Old 11-12-2012, 04:11 AM   #1
deWog OP
Oddometer: 107
New Metzelers for the GS...
Just launched, the new Karoo 3
deWog is offline   Reply With Quote
Old 11-12-2012, 04:34 AM   #2
BMW JEEP
BMW JEEP's Avatar
Oddometer: 178
Wow, if form equals function, those look like a great 70/30 dual sport. Kinda like a cross between the Heideau Scout and the Karoo 2. Where did you find those? They weren't even on the Metzeler homepage.
2013 R1200GS K25 (Camhead) Triple Black
2007 F650GS Dakar
“Life is what happens to you while you're busy making other plans.” ― John Lennon
BMW JEEP is offline   Reply With Quote
Old 11-12-2012, 05:52 AM   #3
slowoldguy
Tire Tester
slowoldguy's Avatar
Oddometer: 8,671
I'm game. Somebody find where I can buy a rear.
RTB V- The Texas ADV Rally- Hurry before we fuck this up!
http://www.rollthebonesrally.com/
"If you can't fix it with a hammer you can damn sure teach it a lesson".
slowoldguy is offline   Reply With Quote
Old 11-12-2012, 06:06 AM   #4
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,080
Any additional information available, like grip or tread life compared to past versions?
Old 11-12-2012, 06:15 AM   #5
Okie Preacher
Okie Preacher's Avatar
Oddometer: 881
Given your track record with new tires and your throttle habits, I am thinking 2,500 miles tops!
Okie Preacher is online now   Reply With Quote
Old 11-12-2012, 06:22 AM   #6
slowoldguy
Tire Tester
slowoldguy's Avatar
Oddometer: 8,671
I'm ever hopeful. ;) Gonna go look at my TKC rear now. Poor bastard.
Old 11-12-2012, 06:24 AM   #7
mcstark
KaTooM convert
mcstark's Avatar
Oddometer: 1,141
Now that looks like the perfect GS tire, and coming from Metzeler, I'm hoping it wears like iron.
Regards,
Mark
2004 KTM 950 Adventure
Black is the new orange
mcstark is offline   Reply With Quote
Old 11-12-2012, 06:47 AM   #8
Versys_User
HardCore n00b
Versys_User's Avatar
Oddometer: 111
you think it may run like a tractor tire?
with those big grooves in between blocks and no center rubber
Versys_User is offline   Reply With Quote
Old 11-12-2012, 08:07 AM   #9
Mike Ryder
Kriegerkuh
Mike Ryder's Avatar
Oddometer: 997
spring 2013.
http://www.motoblog.it/post/84773/me...enduro-karoo-3
Karoo 3 sarà in vendita a partire dalla primavera 2013 e sostituirà gli attuali modelli in gamma MCE Karoo e MCE Karoo T. Il nuovo pneumatico sarà disponibile nelle misure: 110/80 - 19 M/C 59R TL, 120/70 R 19 M/C 60T TL, 90/90 - 21 M/C 54R TL all’anteriore. Per il posteriore invece: 150/70 - 17 M/C 69R TL, 170/60 R 17 M/C 72T TL, 130/80 - 17 M/C 65R, 140/80 - 17 M/C 69R, 140/80 - 18 M/C 70R, 150/70 - 18 M/C 70R. Tutte le misure disponibili sono contrassegnate con la dicitura M+S “all season”
Yes I am quite serious.
Mike Ryder is offline   Reply With Quote
Old 11-12-2012, 08:17 AM   #10
LaurelPerryOnLand
Oddometer: 3,481
In other words...ENGLISH for example...
After the world premiere of the new tire enduro street Tourance Next at INTERMOT, Metzeler presents EICMA another jewel of the range 2013: 3 Karoo , tires with inserts intended for riders who like adventure and want to use their bikes for long trips off road and raid Africans. Karoo 3 fits perfectly on modern enduro large and mid-size that should be used in both on-road as off-road, just as the latest addition to the BMW R 1200 GS, which can be equipped with just the latter product measuring 120/70 R 19 at the front and nell'inedita 170/60 R 17 at the rear.
