night lighting.
I used to have an 1150GS, and its headlamp was even worse than my 12GS. I've never had a 11GS, so I can't compare. I'd recommend you check out the HID option for your bike.
$50 or so, plus an hour or two in the garage.
Gracie's Gold
Old 11-13-2012, 02:31 PM   #28
def
def's Avatar
Oddometer: 10,359
Chad
Have you ridden up Mt Lemon? Or tried the Salt River Canyon out of Globe (Hwy 60).
Old 11-13-2012, 02:44 PM   #29
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,571
I had an H4 +50 bulb in my 1100GS, it made a great difference. Another easy and cheap improvement is to have a relay fitted to the headlight.
David Hunn:
Old 11-13-2012, 06:02 PM   #30
ChadHahn OP
Oddometer: 262
I've been up to Mt Lemmon. I haven't been through the Salt River Canyon on this bike. This spring I rode down to Bisbee and did some gravel like whatever the road is from Parker Canyon Lake to Sierra Vista.
I was going to take Reddington Road and the back side up Mt Lemmon but was having trouble with my pillion seat lock and after the third time it bounced off I turned around.
Chad
Times are GMT -7.   It's 09:19 AM.
