Old 11-12-2012, 05:56 AM   #1
Bluethumb OP
Oddometer: 129
Billet Mini 6
I just picked up a R80ST. The PO upgraded to a Harrison Billet Mini 6 brake caliper, using the stock disc. I believe I've seen this same caliper used with larger rotors, using an adaptor mount with the caliper to allow the larger diameter rotor. I've done some web searches but can't come up with any info.
Anyone running the Billet that can give me advice on the best set up. Would a larger rotor give me better braking?
I also need a source for a new brake line.
Bluethumb is offline   Reply With Quote
Old 11-12-2012, 07:30 AM   #2
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,747
wait till you have to replace 3 pairs of brake pads!!! The stock pads are soft and don't last long. On my R100GS front end I was able to use the Stainless line which fit the stock caliper. I ended up doing a conversion to a Brembo 4 pot (which you can't do) and was very happy with that. Sold the 6 pot.
You should be able to use the MAP engineering rotor and bracket just fine. In order of preference I'd do the larger rotor first, then the 6 pot. My main issue with the 6 pot was 3 pairs of soft pads. Even though longer lasting pads are an option.
Try Motobins, Sibeinbok, Boxerparts in germany, Motoren Israel.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 11-12-2012, 07:37 AM   #3
Bluethumb OP
Oddometer: 129
The six pot is already on the bike, so I get to live with it. I've looked at the MAP website but couldn't see any listings for larger rotors or adaptors. Is MAP the source or other sites? as far as Motobins, etc., is this for brake pads?
Old 11-12-2012, 03:20 PM   #4
One Less Harley
Oddometer: 4,747
should fit the ST
http://www.boxxerparts.de/xtcshop/pr...38dd0837f662d0
http://www.bmwboxersupplies.com/prod...roducts_id/164
ST brake kit
http://www.motoren-israel.com/produc...for-R80ST.html
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 11-12-2012, 04:01 PM   #5
Hennepinboy
Have battery will travel.
Hennepinboy's Avatar
Oddometer: 456
Billet 6
EBC FA175 brake pad will fit the Harrison Billet 6 brake caliper. Seals and O-rings are available from Harrison in England. It is pretty easy to rebuild the caliper. I am running a stock diameter EBC brake rotor.
I did safety wire the caliper pins that hold the pads so I could not loose a pin if of the three hair pin should fall out.
I have the Billet 6 on the front of my 92 R100GS, if I had the balance or the ball I think I could do stoppies with the bike, the Harrison was a big improvement from stock.
The Minnesota Airmarshal
Hennepinboy is offline   Reply With Quote
Old 11-13-2012, 10:17 AM   #6
Mark Manley
On my way
Mark Manley's Avatar
Oddometer: 745
I have ridden a friend's ST with a Harrison six piston caliper and thought it was as good as the double disc set up I have on the front of my G/S, I did find it pulled to one side and think a larger disc would make this worse and the bike over braked, stick with what you have.
If it's in the Touratech catalogue then you don't need it
"You've got to think for yourselves! You're all individuals!"-Brian of Nazareth
Mark Manley is offline   Reply With Quote
Old 11-13-2012, 10:24 AM   #7
Bluethumb OP
Oddometer: 129
Good advice. Thanks. I think it just needs a good sorting out.
Times are GMT -7.   It's 12:04 AM.