The new Karoo 3 is a very versatile product able to guarantee to all those bikers who love travel, medium and long range, a high mileage , excellent grip in off-road , a stability notch and excellent handling . All important when you consider that riders often have to travel many miles of asphalt before they reach their destination off road.
These are the main improvements of the new Karoo 3 compared to their predecessors MCE Karoo and MCE Karoo T:
- the compounds of the new Karoo 3 use components in high dispersibility able to obtain a more homogeneous compound which offers greater mechanical resistance to tearing, for the benefit of the mileage , while maintaining high damping capacity.
- The structure of polyester provides strength and flexibility at the same time because the tire is able to copy perfectly the ground unevenness in contexts for the benefit of off-road handling and traction.
As regards the design of the tread , the plugs from the trapezoidal shape presenting an innovative geometry of the dowel that ensures traction off road progressive to different bending angles. The V shape of the drawing, given by block arrangement, optimally distributes the lines of force transmitted to the ground for the benefit of more regular wear on asphalt.
The center blocks, being large, reduce their mobility in favor of greater stability even at high speeds. Furthermore, their spacing is variable from the center to the shoulder: the center the dowels more spaced ensure better penetration into the ground offering better traction in off road, on the shoulder instead of the dowels are closer to each other to ensure greater flat tire in the fold on asphalt in favor of the grip.
Karoo 3 will go on sale from spring 2013 and will replace the current models in the range and MCE Karoo MCE Karoo T. The new tire will be available in sizes: 110/80 - 19 M / C 59R TL 120/70 R 19 M / C 60T TL, 90/90 - 21 M / C 54R TL front. To the rear instead: 150/70 - 17 M / C 69R TL 170/60 R 17 M / C 72T TL 130/80 - 17 M / C 65R, 140/80 - 17 M / C 69R, 140/80 - 18 M / C 70R, 150/70 - 18 M / C 70R. All available sizes are marked with the words M + S "all season".
They look like a nice cross between a Tourance and a TKC. With the Tourance influence...they'll probably ride better on road...yet retain the traction of the TKC.
Hello Metzeler: I'd like to sign up to test these. PM me.
jdub is also in line for testing...just BEHIND me!
LaurelPerryOnLand screwed with this post 11-12-2012 at 09:15 AM
LaurelPerryOnLand is offline   Reply With Quote
Old 11-12-2012, 08:27 AM   #11
KMC1
There is no spoon.
Oddometer: 2,561
Looks awesome!
We need some riding impressions, stat!
Obama says adding $4 trillion to debt is unpatriotic: http://www.youtube.com/watch?v=1kuTG19Cu_Q&sns=em
An Overview of the United States National Debt: http://www.davemanuel.com/us-national-debt-clock.php
KMC1 is offline   Reply With Quote
Old 11-12-2012, 09:08 AM   #12
jdub
Dawg bytes reel gud
jdub's Avatar
Oddometer: 1,840
It's about time some fresh off-road oriented rubber comes out of the big OEMs. I'm in line for beta testing!
Current: 2014 R1200GSW
jdub is offline   Reply With Quote
Old 11-12-2012, 09:18 AM   #13
going south
hero & Zero...
going south's Avatar
Oddometer: 1,131
Man oh man.. I knew you'd be all over this...
Looking foreword to your assessment on the new meat....
going south...
Never Lost! Just Don't know where I am!
"Don't worry about your money, let your money worry about you" Jorge González
going south is offline   Reply With Quote
Old 11-12-2012, 01:04 PM   #14
deWog OP
Oddometer: 107
Thanks LaurelPerryOnLand..........that's a surprisingly accurate translation.
- well done!!
Old 11-12-2012, 01:10 PM   #15
LaurelPerryOnLand
Oddometer: 3,481
- well done!!
il tuo benvenuto.
Ciao!
Times are GMT -7.   It's 06:14 PM.
