Old 11-12-2012, 07:50 AM   #1
corriej OP
corriej's Avatar
Oddometer: 19
Help with new BMW F800GS chain
Hi Guys,
The BMW OEM chain for the F800GS was a chain without a softlink and you had to remove the swing arm to fit it. However since the launch of the 2013 F800GS BMW changed the part and it now has a softlink.
The problem is I have no idea how to fit this:
Can anyone help? What do you do with the little metal springs/wires?
Corrie
corriej is offline   Reply With Quote
Old 11-12-2012, 03:09 PM   #2
GH41
Oddometer: 822
Lets call the springs Titty Springs! GH
GH41 is offline   Reply With Quote
Old 11-12-2012, 04:26 PM   #3
Motoriley
Even my posing is virtual
Motoriley's Avatar
Oddometer: 2,685
I can't help but this looks interesting so I'm subscribed. I too vote for them to be called "titty springs".
04 Toyota Sienna, new wipers for 2011!!
Electricity (120 AC), Indoor Plumbing, new kitchen tap for 2010!!!
Color tube TV, Microwave Oven (yes she rotates!),Washer & Dryer,Paved Driveway,
Website - http://www.apormc.com/
Vids - http://www.youtube.com/user/Motoriley?feature=mhum
Motoriley is offline   Reply With Quote
Old 11-12-2012, 04:28 PM   #4
TowPro
Lets ride
Oddometer: 3,219
I have seen these before, but never used them. do they have a hole through the pin that this wire goes into?,
then the wire bends sort of like safety wiring a master link on.
2015 KTM 690 Enduro R
2014 R1200GS - My Naked Street Touring Bike
2000 KTM LC4 640 E - currently up for adoption with 3200 miles
TowPro is offline   Reply With Quote
Old 11-12-2012, 05:54 PM   #5
Moqui
Oddometer: 10
My guess is that they are a spacer that fits between the plate and roller and goes around the oring. That way they would protect the orings from being crushed and distorted when the assembly is pressed together. They probably need to be removed before riding the bike. And yes they should be called Titty Springs.
2010 F800GS
2000 200EXC
Moqui is offline   Reply With Quote
Old 11-13-2012, 04:36 AM   #6
corriej OP
corriej's Avatar
Oddometer: 19
Hi Moqui, you are right. I asked around and that is exactly what they are used for. They are spacers to stop noobs like me from crushing the o-rings during installation.
Titty Springs +1
EDIT: You have to use a chain rivet tool to fit the rivet link.
Old 11-13-2012, 08:34 PM   #7
Kiwi Tinkerer
Ross
Kiwi Tinkerer's Avatar
Oddometer: 389
Peen it
Or peen the end with a small peening hammer. Stick a heavy piece of steel behind it. That works just as good.
Kiwi Tinkerer is offline   Reply With Quote
Old 11-14-2012, 05:12 AM   #8
flubbyhog
flubbyhog's Avatar
Oddometer: 100
The two springs are to hold the chain close together so you can install the conn. link.
It also looks like a riveted chain so you have to mushroom the pin heads after you get it all together. I have a chain tool and it works good for this. It's basically impossible to hold the backside of the link and whack the pin with a hammer hoping to mushroom it out that way.
I've had my chain tool for so long, I think it was made by MotionPro? Could be wrong though. They're all over the net for around 50-60 bucks.
Mmmmm, liquid courage...
flubbyhog is offline   Reply With Quote
Old 11-15-2012, 05:09 AM   #9
AviatorTroy
AviatorTroy's Avatar
Oddometer: 1,650
I just bought a chain tool at harbor freight for 12 bucks. If it lasts long enough to be used 10 times that's what, 200,000 miles? Good enough for me.
AviatorTroy is offline   Reply With Quote
Times are GMT -7.   It's 07:53 PM.
